ooh, interesting, my 148 CABYE under Mach 2 seems to lack a cold bug...Quote:
i like your spirit :D
Yep, all of those ~ LDTx3, trying the 6.23-1 BIOS. RAM is Memtest stable tests 5 & 8 250MHz 1:1 (2.5-3-6-3 1T) vcore 1.52 actual 1.53 on multimeter!Quote:
Originally Posted by tatts
Just tried to boot on the above settings at 10x250 and get that great BSOD IRQL_NOT_LESS_OR_EQUAL :confused:
Edit, disabled bank int. and will now load into windows but bombs out of SuperPi instantly........I have also been using this guide TCCD DDR600+ DFI nF4 Ultra/SLI guide for RAM tuning.
I wish :( htt literally scaled opposite to temperature. When I first set it up, I thought I had the worst opteron in history as I couldn't get above 2.4 at -20C! 70C warmer gives me 9X324 and more.Quote:
Originally Posted by Aphex_Tom_9
just got my opty 146 today. stepping as follows:
OSA146DAA5BN
CABYE 0540FPBW
1341649J50193
i also my Asrock Dual sata2 version 1.04
what do u guys think of the posibilities of this stepping? :stick:
I've always been under the impression that the coldbug doesn't kick in until substantially lower temps are achieved (-50c), by that I mean far beyond the kind of temps achievable with a single stage. This rings true with my set up too, even at -26c my HTT is unaffected, 320+ isn't a problem.
nearly every 146 so far with that stepping have hit 3ghz with pritty low volts, mine is the same stepping and does 3ghz on 1.45V and some need upto 1.55V, just hope your board clocks well :DQuote:
Originally Posted by Naasar
I've been able to push this chip now to 2.8 on my CABGE 146 opteron with the IHS off. Will try to push more.
Are the CABYE 0540 coming in the cardboard box or the new box? Anyone know?
All the retail opty's come in the cardboard box.
the cardboard box.. is the new box ;)Quote:
Originally Posted by NYCTeeN82
Does the 1.04 version of the mobo wildly different from previous ones? If no, flash to the first OCworkbench beta bios and do the vcore mod. Once that's done you should be able to take it pretty high with the first limitation coming up being the cooling you have. On water you should be able to crack 3ghz. After cooling issues are resolved, YMMV based on what the board will allow. Good luck and post your initial results ASAP.Quote:
yeah starting to see 146 CAB2E FPMWs in Australia tooQuote:
Originally Posted by Razor_cut
What week?Quote:
Originally Posted by eva2000
week 40 I believeQuote:
Originally Posted by xenolith
Anybody have any results on these Opty's? I missed the boat with the CABNE, CABYE most likely. There's a place or two in the U.K that are supposed to be getting stock today, so there's a chance they'll be the CAB2E's. I'm hoping for the CABYE's, but I doubt it.Quote:
Anyone with 146 CAB2E results? :)
My 146 will arrive on friday, code is CABYE 0540 FPMW. *PMW or *PAW are usually good AFAIK.
So what do you think, is it a winner?
mats : where from ?
I have i Choice to buy eiter a CABYE 0536 or a CAYE 0540 for the same price, wich one is the best?
Yea, that's a good stepping - DFX's Opteron 146 CABYE 0540 FPMW @ 3.5GHzQuote:
Originally Posted by Mats
Do you mind if I ask where you got yours from?
Is that 144 or 146?Quote:
Originally Posted by Wiker
ITs a 144
Well, Eva2000 got his 144 CABYE 0536 up against a FX-57 - check out Super Pi: Opteron 144 CABYE 0536 GPMW vs FX-57 CABCE 0516 WPMW.Quote:
Ok I hioe to reach about 2.9-3 ghz with a thermaltake bigwater. Wich one seems to have the best possibilities of this`?
0536 i think.
