Originally Posted by
Damien
kind of a double post in a way but i've tried a bit more here..
new build is in sig, i'm out of ideas here. I've tried leaving all memory settings at auto, manually set 8-8-8-21 (rated speeds), tried lower cpu clock, 1.64v on ram, 1.45v on qpi/vtt, etc... i just can't figure this out. no matter what, anything higher than 1520 results in it just sitting there with a blank screen when trying to boot then shuts down, comes back up and it had to set memory back to default, which makes it 1066 on my board i believe
1520 appears to be working with no issues, but this is really hindering me from trying to get a 4ghz stable clock down because that requires 1600mhz
anyone have any ideas?
i noticed in cpu-z that my SPD for 1600mhz is coming up as 2T...is this true? I was under the impression ddr3 can run 1T..i havent even tried 2T
