EIST. that stands for Enhanced Intel SpeedStep Technology.
EIST is a feature, that adjusts your Multiplier, depending on the level of activity of the CPU.
if all your CPU is doing is browsing the internet or typing, then it will default to the lowest available multiplier, since its basically doing nothing.
this is to do many things, save on CPU power, save on actual power used, and to save on heat put out by the CPU.
theres no reason to have a CPU at full speed... if your only doing little mundane things like listening to a MP3, or browsing the net...
theres also... C1E.
C1E is a feature, then when it first came out, drove me absolutly nuts, cause no where was it explained what the feature was or even what CPU had it, for awhile after it started being used in processors.
so I'd be overclocking, run super PI, and get some great run... then C1E would kick in, and my voltage would drop from 1.5 volts, to 1.2 and my OC would stay the same... and this would always lead to instant CPU freezes.
this one single feature drove me so nuts trying to figure out what was going on, when about a year ago it started being used, and my Abit AS8 had no option to disable it, and I had no idea what it was...
I got to the point where I almost took the board outside, and smashed it from being screaming mad.
had I done that, I would have killed a perfectly fine board... cause this is a CPU feature.
a realllyyyyyyyyyy annoying CPU feature.
what C1E does, is lower the Voltage of the Processor, when at Idle, to save on heat output.
remember, a CPU is meant to only be run at stock.
Intel designs these CPU's to be stable at thier stock speed, with C1E active.
however, C1E for a overclocker, can leave you going nuts if you dot know what it is.
especially if you have a older LGA processor, that doesnt have EIST on it, but does have C1E.
C1E. if used with EIST, is actually a handy feature to have, if you want to keep your CPU temps low while at idle.
but if you choose to disable EIST, I strongly suggest you disable C1E at the same time, otherwise, this feature may drive you bonkers too, just like it did with me.
and then theres TM1/TM2.
I know what these are, Thermal Monitors.
however, I am still confused as to how these are different from C1E and EIST.
but, in my Gigabyte board here, in the bios, the description it gives is... TM1 lowers the CPU Voltage and MHz, when the CPU is at Idle.
to me, that just sounds like EIST and C1E... so I dont know how thats any different. but either of these 3 features, can and will alter your voltage readings in windows.
which is why, when you set say 1.5 volts in bios, you only see 1.2 volts, when you actually get into windows, cause EIST or C1E are active... or TM1/2.
disabling these, in bios, should obviously force the CPU to run at whatever voltage you select... assuming you keep in mind, you still have a voltage droop to deal with
