That looks like a keeper, nice chip you got there.
Hello America xD
Im gona buy a Opteron 165 or 170 therre (in USA), Im from Chile, so I can't go to the store and choose the stepping I want.
Mwave and monarch computer are the cheapest resellers, do you know what stepping do they have?
And the worst stepping I could get, how much would oc?
And a last question...
Amd is going to cut the prices, but some stores (mwave and monarch) Already have prices like the new..would they cut also? and....is going to come more stock?
Hi, I'm posting to see if any of you have any suggestions. I've taken my Opty up to 2.9 (prime and super pi stable) but I'm having trouble hitting 3.0 stable.
List of things I've tried
1 : Upped vcore to 1.415
2 : Lowered divider from 150
3 : Fiddled with timmings
I'm kinda stuck any ideas :confused:
http://valid.x86-secret.com/show_oc?id=132037
Vcore at 1.5-1.55v and prime at 3.0Ghz
Dont forget to up your chipset and LDT volts a notch, and keep your memory way under its normal speed. Raise afterwards.
ello America xD
Well I'm on air and anything over 1.42v causes core 1 to push 58-59c and eventually fail prime (core 1 runs about 5-6c hotter than core 2) . Maybe a better cooler would help me but I figured it should be enough. I'm not brave enough to go lidless or any thing crazy like that. ;)Quote:
Originally Posted by v0dka
My memory isn't oc at all. I have ddr500 g.skill hz's and they are right at spec pass memtest and everything. :confused:
mm...what are being the last steppings bought...and were....?
and how they did oc? =D
Thx
Bz
shadow_419: what are ur temperatures on full load? Thx Bz
http://img360.imageshack.us/img360/5...2063630eo2.png
got this ccbbe0615epmw from newegg last week this is how it pperformed , i think it has a bit mor to give but i got to my goal and did'nt want to push it
EDIT something i noticed about task manager shows the cores as messed up but i assure you that both cores were at 100% with p95 and will redo prime next week so there are no questions
Most good stepping opty's need at least 1.5v for 3.0Ghz.Quote:
Originally Posted by shadow_419
I would be very surprised if you could pull it off at anything near 1.4v. Youre on air with what cooler, stock? Those temps look awfull, just get the Thermaltake BT, cools rediculously well for $ 30 and it is really quiet too. Hows the airflow in your case?
I have the same exact problem as shadow.
325 x 9 max @ 1.44v DMM 44c-45c SP2004 on the hottest core 41c-43c on the other. I can't get 333 x 9, If I raise the NB volts it don't do anything, or LTD volts. Accualy get a little longer on SP2004 with 1.20v LTD. I'm just looking to get SP2004 stable. SuperPI 8mb runs fine at 3.0 .
Same Ram as shadow, the Ram runs 275 2.7v memtest stable. I can't get 3.0 with a FX-55 or a naked 148. 2.9 is the max on all 3 CPU's, or just a tad over 2.9, The FX dose 3.0 @ 1.40v under phase fine. It's the only one not cold bugged.
As for this 165, seems 325 is the max for both my Expert and Sli-DR. I'v tryed everything. Tryed 100 mem, x6 CPU Multi, 325 is the max both SP2004 stable at. Can post about to 334 and SuperPI fine, just SP2004 fails at anything over 325.
I'm using the 406 BOIS from DFI. And I see shadow is using Big Toe's Bios.
Been spending money just to get 75mhz faster. I bought this CCBBE off ebay because I almost for sure thought it would do 3.0 . But I guess my mother board needs better cooling. But it never gose to 55C on the NB chip. I have the same as shadow, 1 core is about 5c hotter than the other. I can run up to 1.6v befor it hits 60c in SP2004.
Anyways I'm just going to follow what people say to shadow. So I can try the same.
Peace, Nugz
guys, need some help here, i have problems getting 3.0ghz stable, most of the time core 1 would fail within minutes while core2 can go on and on.
chip is ccb1e 0550vpmw
dfi venus board.
gskill 2GBhs rams
currently trying to prime stable at 290x10
vcore is 1.530 (1.125 x136%)
my previous attempt at 2.8ghz passed 6hrs of prime before failing. but it failed OCCT 3 times at 3 very different times and on the last attempt, it passed occt. vcore 0.00% ripple
occt and prime temps nvr breached 39degC
BIOS Settings:
FSB Bus Frequency............................. - 290
LDT/FSB Frequency Ratio....................... - 3
CPU/FSB Frequency Ratio....................... - 10
PCI eXpress Frequency......................... - 105
CPU VID StartUp Value......................... 1.50
CPU VID Control............................... 1.225
CPU VID Special Control....................... 124%
LDT Voltage Control........................... 1.30
Chip Set Voltage Control...................... - 1.52
DRAM Voltage Control..........................- 2.80
DRAM Configuration Settings:
DRAM Frequency Set............................ - 100
Command Per Clock (CPC).......................- enable
CAS Latency Control (Tcl)..................... 3
RAS# to CAS# delay (Trcd)..................... - 4
Min RAS# active time (Tras)................... - 8
Row precharge time (Trp)...................... - 4
Row Cycle time (Trc).......................... - 7
Row refresh cyc time (Trfc)................... - 19
Row to Row delay (Trrd)....................... 02
Write recovery time (Twr)..................... - 02
Write to Read delay (Twtr).................... - 01
Read to Write delay (Trwt).................... - 03
Refresh Period (Tref)......................... - 3120
DRAM Bank Interleave.......................... - enable
DQS Skew Control.............................. - auto
DQS Skew Value................................ - 0
DRAM Drive Strength........................... -7
DRAM Data Drive Strength...................... 4
Max Async Latency............................. - 8
DRAM Response Time............................ - fast
Read Preamble Time............................ 6.5
IdleCycle Limit............................... 256
Dynamic Counter............................... - disable
R/W Queue Bypass.............................. 16x
Bypass Max.................................... 7x
32 Byte Granularity........................... 4bursts
I just got my opty 165 and removed IHS :slapass:
http://www.geocities.com/hellz0r/pics/PC.jpg
Testing in progress :stick:
I'm actually running a little cooler than that now. I had a bit too much as5 and it was ruining my temps. I'm actually on a scythe mine cooler with a yate loon 120mm fan. I also had the fan running at like 800 rpm :slapass: . My case airflow is pretty good. I have an Antec Sonata case with Yate loons. I'm currently running outside the case and my max load temps are 46-47c core 1 and 41-43c core 2. I figure about a 5c increase once I reinstall it into case.
Hey Nugz, what batch is your ram? I've never been able to break 260 with them without failing memtest. 261 = :nono: Any settings you use to get you to 275?
0512 first 4 numbers. right? need 2.7v to pass 275, then kind of stoped there, can get into windows at around 290 2.8v but errors in memtest.
On the setting
DRAM Drive Strength........................... 7
Refresh Period (Tref)......................... 3072
I have 0603 sticks. Whats the tref in bios, if you remember. I have it set to 3684. I've been priming at 3.0 for about an 1.5 hours right now at 1.42v(windows) 1.45(bios) temps are a little too much core 1 55c core 2 47c .
I'm running outside my case so I know I'd need a better cooler. A ninja or big typhoon I guess. I could use a fan with more cfm but I really hate noise. :D
:DQuote:
Originally Posted by Nugz
GUYS ... GUYS ... GUYS...
You forget that PSU needed for an OPTY running at 3GHZ@vcore > 1.5, on a system with a Hungry VGA gard (7900GTX or SLI), must be at least 600 - 700 Watts ....:(
You need to upgrade your PSU before start blame your mobo - cpu for OC wall...
Easy as that uh?
325 x9 1.45v Bios, 44c-45c no problem, SP2004 stable.
333 x9 1.55v Bios, 51c-56c errors in mins.
The video cards don't do anything, other than sit there in desktop running SP2004.
Thanks for the help, just shot out, your hardware sucks, "buy more". I really can't see my self spend more at the moment.
Nugz
edit: I see your point, will not even try anymore utill I get a new PSU.
My friend.... you don't get the point....:(Quote:
Running a game.... your CPU Never will go higher than 50% load (X2 CPU)....
But when running orthos or double SP2004 your CPU (X2) running 100% meaning double power (Amperes) needed....
Its almost the same power if you play games or do some SP2004 X2 Benches.... and probably on games scenario you need lower power....:D (In case the game use Single Thread Code execution)
In my case (600Watts PSU OCZ) if I want to make my system stable at 3200Mhz@ 1.52 Vcore, I switch off HDD's - DVD's - Extra Fans otherwise my system will crash after 5 minutes on ORTHOS bench.....
http://img144.imageshack.us/img144/4970/clip2yd8.jpg
I also need better PSU to get my OC at max ( 3330 MHZ water-cooled)...
Now I hope to get much clearer picture..... :D
I really do understand man.
This PSU only has 500 watts.
Would this one be good?
http://www.newegg.com/Product/Produc...82E16817194008
or this one
http://www.newegg.com/Product/Produc...82E16817703004
lol
Like one review says. A house hold braker can only handle 1800watts, 20amp.
This is getting bad, sometimes durring the day, I can't have my gaming computer and this computer and the washer going at the sametime, the braker shuts my power down. More power from my sockets? OMG lol
Hehe.
Peace, Nugz
The PCPower&Cooling you posted would do the trick. A little spendy though. This one here works great running 2 1900xtx's and a dual core FX at 3.2 24/7 and doesn't skip a beat.
http://www.newegg.com/Product/Produc...82E16817341002
Much easier on the wallet.:)
Athough I respect Dagidilis' opnion I dont really agree on wahts going on here.
An overclocked Opty at 3.0Ghz with 1.6v would need about 280watts. Your 500w PSU should handle that fine, if there is any problem it is with the amperage on the 12v. Now, Im guessing here but I would say anything over ~30amps should suffice. Most modern PSU's that are bought by the typical XS member are around 40amps.
Besides, plenty of people without 700w GameXstream or 1000w PCP & C and stable. How do you explain that?
Its a common misconception that Opterons get to 3.0 easy, 3.0 is a big line and I can thell you that Ive been through a LOT of them before I found one that did. I even had a CABNE 0528GPMW that couldnt get 3.0 stable, so even killer steppings have their bad ones. Really, its annoying as hell, but most will in the 2.9 range easy but 3.0 is borderline for about any 939 chip (look at the FX-60 for example, lots dont even get 3.0 stable).
I know some will hate me for what Im about to say but here it goes... You should be looking for an optimum between added Mhz and Vcore, not set a predefined goal that you want to reach. 2.9 at 1.4v is a real killer OC that is gonna give you more good than to force those last 100Mhz that you will only notice in benches and drives your temperatures and power bill up while decreasing the lifespan.
Nugz have you tried Big Toe's bios? Could be as simple as a quirk with that bios and your gear. Don't know if you use speed fan or not but it has a rough little graph you could wath while running orthos to see if your getting voltage droop.Quote:
I use a DMM to check the volts, and the PSU is adjustable, so it's set at 12.145v then in use it drops to 12.138v. 3.3v is set at 3.345v and drops to 3.33v in use. The 5v rail is set to 5.05v and drops to 5.04v in use.
I'v been prime'n for about 4 hours at 323 x9 "2906mhz" 1.45v in Bios, CPU-z says 1.40v, 1.44v real DMM checked during use. Seems all fine here. Mem at 166 = 264 3-4-3-7 2.6v . 7/4 Data Drive blah 1.3v LDT 1.70v NB MBM CPU temps says 42c Core temp says 46c Core#0 52c Core#1.
I can run my FX-55 under phase @ 3300mhz 1.50v in bios 1.49v real, -40c for hours prime stable with these PSU's. Guess a FX single core is different than a 165 Dual core. hehe.
I'll try Big Toe's Bios, But DFI/ that one guy, just takes Big Toe's stuff and adds it into the latest Bios so, I don't know if it would help any. But worth a shot.
Peace, Nugz
Might want to try Tmods bios cd over at Dfi street. It's an iso you can burn that has every bios you could think of for dfi boards. It even flashes in dos so less worries about a bad flash. You should check it out. :thumbsup:
This soon will be my new PSU.... :D
http://www.thelab.gr/attachment.php?s=&postid=435244
Just look what i get on Heavy load @ 1.51 VCore......:mad:
http://img98.imageshack.us/img98/1094/untitledky6.jpg
Ps.... OCZ 600W Powerstream
