This is it and nothing more enjoy I searched hard for this
Originally Posted by esdee
bought them today, tested for 2 hours. What do you guys think?
data on the IC's are
TWINMOS
04514
TMD7608F8Ε50D
The third pic shows that the 166multi works just fine!
will post a pic of the Chips later (now they burn in hell... eeeer my PC)
My setup is
Winch 3500+
MSI Neo2
Twinmos DDR3200 rated cl 2.5 (LOL)
OK So far these are the things we have to look for for those chips!
DIMMS Found With UTT
(*) Twinmos SpeedPremium (04464 production week,a 4 at the end help too)
(*) Twinmos\Twinmos Twinmos\Mtec chips (cheap ones) (04514 ,same as above)
Make sure if you can take a look at the chips of the RAM that there are
(*) Two Dots marking
(*) Metal Dots (two in each side!)
(*) AA4T (not AADT)
(*) week 0xxx4 (the ending 4 is winbond chips)
AND THE OFFICIAL TWINMOS CHIP/RAM GUIDE!
http://www.xtremesystems.org/forums/...504#post774504
Ok I have the same Data as my man here, nice info by the way, short simple accurate, but it just doesnt get better then this. These Twinmos TMII400/1GB and any other with the chipset specified above are like a bicep the more u work it the bigger and stronger its gonna get. I have AA4T=CH-5=UTT, when i got them i couldnt get passed 200 FSB SPD Timings, now after burning them in 250 FSB 2-2-2-5 3.3 voltage (no mods). There is a process for this that I will specify shortly and needs some attention and patience.
1. Set memory voltage to 3.3V
2. Set FSB to something high but not too high, e.g. 230 FSB
3. Run memtest86 and loop "test 5" for a few hours
If you get no errors at your this speed, increase FSB, all the way until you start getting errors. When you do, continue to loop "test 5" for hours, the errors will decrease or will be less frequent, soon enough they will magically disappear all together. When this happens, increase the FSB and try again.
4. About the errors... a few is ok, but not a thousands. You want the ram to be forced all the time, and too many errors, the program goes into subroutines to log them instead of jogging the ram. So a "few errors"...10-20-50-100 is ok, not not K's. I liked 10-20 max PER LOOP of the test. The thing is, when errors are found it takes a break to record the tally, so the less errors u get the better.
5. The idea of keeping the error rate low is that the program will take time away from hammering the ram to "tally" the error, and the idea is to hit the ram as hard as possible, so try to target the FSB at the point where errors start but not so high that ALOT of errors occur (as this would take away from the overall effect we are trying to acheive...(beating the ram senseless).
6. For burn in its not required to set it to the highest voltage possible. Instead, and this is confirmed by OCZ, set the Vdimm to 3.2-3.3V and run it in memtest at as high an FSB as it will run without getting more than a few errors on a pass. Now at that FSB point, give it 24-72 HOURS of burnin, keeping the ram cooled with a fan blowing on it. Hopefully the ram will "improve" over time and the errors will reduce/disappear. Try increasing the FSB a couple Mhz every say 4-6 hours, and continue burning.
This info Was supplied by Marcus d that did an outstanding job getting this info.
I will add one more thing, my process was different I used all tests and never got errors on 5, just on 8 and seven, I think it my be different for every one, pay attention to the first pass so that when u see the amount of errors write it down and compare it to the number of errors u got on the other passes, and ull see how the start decreasing.My first pass had 177 errors, second 143, third 90, fourth 10, fifth none :D.So try it and see if it works for u. Ill post pics later so that u can see my results. :toast:
If ur thinking why I havent pushed them more, ive just been plain lazy, i just got World of Warcraft and im hooked, ill try higher and post my results when wow fever dies out
_________________
Lanparty NFII Ultra B
Antec True550w Psu
Amd XP-M 2400+ @ 2500mhz FSB 250x10 1.85v
2x512 TMII400/1GB (AA4T) Bought at new egg a month ago.
Air cooling Thermal Right SLK-947U with Delta 92mm fan, Arctic Silver 5 Thermal compound 38/35 idle 40/37 Worked.
