SATA Management with Extreme
Gents,
I've finally been at home enough to finish putting my new rig together--no RMAs thank goodness! Before I start pushing the system and taking advantage of the rest of this thread, I'm trying to set up the basics.
I'm having a tough time understanding the SATA management in BIOS on this board. I'm pretty solid on most other system basics, but my previous experience with multiple SATA headers was limited to a 4 channel add on card on my last rig.
My goal is as follows--
Using BIOS settings, shift between two SATA setups (all drives mentioned below are SATA):
Setup #1
Drive #1 w/ OS#1;
SATA Optical Drive
Setup #2
Drive #2 with OS#2 with an additional storage drive (drive #3, accessible to OS/drive #2)
SATA Optical Drive same drive as Setup #1
I think that there is a way that I should be able to use the ex-58's ports and bios settings to be able to switch between these two setups, but I haven't gotten my arms around it yet. Should I be setting up one OS on the ICH10 and the other on one of the Gigabyte ports? How can I get either ICH10 or the Gigabyte/JMicron to do separate drive-based volumes? How would you guys approach achieving this setup?
Thanks for helping out this SATA novice.... :shrug:
Matt
