here you go :toast:Quote:
Originally Posted by Reefa_Madness
about the price , m.tec 1gig about $50 cheaper than SP :rolleyes:
i think you can get it in US more cheaper..
hmmm the hard part is : what should i do with my SP then? :hehe:
can someone please tell me where I can buy Mtec.
i think its not important which one you should get (m tec or twinmos relabeled chip), since they are both "value" line from twinmos.. the important think imo is week of production.. but again it may vary alot (but at least they (512x2)can do 250 2-2-2-x 1T with cheap price)
if you can hit >250, i think it would be a bonus from twinmos :p:
newegg has the speed premiums back in stock, 73 in stock right now. About time they ordered a bunch
just when demand might be slowing down.
Problem in the states is a fair amount of the value line is the sheep stuff (baa-a-a-a-a-a-a-d), not the AA4T :(
Egg has been ordering that much, that were just going really fast ;)
Originally Posted by setyotomo
ooh ok,I thought you said Mtec was cheaper then UTT.
on another note,who here uses A64 memtweaker? by goddhor,I'd like to know if the 183 ram option is legit or 3MHZ too high...thanks :)
hmm.. any ideas the kind of speed u could hit with only 3.1 volts? haerd a few ppl saying there may be probs with the stability of the ultra-d DFI boards when u switch over to the 4v max ram volts.. wondering what i might hit if i stuck to the 3.1v max :/
Wo0t! Fixed my 3.3V issue and now I'm flyin at 260 2-2-2-8 prime/memtest stable @3.45
But I'm only gettin 4000 bandwidth my BH5s would of killed this score...I must be doing something wrong :(
Thanks.Quote:
Still waiting for my PC3500 Speed Premium, picked them up at komplett for $155
100308282 2,00 STK 390,00 780,00
TwinMOS PC3500 DDR-DIMM 512MB BH-5
:D :banana:
jolle where ???
I think he meansQuote:
Originally Posted by TEDY
this place.
And what do you think of these?
More good UTT or really more BH5 like overclockers.de says?
http://img8.exs.cx/img8/7060/maybebh55we.gif
probably just made with the windbond bh-5 die..
I don't get it
1*512 works flawlessly 265 at 3.6v
2*512 errors memtest #5 why ???
weird errors at 0.0MB/0.1MB/0.3MB ???
that means mem controllerQuote:
damn it :(
so much about CBBHD... :(
So time to sell them ???? I really want some 1:1 300+ capable ram with 2*512.
The problem isn't the RAM, it's the cpu memory controller. :)Quote:
maybe should raise vcore a little for 265*9 i had around 1.3-1.325...maybe bump to 1.4v ?
can't be memory controller cause before TWINMOS i had KHX3200/256*2 BH-5 which i ran them ok 270 at 3.7v!
Maybe it can't handle the 1Gb.Quote:
I had the same type errors in my NF7-S, 0.1, 0.3, 0.4, etc when I'd do dual channel above 235 fsb. It can do single channel up to about 250, so that is the on board memory controller then? Any way to beef it up? Chipset and memory voltage seems to make no difference. :(
@ dutchman.pt , if they say PN code ends 1A4T... then it's BH-5 UTT. :)
@ TEDY , venice! ;)
@ cartmanea , how much vdimm are u giving them on DC and with what timmings?
enok just bought damn CBBHD...costed me 190$ :(
:( u deserved that tictac's slap smilie!!
