bios for asus s96s laptops... im searching all their old bios updates *from other sites not asus* looking for the holy grail. what i was interested in was the afudos version...
How about "Rampage streamline" or "Maximus Bigbios" or one thats been done i think is "Max rampage" or another is "rampage little chip"
does the es on afudos versions mean "engineering sample" as in unlocked switches?
Stilt, does afudos 2.11 has the Afudos /ixxxx.rom /pbnc /n option?? i think i found 1 but havent got time to try out yet.
http://forums.mydigitallife.info/sho...11&postcount=2
Tried both the afudos versions from ZenEffect and can confirm there ES allright !!
They support the switches we need to do this.
But it doesn't work.
i get .. (command: afudos /iloader.rom /n)
Reading file ....... done
Reading bios ....... done
Advance Check ..............
_
And thats it doesn't do anything more so i think they either don't support these bios file's or the chip it needs to be flashed in.
For the record i am willing to test if this works on my P5E :)
smokey can u try the afudos 2.11.... in the link i given it says it support the option that is needed...
Hi, just a question
I've got the BISO 907 now and my Vista is in an array of 4 Raptor in Raid0.
If I update the BIOS does it will break my RAID?
Thanks for the answer
you have to set RAID again in BIOS after updating. But that's all.
i believe i may have found the mother load.
everyone look here:
http://www.rebelshavenforum.com/sis-...ubb=forum;f=52
http://forums.mydigitallife.info/showthread.php?t=529
a collection of tools:
http://www.lejabeach.com/sisubb/tool_8_RC1.rar
also would this work??;
http://www.coreboot.org/Welcome_to_coreboot
Seeing as no 1 will comment on bios 217 I can assume its no better?
Forget it, thought you meant afudos. Bios 217? Where is it?
by the time i afudos that is an engineering version, i will be able to read chinese :p:
on the asus website i think it shows the board will be released with 0215 so i think 0214 beta is all we will get untill release and etailers are showing expected stock on the 28th
I might have a newer version tomorrow.
