My XMS-PC3200C2 Rev1.1 are CH-5 not BH-6 like listed. Maybe this should be updated... :)
Ur sure? Never seen old CH5 who did 200Mhz 2.0-2-2-5 2,6V even not up to 280 2.0-2-2-5. ;)
http://www.xtremesystems.org/forums/...03&postcount=1
Edit: Ok sry, maybe u mean that there are two versions.. i forgot that. :)
One with CH5, one with BH6.
Yes that's what I mean. I purchased a pair thinking I was getting a deal because they were listed in this thread as bh-6 but once they arrived and didn't OC anything like bh-5/6 I knew something was up. So I took off the heatspreader only to find this! :mad: Also killed that stick in the process of taking the h/s off. LOL note the chunks taken out of the PCB. :p: I guess I took one for the team on this one, no worries though these ch-5 chips aren't worth the PCB they're made on. :)Quote:
Originally Posted by GravediggA
:DQuote:
Originally Posted by TheMeatFrog
U was a bit rough tbh.. But good to know, that there are 3200C2 with CH5 too, never seen some before. :)
Indeed I was :p: I read some place else that Corsair mem are notorious for dying while removing the h/s since they are VERY hard to remove. It was worth it I guess to find out what IC it was. ;)Quote:
BTW here is a picture of the sticker so maybe this can help some other people avoid making the same mistake I did. :)
http://img52.imageshack.us/img52/3585/img14113jl.th.jpg
probably because your sticks were recent 0338Quote:
Sometimes you'll find CH5 where BH5/6 should be and vice versa
I had a pair of XMS3200LL v1.2 which turned out to be BH5 instead of CH5
Added GeIL ONE TCCD (ES).
That's because the list is plain WRONG for Corsair memory. ICs can and will change within the same part # / revision #. The LOT # is needed to successfully identify the IC.Quote:
Originally Posted by ArcTan
There's already a huge list here: Corsair's IC Inquiry Thread
No need to remove the heat spreaders (thus voiding the warranty) on Corsair memory when you can find out the IC by asking Corsair directly.
Very nice list. Helps tons!!
No problemo.
anyone have some info about these here?
Corsair Twinx1024 3200C2PRO (2x512)
XMS3202 v4.3
0518032-3
thanks
Follos ReelMonza's link, go to the Enthusiast's Corner, post in the IC Inquiry thread stickied at the top.
That lot # looks familiar though, did you already post there?
yes, i posted there... it's the last post :D
but no answer so far
Check my memories...
http://www.thelab.gr/showthread.php?...1084#post21084
Transcend Value Ram DDR333 (spd : 2.5-3-3-7)
with Winbond BH-6.
They are missing from the list and little know about them.
Bought them in Greece 2 years ago.
My ram seemed to be missing so I'm filling in what I found:
2x 1GB OCZ PC4000 Platinum edition Enhanced Bandwidth, Extended voltage protection, Ultra low noise.
It runs at 3-3-2-8 with Infineon HYB2D512800CE-6 on Brain Power PCB.
Infineon says: HYB25D512800CE-6 / 512Mb,64Mx8, DDR333 2.5-3-3 / PG-TSOPII-66
So it seems to be only 333MHz chips that can do 500MHz.
Here's a nice review: http://www.overclockersonline.com/in...num=321&pnum=0
And here http://www.xtremesystems.org/forums/...ad.php?t=82975 a funny story hehehehehe.Quote:
Originally Posted by tijgert
Thanks btw! :D
Dudes what chips do adata and geil value crap have?? :p:
sry not 4 me i buy bh 5 two twinmos memory sticks next week :clap:
Anyone any idea what chips lie within LPT ram??
I have two sticks of it one pc3200 and one pc4000,
No system to test in ATM but Im looking for specs on them.
Google throws this back whick is of no use to me at all!!!
http://www.it.com.cn/f/diy/046/30/7038.htm
hi guys
I am new at this forum and i have a question:
which 2gb kit should i buy?
or which chips are on 2gb kits like CORSAIR TWINX2048-3200C2??
thx
ps: :slapass: bad english sry I'm swiss
hi and welcome! :)Quote:
Originally Posted by SWISSCLOCKER
imho the best 2gb kit would be OCZ platinum EB pc4000.
as for Corsair, it depends on revision: v1.x is Infineon based, v2.x in Nanya.
whoops, i meant OCZ platinum EB pc4000 2gb kit. linkQuote:
Originally Posted by Wired-HoH
:slap:
thanks for the heads up wired. :up:
high5:
No problemo.
Swiss: Do you want to overclock at all?
btw Wired, do you know could we expect Corsair to release XMS 3500LL 2GB in a non-Pro edition, w/o those leds?
What chips are used on the Geil Ultra-X nForce4 Edition
http://www.geilusa.com/newsdetail.asp?linenumber=61
(I got a reply that they use the "elpida" chips:confused: :confused: )
Would this ram be any good on a DFI nF4 Ultra-D mobo?
(my CH-5 ram is on the road to oblivion:slapass: :slapass:)
I have a corsair XMS3200C2PT and likely have a SAMSUNG TCCD 516
anyone know about the limits of this RAM?
please don't double post.Quote:
Originally Posted by BiKEKiNG
http://www.houseofhelp.com/v3/showthread.php?t=44365
More likely TCCX.
hm... yes:DQuote:
i think thats a really nice kit, but it is a bit high pricedQuote:
what about this:
http://www.ocztechnology.com/product...annel_platinum
Just keep in mind that 3200s aren't guaranteed by anyone to do higher than that speed (albeit most will by a little at least), hence why higher speeds are recommended.
FYI, the Corsair equivalent of that memory is the 3200XL series.
atm I have the corsair twinx 3200xl pro, but i need 2x 1gb :)Quote:
can i clock them -> http://www.ocztechnology.com/product...annel_platinum up to DDR500 with high latencies and higher voltage?! impossible?
Maybe. Basically, they rate them @ 400 Mhz. 25% OC may be possible, and everyone can guess what they may do based on ICs, PCBs, etc, but ultimately the best answer is a "maybe".
Finally I am going to try my GeIL Ultra-X TCCD on my new MSI Neo2 Platinum, but ARGH... I already have a problem before mounting it:
http://www.xtremesystems.org/forums/...ewpost&t=84599
:censored: :dammit: :help:
Motherboard also works without I/O shield :banana:;)
hm but DDR450 with Cl 2-3-3-6 should be possible?
(with the OCZ platinum kit, 2x 1GB, DDR400, Cl 2-3-2-5)
Can anyone list a few of the top 2gb kit clockers? I may be making the move to 2gb soon, and wanted to know which I should be looking at... of course, I go for the better bang for my buck, but still would like to know what comparisons to make. :)
It seems to really be a case of pure luck finding a good pair of 2 X 1 gb overclockers :(
With the UUUC chips there seems to be seriously 3D stability problems on later chip batches which I, and others, and experiencuing with Mushkin Redline XP4000 > http://www.xtremesystems.org/forums/....php?p=1218163
Haven't really looked into other brands yet...but if they use the same chips, the same issue is there...but gskill and corsair comes to mind...
This review mentions same issues> http://www.3dxtreme.net/index.php?id=oczebpc4000p4
I still don't know if it's worth going to a 2gb kit.
Does it help that much with a dual-core??
I just got a set of the OCZ pc4000 xtc and right now they are running 275 with 3-4-4-8 timings and 2.6v.
I think you may be getting your IC's confused, I know I certainly have before. Both links you provide and the associated 3D stability problems refer to RAM based on newer batches of Infineon CE-6 based parts, e.g., OCZ EB PC4000, Mushkin XP4000 Redlines which do not overclock nearly as well as previous Infineon CE-5. Samsung UCCC based RAM is giving the higher overclocks right now but at the price of looser memory timings than what the Infineon parts will do at 250MHz. Hope that helps, so anyone contemplating the OCZ EB's or Redlines should not expect to see the same results as folks that bought theirs a month or more ago. BTW, the UCCC 2GB kits cost about $100 USD less than the Infineon 2GB kits. Right now I am really digging my $200 AMR Mushkin 2GB XP4000 non-Redline UCCC @ 275 MHz 3-4-4-8Quote:
Originally Posted by -.-PhanTom-.-
Originally Posted by thinkingbear
Ahh thnx for clearing that up, mate! ;)
I guess in my frustration I didn't pay enough attention to detail....easy to get frustrated when you have paid top dollar for what you thought was a premium product and then it only goes a little over spec :(
a new add for the list
Twinmos Speed premium PC3500
ending code 1ACMT
Chips Hynix D-43
EL DDR PC3200 Gold --chip--> Winbond New BH5 ~ Brainpower PCB
you can add OCZ ref (OCZ4001024ELDCGE-K)
are you sure about that?Quote:
Originally Posted by 200%absolut
one member recently reported he got that ACMT and ICs were marked PSC which is Powerchip.
i have one stick in hand and it's hynix chip. Do you have more information about this ICs?
I receive this stick from twinmos RMA last week.
EDIT: after a quick search i've perhaps find the chips you are talking about :
Twinmos Twinmos Ram /w Sticker ending: CADT PowerChip
http://www.techpowerup.com/memdb/
could you take a look at ICs on your TwinMOS and write down the entire label?
Twinmos
05036M
TMD7608F8E44F
thanks.
i did search the forums a bit and now it seems i misunderstood the other member with ACMT TwinMOS. it seems his ICs aren't PSC labeled, but rather that his retailer told his they were PSC:
http://www.xtremesystems.org/forums/...ad.php?t=85046
http://www.xtremesystems.org/forums/...49229&page=127
(starting from post #3170)
200%absolut, did you try OCing that TwinMOS of yours? 250MHz should be easy for Hynix.
i haven't tested it (P4P800Vm 2.65V max :( )
But if it the same chips as ADATA DDR500 250 will of course be easy
So we can update the list :D
I thought that Hynix didn't really like much above 2.7v anyways... at least the D43s (both a 512 kit and a 1gig kit) and D50s I've had never liked much voltage... I think my 1gig kit worked well with 2.7v, and my 512mb kit worked well with 2.7-2.8v, but those were Kingston value, and Buffalo PC4200.Quote:
Do any of you know what chips the XMS3200C2 v. 5.2 possesses? I've got a pair of those (which are going back to where I brought them), the test run I did got them up to 230MHz 2-3-2-5 1T, which was quite nice for what I paid for them.
But the chips remain the question, I'm just a bit curious.
what was the Vdimm ? Have you try 2/2/2/5 ?
ProMOS.Quote:
Originally Posted by Mean Machine
Never heard of it... I'll do some googling, I think. But thanks for the answer.Quote:
Originally Posted by high5
I got a 1GB kits from Kingston and it is a KHX 3200AK2 which supposed to be CH 5 chips...infact i found out that it is CE 5(from infineon) week 46 05.... :(
i personally know some people who OCed that v5.2 Corsair upto 240-250MHz, so its not as bad as it sounds... :p:Quote:
Correction on...
"EL DDR PC3700 Platinum Edition (2-3-3-8) --chip--> Samsung TCC5 (new production) ~ Brainpower PCB"
I just took a peak under my spreader and it's definitely "TCCD"! Not to say that they are all TCCD, as I wouldn't know, but mine is for sure TCCD.
Mine: OCZ DDR EL PC3700 Platinum Edition (2-3-3-8) --chip--> Samsung TCCD
lucky u,Quote:
Originally Posted by g0dM@n
i did also take a peek and i found infineon i/c in my kits....damn!! i'm burning them at 3.41v right now....:banana:
What kits? The same ones I have? I thought they were all Samsung TCC5 (and also TCCD now that I verified).
What infineon chips are they, and how do they perform? 3.41v?!
CE-5 and it is rubbish....3.41 only stabilize around 235mhz with 2.5-3-2-5,Quote:
i was hopping getting a CH's but finally opened up the HS only to find an Infineon chip is inside...
