Originally Posted by
-Boris-
First, the Llano specs seen in this thread are pure speculation. But let's pretend they are real. Then you still have different TDP ranges. And I'm sure that a Llano part at 2.6GHz will be a lot "hotter" than a 1.6GHz Zacate. You have much larger cores originating from chips developed with servers in mind against a very small chip made to be extremely efficient in perf/w. Even if Llano is power optimized it simply can't be cooler than Zacate.
Even if there were a Llano at 20W TDP, it's still just TDP. Chips made at the same TDP can have significant differences in power consumption. The TDP-ranges are simply not in a resolution high enough for such comparisons.
In an poor attempt to explain let's pull some numbers out of my arse here.
18W TDP Zacate could mean 10W theoretical max, 7W real world max, 3w typical and 1w idle. A 20W Llano could mean 20W theoretical max, 15w real world max, 11w typical and 8w idle.
These numbers are of course pure fantasy, but my point is that TDP-ranges could mislead, one watt in theoretical max is enough to be put in a range with twice as high TDP number. And TDP don't show how efficient energy saving there is. A Zacate will probably have much better idle and low usage powers than Llano due to the very different bases for their design.
And then again, even if a normal Llano at 45-65w probably could be reasonably priced around 150-200usd for notebooks, a 20w ULV would be rare and thus priced a lot higher. At the same time Zacate and Ontario will be so cheap to produce that AMDs people could wipe their behinds with them if they had skin thick enough.
So, even IF a 2.6GHz Llano with 20W TDP existed. It would be much more expensive since the chips good enough would be rare, and it would probably use a considerable amount more power than a Zacate in real world, especially in idle and normal use.
