Is there a Thuban 1055T in here somewhere? It was interesting for awhile.
No offense.
No offense.
But without a 6-core Nehalem not running HT to compare, how can you be sure the performance variations are not simply due to the software? And given that HT in general only benefits between 10-25% in well multi-threaded applications; whose to say it won't be Thuban that suffers more in real world desktop applications which in general aren't that well multi-threaded.
But they are.
A product with the same performance and lower efficiency has higher heat output.
We never said it disappeared. we said it is lost as heat (i.e. transformed from electrical energy to heat energy)
We have 980X which is 6-core.
But it's also at a way higher price point. And that's what's appealing about Thuban.
Yes, HT is less efficient than actually having more cores.
Saying that more cores or HT won't benefit single threaded programs is just stating the obvious. People won't be buying 6 core CPU's expecting higher single threaded performance.
In programs that are well threaded, Thuban can close the gap or beat 4 core i7. In single threaded programs, Phenom II was already close enough anyway (except for things like SuperPi)
Seriously why is there so much Intel talk here?
A 6-core Nehalem would totally break Thubans back even if its not running HT, that comparison is well brutal :D
As of now it seems that Thuban is a equal or bit better than a equally clocked bloomfield with HT on.
As per a measure of scale i think that AMD needs 1.5 cores for 1 of Intel's and if we use this scale you will notice that in Turbo mode AMD has 3 cores at 3.3Ghz that means it can rival 2 nehalem class cores.
But the weak point for AMD's Thuban is single thread execution i expect it to lag behind bloomfields in app's that use just a single thread. Lets hope AMD's turbo mode does good enough for a single core at 3.6Ghz beating a nehalem class single core at 3Ghz "1090T vs i7 930"
Thubans strongest point is three thread execution...
no... a high leakage chips loses current.... so it needs more volt to stabilise it ... so it gets it hotter... lower leakage = less heat because they need less voltage to stabilise thus running cooler .....
high leakage or low leakage dont matter when you use LN2 or LHE
http://en.wikipedia.org/wiki/Superconductivity low leakage or high leakage wont matter ..... they all have the same resistance ... well if you reach that extreme cold point from what i could understand ....
so fermi should dissipate less heat???? its an extreme high leakage chip.....
btw this doesnt compute.....
maybe they want to steal amd's 15min of fame for the week....
Shame this thread has lost its way, enough has been said now should really just move on :up:
@ajaidev I agree with what you're saying, when the Core i3 2C/4T vs. Athlon II X3 benchmarks showed up it was clear 4C/8T i7 would be matched by Phenom II X6 :)
For some friend I need a test with mental ray or a 3dmax v-ray bench.
Okay folks
Back from work and trying to hit 4GHz
4GHz done
4.2GHz is the current max ( managed to run wPrime 32M and SuperPI 1M)
I guess it's good enough for today :)
I will get the screencap up ASAP, sorry for waiting
P.S. : for other poster asking me to run different bench / chess game with the rig
Please reply after this post
4.2 is very nice, how much Vcore for that? And how does CPU-NB overclock? We've seen Mad222 pushing the CPU-NB to 3150MHz, is yours as good?
No need to apologize, i'm sure everybody will understand you have to go to work, like me and most members here. ;)
imamage: Cinebench 4 GHz please :) and maybe some test stability (LINX or prime???)
Thanks imamage seems 4Ghz air should be achievable by most since 4.2Ghz is max stable :D
This is indeed good news waiting for the screen's F5 getting pressed evey few secs :P
Eagerly waiting for ur benchmark screenshot:)
2.6ghz 12 opteron cores = 7.95
4.2ghz thunban cores =7.38
difference 0.57 speed does make up for less cores now lol
I didn't have much time
Only did these test
4GHz Fritz
http://www.hkepc.com/forum/attachmen...f0bb59e663.jpg
4GHz wPRIME 32M
http://www.hkepc.com/forum/attachmen...f6a605926b.jpg
4.22GHz SuperPI 1M
http://www.hkepc.com/forum/attachmen...0686a3162a.jpg
http://valid.canardpc.com/show_oc.php?id=1134111
4.22GHz CPU-Z Validated
I lost one screencap with 4.2GHz wPrime 32M
The VCore is 1.58V
This CPU surely can replaced my 955BE in my rig :)
Up the on chip north bridge, wonder how much it would help in cinebench?
uffff, nicw winrar bench
http://img140.imageshack.us/img140/9548/winrar3593.jpg
Yes, waiting for that NB to be pushed higher ;)
Thats sad to hear.However all will be lost when you will try with k10stat with both turbo ON and OFF in the bios.Thx for info!Quote:
I have tried , Max out Ratio in BIOS is x14 , I can't choose X16.5
Haven't try K10Stat / AMD OverDrive yet
