Use BIOS older than 1.80, then it works fine...
1.80 and 1.80A are not that good...
1.53 best so far...
1.53 best so far...
Which BIOS do you recommend for Thuban?
I dont have any thuban yet... But try 1.53 or 1.51... Best so far..
New to these forums, however I did just order a FraggleRock 880G Extreme 3, to replace my BIOSTAR TA890GXE, which is being RMA'ed.
I decided after sifting through numerous boards to finally give one a try, hopefully everything works out...
Ill be happy just getting at least 3.6ghz out of my 1055T on air with it ;)
@Cele
FX version should be in Croatia in 2 weeks..
i also have this awesome board with 1055T, and this is my current max OC-ed results
http://img.photobucket.com/albums/v2...5/ASRockOC.jpg
New 1.95 beta bios
890GXE195.zip
fixes the sideport problem
Thanks...
Hope it Fix the RAM problems (first slots dont respond and many vendors do not work since 1.80).
Nope mate first slots are crap (on most boards anyway) stuck there around 1780mhz, white ones do 1820mhz dead easy...
Is this mobo worth trying? How does it manage to keep the set VCore under load... aka how much VDROOP under load does this board have?
1.95 -> Fix the RAM problem, now all RAM work in first blue slots...
This mobo is really great mate, for the vcore it depends per CPU... the Thuban slightly overvolts here when loaded, other Phenoms have got about 0.06 droop/drop eg I set 1.35 in the bios it will be around 1.29 under load on my sample board... but the power circuitry is really good as it kept going at 1.9Vcore set for more than 4 hours in a row under LN2...
Ofcourse if you are looking for max ram performance there's only one option : the FX
I am still using bios 1.0 and got nice results with my X2 555. Not sure if i should upgrade the bios and fix what ain't broken.
I got my 880G in and my wiring finally done for the moment, I need to mess around with it and get oc'ing some when I have time.
Oh and by god is the stock fan that comes with the 1055T annoying as all hell, I need a new cooler asap :ROTF:
Try BIOS 1.20...
Its based on BIOS 1.00, not on 1.19,
you could have unlock X4 stable.
With BIOS 1.00 non of my 555 and 550 could stable unlock,
first stable unlock was with 1.19 and 1.20.
Bios Database:
http://www.pctreiber.net/forum/index...c,13303.0.html
So if this overvolts with Thuban, that's fking awsum ^^ Just the way I want it.Quote:
Originally Posted by Leeghoofd;4389276 begin_of_the_skype_highlighting:banana::banana::ba nana::banana::banana::banana::banana::banana::bana na::banana::banana::banana::banana::banana:4389276 :banana::banana::banana::banana::banana::banana:en d_of_the_skype_highlighting
Now I'm thinking of "Asrock 890FX Deluxe3", it's not expensive either... 132€.
I also have one 555 which goes ~4050MHz 1.4875V when unlocked. So it's interesting to see if it can be pushed further with 890gx/fx, now it's having a party with 785G.
have tried bios 1.2 but random BSOD although only using firefox, updated to 1.8 got random freeze, end up flashed to 1.53 without any problems...quite stable in my opinion...
I got the same problems and RAM stability...
Use 1.95, works like a charm...
1.53 too.
1.80 and and 1.80A are bad.
Didnt try 1.71 and 1.73, because i got 1.95 before them...
All ASRock BIOS-es at one place:
