looks great! will there be one in the top of the case above the graphics cards too?
All you would need to change the colour is a cheap lighting gel (the gels they use to change the colour of stage lighting in theatres). Cut to fit, and attach to the light box. Project done.
You can even get those gels in many different colours, and for dirt cheap.
Love it. The light module is lovely. You take great pictures too :up:
BRILLIANT (No pun intended....ok...maybe a little :D ) Idea!!! :up::up:
I love it when someone finds something new and different, showing us that there is no end to the creativity to be found with modding!
Inspiring photos Charles. It's great to see that another one of your ideas developed into something fabulous. I'm just wondering what's next up your sleeve.
:up:
Excellent work!
Wow.
I’m truly overwhelmed with your comments and support guys; thank you sincerely!
Your words of encouragement motivate me immensely. We’ve got stuff we’re working on that we can’t wait to reveal. I’ve learned my lesson about premature announcements so for now I’m going to keep my yap shut, my nose down and just keep plugging away. :yepp:
This is an amazing Community with so many talented people and such a positive vibe. Huge thanks to all of those who work behind the scenes to make this place possible!
http://www.murderbox.com/uploads/DSC_6498gg.jpg
:toast:
Zen frog!, and yeah, that's looking incredible, cant wait to see the next suprise
Wow, great idea Charles, your inspiration inspires me! :D
Can't wait to see what the next "twist" is...
I love murder Mod TJ07!
I've to congratulate the creators by the great work that you can do with the sleeving! Congratulations!
Now, I'm waiting by other mods with other cases :up:
The background is simply stunning. Hats off to you for such impressive designs!
Wow that mod looks wicked sick...
Im just speechless. I used to despise the TJ-07 case but this thread has just totally convinced me to buy one. Just a shame i dont have the skills or tools to do similar sort of work with such attention to detail.
Charles. You are very talented and I believe there is no one to oppose that. I really like the extra time you put in every detail and your work has inspired me a lot in my build. Check it out if you want:
http://www.xtremesystems.org/forums/...d.php?t=206381
It really strikes me that you are using very similar methods as I when building, measuring and cutting. Also I can see all those things that are so unique for aluminum. When you first post a project like this many people might think that installing 3 pleds like this is a jiffy, just cut three holes and mount the displays, right? Not really, measuring and getting everything lined up perfectly might take hours. Although you've got acces to a water jet things might not be as easy as it looks. What really impresses me is the accuracy of everything. All the mounting holes and the depth of the counter-sink. For me, drilling a hole is a three-step procedure. Take a 4mm hole as an example. First I take a very sharp "cone-drill" and make the first alignment of the hole, Then I drill the hole with a small drill, like 2-2.5mm, then finally I take the 4mm drill and enlarge the hole. This is to avoid the drill-"sliding" as much as possible.
What surpriced me though is that you didn't mask the surface when using your jigsaw. You managed to get those typical scratches created by it. Although they aren't deep, I personally can't stand the look of them whilst working on the panel, so now I always mask the panel of before doing such work (leaving the marking on the panel unmasked though, I see you found out that you get a lot better precision by marking directly on the panel rather than marking on masking tape).
Take care man, love your work!
Wow Aluchill that is a sick build, thanks for bringing that to my attention.
master case modder + master photographer :P
Amazing! I just hope it doesn't fall of that ledge.
Cheers DragoonXX!
We've got lots of stuff on the horizon. Now we just need more hours in the day. :)
Cheers twwen2. :)
I'm really anxious to showcase how it looks loaded with internals!
Thank you norim_13!
Hopefully the wait won't be too long. I can say that new designs are a high priority. :)
Cheers Eddie3dfx!
Thank you Blacky!
I must say that when I first saw your post, I thought your sig was intended for me. errr... it isn't is it? :)
Thank you Scubar!
I built the first murderbox on my living room floor with very limited tools. Obviously a lot has changed since then but I'm a firm believer that where there is a will, there's a way. :)
Cheers NysoO!
I'm a massive fan of your work and have been deeply inspired by your recent project. Thank you for taking the time to make such nice comments - I really appreciate that. :)
I'm wondering if maybe those "scratches" you're seeing are possibly the lines caused by the bending brake when the angle was formed. They're very noticeable in the bare aluminum but won't be an issue after powder coating. I can tell you that all the surfaces were properly prepared so as to achieve a perfect finish after powder coating. After all and as I'm sure you'll agree, it's all about perfection. :yepp:
Thank you lkiller123!
Cheers hotwaxisbad. :)
It's funny you should say that... it was indeed a concern - luckily there was no wind!
Thank you Rocky!
Project Update: Nothing exciting to report I'm afraid - parts are at the Powder Coater... cables are being sleeved... It's small detail time before the big assembly. Making sure all the little bits that can hold up a build are on hand. The finish line is starting to draw into view. I will say that there will hopefully be a little something interesting revealed near the end of the week but that's all I can say for now. Not because I want to tease... but because it's not for sure yet. :)
Thanks for looking in. :toast:
Absolutely amazing photos and design Charles! This look a-bloody-mazing!
Keep up the great work mate! :up:
Charles ... you are my guru :)
I know how you feel with that one, for me, my build keeps getting held up on account of two main things- money and time
dont have the money go get the parts I want (and Im not even going for ultra high end.. a GTX 260) and I dont have the time to just sit down, clear my head and plot/ doodle/ figure out how I'm going to do what
final build is going to look stunning
I do have one question for you (Hoping you might have some experience with them) http://www.mainelectronics.com/heatshrink.htm <---how is their heatshrink? I'm looking into getting some of the adhesive lined, I just would like to know what kind of quality it is (cheaper than ordering from cableorganizer.com, much less shipping cost)
Thanks for the images of the drill bit! Don't worry about a part number, the pictures will do just fine! I'll see if I can't find a similar bit somewhere around here. And might I say that's a pretty spify idea you got there with the sLIGHT twist :D! It all makes sence now!!! Excellent job with it - can't wait to see those final images of the finished case!
P.S. And to think that I thought that "Aboot" was only how us maritimers talked, lol!!!
Mike
Wonderful Photos, and of course beautiful case..:up:
