Alright. Thanks for the info. That helps clear up a bit for me.
Also, could someone explain to me jason4207's use of the molex plug in his mod found HERE.
I think he is using it as a switch to enable/disable the mods, but i am unsure of how it works unless he has the female adapter with cables connecting both the vgpu and vmem to the ground.
And also, where is a good place online that you get your Trimpots from?
