probably a little high, but you can try.
Got it on friday, but haven't had the time to test it yet ...
It is a L740A :( but the number on the little black sticker ends on 915 :bravo:
1.6v!!!!!! That's going to burn it out in a couple months right??
The specs say:
I'm testing mine at 1.36 volts 24/7 but it's probably dangerous. As long as it lasts 2 years, It's good enough for me. In 2 years this baby will be slow as molasses.Code:Max processor input voltage (VID) - 1.360v
I'm confused though, because in my BIOS I have it set @ 1.36v but cpu-z sees it as 1.280v. Can I up it some more in the BIOS till cpu-z says 1.36v or should I go with my settings in the BIOS?
There are reports of 1.5V+ degrading 65nm chips. Not all of them do it, for example yours seems fine, but the equivalent on 45nm would be 1.4V+ (the "Vmax" for 45nm is 1.45V as opposed to the 1.55V of 65nm).
I just don't want to burn a valuable chip.
The L740s can be very nice for air/water despite what hipro has shown with subzero cooling.
Yes on air/water they are doing well.... ;)
is anyone got to 6GHZ with QX9650 ???
Coolaler did it already
QX9650
Coolaler - 6058MHz http://www.hwbot.org/result.do?resultId=688838 (SPi 1M WR btw ;))
k|ngp|n - 6008MHz http://www.hwbot.org/result.do?resultId=698084
No_name - 6114MHz http://www.hwbot.org/result.do?resultId=698353 (SPi 1M) and cpu-z validation at 6247MHz (:eek: - must be the 15th time I use that emoticon to express my feelings about that extreme cpu frequency :D :p:) http://valid.x86-secret.com/show_oc?id=311022
AndreYang - 6038MHz http://www.hwbot.org/result.do?resultId=678438
i'm about to pull the trigger on a L739A746, any speculations on how it'll perform? the seller had his maximus' bios Vcore set to auto and it defaulted at 1.44V at 400x10. what do you guys think? i'm new to yorkies and don't know what to expect.
L740B I had could do 3.8GHz at 1.36v
At 4.0GHz it required 1.44v for 24/7
For 4.4v it needed 1.6v and I didn't go above that because I'm only on water.
that is a bad one, mine that is 40B or A,
On dice I could do 5.5Ghz and on LN2 I could take it to 5.8Ghz
Haven't tested max on water or air, for the extreme cooling I used 1.93v
Waffer is 915
Congraz Hipro :P
Damn... really wished these boxes show the wafer # like on regular chips.
I've got here Q744B101
So far 4630mhz @ 1.62v water cooled .. looks nice :up:
http://img236.imageshack.us/img236/8...7707hd5.th.jpg
My new one is L744B150
Needs 1.38v for 4.0GHz so far, but not so good temps (I need to remount my waterblock again, maybe lap everything).
It's funny, my L740B249 needed 1.44v for 4.0GHz.
Finally got a 9650, 4.8GHz SuperPI stable :)
http://img255.imageshack.us/img255/7...5431or1.th.jpg
