unless you cut a standard hole, then using custom plates, may have to make a plate for each block, but, the botl holes for the pieces and the board tray would be standard.
Something like what newer water blocks have with all the holes , how ever you can swap out a plate on the mobo tray for each different block?
Or did I just way over complicate that?
