Trying to make this PC see another one, just a run of the mill network, and its no go.. what gives?
I had to do a system restore on this one once a couple months back and I know there was bug with it at one point, could that be the problem?
Both boards are nForce 2 boards, so using the onboard NIC. Both give me a limited connectivity error if I dont set their IP's manually (192.168.0.82 for this one, 192.168.0.83 for the other). Enabling/disabling the firewalls doesnt change anything, have tried using TCP/IP v6 over stock TCP/IP and no change, installed and uninstalled ipx/spx on both with no change...
This machine can see the other at this point but cannot access it (file sharing enabled on both, couple folders shared on both), the other machine cannot open "workgroup" (gives permissions denied error or something) and trying \\machinenamehere gives an error. Pinging by IP address gives lost packets.
I dont know why, but I can never get networks going smoothly.. always something :rolleyes: :(
EDIT
WinXP SP2 on both.
