1 Attachment(s)
Planning a (massive) WC (2x 6970, 2x 6870, 4x cpu)
First of all, hello everyone. This is my first post on these forums. However I've been reading quite a bit about water cooling in general and I'd like to think that I have atleast grasped the basics. However I have a few questions regarding my (planned) project.
Radiator
As the topic says, I have been planning to watercool all my computers (with preferable least amount of parts, meaning rads&pumps). Components to be cooled consists of 2x 6970, 2x 6870, T1055, 2x Q6600 and a lone E4300, all with atleast some overclocking. For starters, how big radiator would be required? In my current plans there would easily be room for something like 60x50x(20)cm and it would be semi-actively cooled. I'm obviously thinking a car radiator with copper pipes. But are there any competitors with as good or better price/performance-ratio?
All the computers would be fitted inside a custom made wooden "rack"-cabinet. Here is a very scientific CAD drawing of it:
Attachment 118570
A sideview on the planned housing, fans in front and radiator in back.
There would be fan(s) in front of every shelf. Hopefully this would create a kind of wind tunnel that could be used to cool the necessary computer components and also the radiator. However, would it be a major issue if the air is already somewhat heated when it reaches the radiator? I would think no, because the most of the heat load would be carried by the water. But this is only a guess and I've been wrong before...
Loops
Then the most important part, designing the loops. The main piping is splitted into three loops (the drawing should be quite self explatory). Currently I've planned to use 3/4" piping in between the pump->splitter and splitter->rad->reservoir->pump. The rest would be 1/2". A splitter that contains 3x 1/2" connections and 2x 3/4", this would seem ideal for this purpose in my opinion but... Also I've been thinking if there should be ball valves in each of those three 1/2" connections? Obviously this would be useful feature to have during maintenance but could those valves be of any use in archieving a better overall performance (I'm thinking of balancing the different loops)? Also, should the splitters be positioned in the highest part of the loop? I would think this makes bleeding easier but does it really matter if the splitters are somewhere in the middle and then I just install a pipe/valve on top of the splitter? I'd also think that there is not much point in having a big reservoir unless the pump is submersible (and probably more quiet?).
Pump & budget
So what about the pump? I would be happy if all the parts EXCLUDING the blocks (and connectors)(edit: to be clear. included in the budget: pump, reservoir, radiator, all the piping and all the connectors except those connected to blocks) would be somewhere under 300 euros but obviously cheaper == more desired. The most expensive pumps might be out of the question unless they are really needed to accomplish the designed task.
I think this pretty much sums up my questions and thoughts. Am I on the right track? Anything else I should aware of that if missed in this post?
