Heatkiller 3.0 - installation issue ?
I wonder if everything is ok...
I have single loop , HK 3.0 block , MCP355 and Feser TripleRad + 3xNoctua 1200RPM .
Here's how it looks like, is my inlet/outlet connection ok ???
http://img19.imageshack.us/img19/1566/dsc3082b.th.jpg
http://img709.imageshack.us/img709/2369/dsc3084.th.jpg
Another thing... Have heared that tension with Heatkiller should be 19.8mm however I did found some posts where people say 18.8 :/ So finally.. whats the answer ?? BTW... I use HK backplate...
Now my OC is 4.35GHz @ 1.38v HT on, EIST C1E etc. turned off...
My idle temps stay between 41-45C . During stress (LinX) max temp. is 82C .
Wonder if these temps are ok... I see many people whos idle temps stay around 30C on water.. :/
