P6X58D & i7-980x @ 4.3 GHz - Need help pushing further
4.3GHz Prime95's running fine with 143x30 and 1.336 Vcore, 1.6 QPI/dram (cpu vtt). Trying to push further; I've read that I have a chip from a good batch.
In my BIOS, it doesn't say Vcore anywhere, I've been assuming that is what "CPU Voltage" is. But what's weird, is that even though I've been increasing the CPU Voltage, when I get into Windows, CPU-Z still stays Core Voltage is still the same (1.344).
I increased to 143x31 (4.43 Ghz) and
increased CPU Voltage to 1.34. boots fine, freezes immediately on P95...
increased CPU Voltage to 1.350, boots fine, freezes immediately on P95...
increased CPU Voltage to 1.356, boots fine, I got about 10 seconds out of P95 before freezing this time tho...
I'm not sure what the max Vcore is for this chip (Intel website states VID is 1.375; not sure what this is exactly)? I've seen another person state they're running with 1.4 Vcore though...
Thoughts? Should I keep increasing voltage a bit more? Is there something else I'm possibly overlooking?
http://img139.imageshack.us/img139/6730/pcis1c50per.jpg
@ 4.46 GHz now, TRYING TO BREAK 4.5 !!!
Originally Posted by
Sam_oslo
It wasn't stable all of a sudden at above mentioned settings. Not sure why, so I had to take my original CPU Volt from 1.375 and:
increased --> 1.38125. Still BSD on me...
increased --> 1.38750. Still BSD on me...
increased --> 1.39375. Finally... stayed stable
not sure why it became so irritable all of a sudden. Temps are up a bit obviously because of the new voltage...
http://img682.imageshack.us/img682/9598/stresstest2.jpg
Question Re: Your XMP Profile
00011011
Thank you
My VVT of 1.6 was actually set automatically by the X.M.P. profile in BIOS for my Corsiar 2000 MHz RAM. It also set my BCLK to 143, which I left alone and just started raising my CPU Ratio Setting (30 now). Should I start backing this VTT down incrementally until it loses stability that way before going any further?
The UCLK Freq I just had set to Auto and it doesn't look like BIOS is telling me what it will be. CPU-Z didn't mention UCLK either. Is there another way to determine what it is being set at? I know it's supposed to be at least double the DRAM Freq (which is 2006 MHz). Should I just manually set the UCLK to 4014 MHz or something (that is the lowest that is 2x the DRAM) instead?
Just Curious - I have the same board and DRAM kit. Manual says selecting XMP profile will present 2 additional options; 1. Performance 2. Frequency. Which option did you select?
