5 Attachment(s)
SR56xx Chipsets:sr5690,sr5670,sr5650 and sp5100.
WIP
These new chipsets should be the "backbone" of all AMD based systems for the next ~2 years.
This includes the upcoming Opteron 6000 series (Magny Cores socket g34,2P-4P) and most likely the Opteron 4000 series( socket c32 1P-2P).
Product Overview
Three different configurations to meet your needs, the SR5690, SR5670 and the SR5650.
All three versions offer:
HyperTransportTM 3.0 technology, PCIe Generation 2, SATA 2.5 and USB 2.0. Additionally all three
offer enterprise features such as HT error handling, PCIe AER, Data Poisoning Passthrough, PCIe end-to-end CRC
and AMD-Vi (IOMMU 1.2).
Scalability:
All three combinations of Embedded Enterprise Chipsets (SR5690/SP5100, SR5670/SP5100, SR5650/SP5100) are
compatible with all AMD embedded processors including high performance AMD Opteron™ processors, socketed
AM2 low power single and dual-core AMD Athlon™ processors and very low power AMD Athlon, AMD Sempron™and AMD Turion™ ASB1 (BGA) processors.
In addition two I/O bridges can be used in the same system in any
combination (SR5690/SR5690, SR5690/SR5670, etc).
Processor Support:
Embedded AMD OpteronTM Processors
Embedded AMD AthlonTM Single and Dual-Core Processors from 8W to 35W
Both AM2 and ASB1 packages
Embedded AMD TurionTM Processors
Embedded AMD SempronTM Processors
I/O Bridge
HyperTransportTM 3 Technology
5.2GT/s peak bandwidth
Compatible with HT1 processors in HT1 mode
PCI Express® Generation 2
o SR5690 (42 lanes/11 engines)
- Two x16, one x16 + two x8, four x8
- Six x1 configurable in combinations of x1, x2 or x4
- One x4 configurable as x4, x2 or x1
- PCI Express Hot Plug
SR5670 (30 lanes/9 engines)
- One x16, two x8, three x8
SR5650 (22 lanes/8 engines)
- One x16, two x8
Southbridge
> PCI 2.3 Interface
o Up to 6 master devices
> Six SATA 2.5 Ports
o Support for SATA 1.5 and 3.0 compatible devices
o RAID 0,1,10
o e-SATA
o Hyperflash
> IDE Interface
o Single PATA channel supporting two devices
> High Definition Audio
o Unified Audio Architecture compatible
o Four independent streams
> SMBus 2.0
> LPC Bus
o Support for TPM version 1.1/1.2 devices
o Supports SPI devices
> Hardware Monitor
o Fan Control
o Watchdog Timer
Power Management
> Dual Dynamic Power Management
o Separate power planes for cores and memory controller
> AMD PowerNow!TM technology and Cool’n’QuietTM technology support
Operating System Support
> Windows Vista® Operating System
> Windows® XP and XPe Operating Systems
> Windows 7 and Windows 7 Embedded
> Linux® Operating System
> Windows Server 2003
> Windows Server 2008
Speculation:
The desktop version will most likely be know as RD890 and
if History repeats itlesf - we'll see something like:
890fx (sr5690) 890x (sr5670) and 870 (sr5650),similar
to the 7 series (790fx,790x,770)
Motherboards utilizing the new SR56xx chip sets available
today on the market:
Desktop/1p Server:
Tyan S8005
Chipset AMD SR5670 + SP5100
HT3,DDR3.
3 "Flavours" are available with onboard SAS option being the major difference.
(See attached - pic1)
http://www.tyan.com/product_board_detail.aspx?pid=647
2P Server:
Tyan s8212
http://www.tyan.com/product_board_detail.aspx?pid=651
Chipset: AMD SR5690 + SP5100
PCI-E (1) PCI-E Gen.2 x8 slot (w/ x4 link) / (1) PCI-E Gen.2 x8 slot / (1) PCI-E Gen.2 x16 slot (w/ x16 or x8 link) / (1) PCI-E Gen.2 x8 slot (w/ x0 or x8 link)
Recommended TYAN Riser Card M2083-RS, PCI-E x16 1U riser card (left) / M2091, PCI-E x16 1U riser card (left)
PCI (2) PCI 32-bit slots
Again 3 "flavours" are available with 8 SAS being the difference.
(See attached - pic2)
SuperMicro
H8DI3+
AMD SR5690 + SP5100 Chipset
2x PCI-e 2.0 x16 (x8 signals),
1x PCI-e 2.0 x8 (x4 signals),
1x PCI-e 2.0 x8,
2x PCI-X 133/100
Now this is the board that caught my attention right away:
H8DA6+-F
http://www.supermicro.com/Aplus/moth...0/H8DA6+-F.cfm
Dual AMD SR5690 + SP5100 Chipset
It allows 4 double-wide (16x) PCIe 2.0 GPUs.
(See Attached Pic5)
Ask Particle about details ;)
I do believe that Crossfire is supported.
References:
http://www.channelregister.co.uk/200...rano_chipsets/
http://www.amd.com/us/products/embed...90-sp5100.aspx
http://www.amd.com/us/Documents/4758...pset_brief.pdf
http://www.supermicro.com/newsroom/p...690_SP5100.cfm
http://www.supermicro.com/Aplus/moth...d/Opteron2000/
http://www.xtremesystems.org/forums/...d.php?t=233565
