If money were no object...
I'd probably build this.
Mobo: MSI 790FX-GD70
CPU: AMD TWKR
Chassis: Lian-Li PC-65 in black
Graphics: Quad Sapphire Radeon 4890 Atomic's in CrossFireX
Sound: HT Omega Claro 7.1
Network: Bigfoot Networks Killer Xeno Ultra
Optical Drive 1: LG GGW-H20L Combo Blu-Ray Burner & HD-DVD-ROM drive
Optical Drive 2: Buffalo DVSM-XL516FB* (internal)
Optical Drive 3: Yamaha CRW-F1UX (External, USB 2.0)
Removable Media 1: 2.88 MiB 3.5" FDD (yes you read that right)
Removable Media 2: Iomega Zip250 or Zip750 drive (internal)
Removable Media 3: Multi-format memory card reader
PSU: Koolance PSU-1300ATX-12N Liquid Cooled PSU
Cooling: Custom-made phase-change CPU cooler with Prometeia-style enclosure that attaches to Lian-Li case, parallel flow waterblocks and single-slot brackets for the quad 4890s, waterblocks to cool the mobo's VRM's, northbridge and southbridge, and possibly to cool the network processing unit card and hard drives. Resorvoir, Pump, and either Radiator or Peltier array to cool the fluid will be located collectively inside an enclosure either bolted in between the Lian-Li case and phase-change cooler, or underneath the phase-change cooler.
(and yes there would still be some fans blowing air through the main chassis)
