Results 1 to 8 of 8
Thread: Chiller for positive Temps and no condensation
    Jan 2005
    Germany
    hi guys,
    i´ve build a chiller in the past month.
    specs:
    danfoss sc12g
    big condenser around 2,5kw?
    danfoss ten2 r134 txv 01 orifice
    20 plates hx
    10l water reservoir
    carel controller with ntc probes
    500 watts at 0°C to 1°C are possible
    more load at higher temps are no problem for this monster.
    i did some testing. my results:
    water temp between 15°C and 23°C with 250 watts:
    the chiller needs 9 minutes to cool the water down
    and the water needs 21 minutes to warm from 15°C to 23°C
    water temp between 15°C and 23°C with 500 watts:
    the chiller needs 17 minutes to cool the water down
    and the water needs 11 minutes to warm from 15°C to 23°C
    pics:
    Dec 2007
    Looks like German Quality build =)
    Administrator
    Nov 2007
    Stockton, CA
    Very nice unit Patrick
    You do very clean well thought out work.
    In your first picture what is the unit in the back ground ?
    Xtreme Addict Jor3lBR's Avatar
    Jul 2007
    Arizona - USA
    Looks amazing Patrick. Well done!
    //RETIRED-o00o--°(_)°--o00o-OVERCLOCKER//
    Jan 2005
    Germany
    thanks.
    tha fan of the chiller has a dimmer to make it more silent than the compressor.
    the unit in the back of the first pic was a normal 2 stage cascade with r404a in the 1st and r1150 in the second stage.
    Administrator
    Nov 2007
    Stockton, CA
    Quote Originally Posted by Patrickclouds View Post
    Oh just a normal 2 Stage Cascade
    If you made it its far from normal I bet
    Jan 2005
    Germany
    i did another load test today.
    this time i used a stronger waterpump.
    with 500watts it was possible to achieve "water" temp of -5°C
    then i tested with 750watts and achieved +4,5°C
    -100c Club
    Jun 2005
    Slovenia, Europe
    Great stuff Patrick!
    Personally I'd go for R-507, it's possible to achieve around 1kW at 0°C - condensation issues aside - as I did with my chiller build.
