Page 18 of 23 FirstFirst ... 815161718192021 ... LastLast
Results 426 to 450 of 566
Thread: P55-UD6 socket burn
  1. #426
    Nov 2009
    I believe you shouldn't have any problems.
    First,it seems that occurs in extreme conditions when vCore is pumped up and CPU starts to drain a lot of
    power - the ammount your wife is not likely going to achieve.
    Second,I truly believe that actually one or two out of ten (or even more) boards sold really burns.
    But most of people like to be on the safe side.
  2. #427
    I am Xtreme
    Sep 2006
    How many burned sockets have you seen with daily (ab)usage with mild OC's ? How many run rigs here at stock speeds ? How many have reported real damage (not some marks on the CPU contacts) All stability issues are now related to the bad socket, pin contact...there's more to that guys......Snowball effect in maximum motion !..... If it was such an issue there would have been more than a thousand RMA's already solely from Gb mobo's... have you seen any or even heard from them ?
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
  3. #428
    Hardware Nightmare
    May 2004
    Taipei :)
    Thumbs down
    More damage detected
    crappy ASUS M3F (made at 27 week 2009), with Xeon 3470 after 20-50 hours of usage under deep subzero (-50 to -100°C) on CPU got first alarm bells
    CGC_TP_NCTF pin from socket burnout, and same melt parts on CPU . According to intel datasheet that's not critical to function pin, for debug usage only. Few VCC pads on cpu melted and got bumps into CPU PCB substrate.
    Rig still working.
    Attached Images Attached Images
    Taking GND reference from another galaxy
    Electronics engineering @ extreme overclocker
    LN2: Cel347@8199.5MHz,920@5300,E8600@6610,QX9650@5700,X 3050@4311,X3470@5060
  4. #429
    c[_]
    Nov 2002
    Alberta, Canada
    great pics TIN
    Just above the ones with the blue arrows it appears there is a slight bit more plastic melting from the upward pointing piece of metal from a few of those pins (the piece of metal level with the plastic, not the pin).
    All along the watchtower the watchmen watch the eternal return.
  5. #430
    Apr 2006
    Sao Paulo | Brazil
    Well, I gave up the Core i5!
    I bought parts for my new system, and a week later, began to appreciate these issues. They were more than 3 weeks stucked in my office.
    Sold my P7P55D Deluxe + i5 750 this week and bought Asus Rampage II GENE i7 + D0.
    Really is a shame that the Intel/Foxconn/Lotes, or whoever else has "guilt" in the development of this project, are playing so dirty with their customers, consumers.
    Shame!
    CM 690 II Advanced - - ┐ ┌ x6 1055T @ 3.7GHz - - ┐ ┌ Asus M4A89GTD Pro/USB3 ┐ ┌ Corsair Dominator 4GB 1600MHz C9 ┐
    HIS Radeon HD 5850 1GB ┤ ├ XFX 850 Watts modular ┤ ├ Seagate Barracuda 1TB -┤ ├ Seagate 320GB 2,5" - - Hotswap - ┤
    └ ACER - Aspire AS2920 - ┘ └ Intel -- C2D T5550 -- ┘ └ Kingston -- 4GB 800MHz ┘ └ Intel X3100 256MB 12,1" WSGA - - ┘
    Desktop Intel: GMC R3-Corona Watercooled | Asus Ramapage GENE II | Core i7 920 Rev. D0 | G.Skill Trident 6GB 2000MHz | XFX GTS250 1GB + MCW60 Rev. 2 | Corsair HX620W | Seagate 7200.12 1TB | Samsung 2232BW 22"
    Mobile PC1: Acer AS2920 | T5550 | 4GB DDR2 800 | 12,1" WXGA | 250GB | X3100 | WebCam 1.3MP | DVD-RW 16x | MS Notebook Mouse 3000
    Pocket PC Phone/Office: HTC TyTN II | WI-FI | GPS | Bluetooth |3G/GPRS/EDGE/HSDPA/UMTS | MicroSDHC 16GB | QWERTY Keyboard
  6. #431
    Xtreme X.I.P.
    Nov 2002
    Shipai
    nice pics tin eof!
    are those metal parts next to the pins the lower end of the pins burned 90C? how come they melt and the pins actually dont?
    Quote Originally Posted by groove View Post
    I put together a system for the Wife using this same motherboard. She play's most of the "heavier" games, GTA4, Crysis, etc.
    lol, nice wife
  7. #432
    Mar 2003
    Holland,MI-USA
    I tried tell you guy's a few posts back that those burned posts (blue arrows) make contact with the cpu once installed. Look at the very outside row of pins in the socket, all the pins bend inwards leaving nothing to contact the outside edge of pads on the cpu. Those posts make the marks in the cpu other wise there would be no marks on the outside edge pads all the way around the cpu.
    Now look at the 2nd pic of TiN_EOF (the cpu) all the way to the bottom left you see a indentation in the pcb of the cpu and not a pad, if you look very close it looks like it's making contact with the pad in the next row directly in front of it.
    Any1 trying to help the motherboard makers solve this issue should have them start looking into the composition of the pins in the socket and a thickness check just a slight variation would drastically change the amount available current draw. It wouldn't be the 1st time poor quality products caused havoc in the electronics market. every1 remember the capacitor issues of years past.
    Cooler Master 110 case w/window and cold cathode/Sony E540
    I7 920@4.4Ghz 210x21 Megahalems
    Gygabyte GA-X58A-UD3R
    OCZ 6Gb DDR3 1600
    XFX ATI 5770 960/1400
    Seagate Barracuda 1.5tb
    Lite-On DVD RW iHAS220-08/Sony Optiarc AD-7190S
    PC Power & Cooling Silencer 750
    That's my 2008 Street Glide.
  8. #433
    c[_]
    Nov 2002
    Alberta, Canada
    I dont think those posts make contact to the CPU landing pads cowpuppy. It would be blatantly poor contact pressure..
  9. #434
    Jun 2004
    USA, Vermont
    It would seem that the problem is lower in the socket itself as the socket seems to take the worst of it and CPU's pads dont seem a burnt as they should b if that was the actual area where there was poor contact, if u look at those pics the tips of the pins r not discolored at all which u would expect from that kind of heat, the fact of the cpu's r not burnt as bad as the pins so that would also lead me to think it ISNT the connection from the cpu to the socket but lower in the socket when u r appy to much pressure in some way, maybe the socket itself is bending enough with high mounting pressure that it is alow somekind of contact inside the socket itself, that is just my .2
    Also if u look the pins that r burnt r burnt down very low in the socket where there is the least amount of resistence threw it so this also leads me to believe it is in the socket itself and the burnt pads r the result of the heat traveling threw the pin into the cpu pad, but who knows?
    Dragon
    http://smbach.com/mad.gif
    Opty 175 Rig
    Lian-Li PC75B case, Thermaltake BT w/ 165 CFM delta fan, Enermax 550watt PSU (36A on 12+), x1950 Pro, DFI Lanparty NForce 4 Ultra-d (moded for SLI so that i can use the second slot at 8x), Opteron 175 CCBWE 0547 TMPW (2.80, 280x10, 1.5 volts), 2x1gb Mushkin Redline xp4000 (280 3-3-2-8, 2.65 volts), 80GB WD
    AM3 Rig
    Lian-Li PC-75b case, Asus Crosshair III Formula, 965 x4 C3 @ 4.1 1.525 volts 2.8 NB 1.25 volts, 2x2gb Dominator GT Cas 8 2000Mhz@ 1720 6-6-5-18-22 1.725 volts, Asus 5770 VT @1010/1435, Seasonic 850watt PSU 2x12v rails 40 amps each, 36GB raptor boot drive, 80GB WD storage drive, HeatKiller LT cpu block, BI GTX 360 with 6x Scythe 3000RPM fans in push/pull, MCP 655 variable pump on setting 5, EK 150ml res, all 1/2 inch
    DFI NF4 BIOS Guide
  10. #435
    Aug 2007
    Spain
    Holy sh**.
    I was just planning on building a new computer and I learnt about this only two days before ordering cpu and mobo. I'm still on time to switch again to AMD.
    Is the problem solved?
    Does the LOTES latch solve the problem?
    Athlon XP2400+@2280 [Asus A7V8X-X]
    Athlon XP3000+@stock [Shuttle FN41] <-- Looking for a compatible board to upgrade a SN41G2 barebone. <-- F*ck you, Shuttle.
    E5200 / Intel G41 ITX / Antec Isk-300
  11. #436
    Jul 2002
    [M] - Belgium
    unless you plan to cool with dry ice, LN2, phase change and want to overvolt the CPU, I wouldn't worry about this issue
    and even in those cases, recent revisions have no more issues with the socket...
    Belgium's #1 Hardware Review Site and OC-Team!
  12. #437
    Jan 2006
    Texas
    Quote Originally Posted by jmke View Post
    Or they watercool and plan to run sustained overclocks under 24/7 loads. Always going to be old stock out there, and doesn't lend any votes of confidence for Foxconn's "revised" sockets either.
    Seen a enough reports of users with memory issues to wonder how many might be from bad CPU pin contact. Very easy to simply blame the kit as bad, yet some people have gone through several...
    Core i7 4790k
    ASUS Z97 Pro
    Kingston 1600MHz 32GB
    EVGA Titan Black (RIP)
    ASUS Xonar DX | Corsair Neutron GTX 240GB
    Apogee XT + MCP655 & Thermochill Triple 140mm Radiator
    Corsair AX1200 PSU | Cooler Master HAF-X | Windows 10
  13. #438
    Dec 2007
    Germany
    Quote Originally Posted by RebootEDC View Post
    No one really knows, that's the problem.
    I've even heard of some instand burned sockets.
    They put the system together, tried to boot it up and than it burns, bevore it could even post.
    I don't know why that happens but i sure want to know....
  14. #439
    Jul 2007
    EVGA P55 FTW over here with the same F * C K * N G problem, probably is all ready dead.
    Pictures later when my friend send to me.
  15. #440
    Nov 2009
    Damn, almost imported eVGA P55 FTW considering it was imune to this issue.
  16. #441
    Sep 2008
    I've an msi p55-gd60 with foxconn socket, after 20+ hours on LN2 and SS the socket and the cpu are still alive.
    vcore was always over 1.55 volt and vtt was always over 1.5 volt but none of the pin is burned.
    maybe I was lucky
  17. #442
    Aussie God
    Feb 2005
    Copenhagen, Denmark
    Quote Originally Posted by Mafio View Post
    maybe I was lucky
    Nah, the burn was RARE, not mainstream...
    Several users has ran several hours 1.65-1.7vcore and 1.7-1.9vtt...
    In fact, even on air, I havent been down to 1.5VTT yet.. 1.54v is lowest I have used so far....
    Competition ranking;
    2008; AOCM II, Minfeld/Germany #2 @ 01SE/AM3/8M (w. Oliver)
    2009; AMD-OC, Viborg/Denmark #2 @ max freq Gigabyte TweaKING, Paris/France #4 @ 32M/01SE (w. Vanovich)
    2010: Gigabyte P55, Hamburg/Germany #6 @ wprime 1024/SPI 1M (w. THC) AOCM III, Minfeld/Germany #6 @ 01SE/AM3/1M/8M (w. NeoForce)
    Spectating;
    2010; GOOC 2010 Many thanks to Gigabyte!
  18. #443
    -100c Club
    Jun 2005
    Slovenia, Europe
    Here's the P55A-UD3 i obtained. Looks like it uses a complete LOTES socket:
  19. #444
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Nah the socket is foxconn and mount plate front and back is lotes, but it doesn't matter. I have yet to burn a socket out on any of the new boards and yet to see someone post it.
    heatware chew*
    I've got no strings to hold me down.
    To make me fret, or make me frown.
    I had strings but now I'm free.
    There are no strings on me
  20. #445
    Aug 2008
    same problem with dfi x58-t3eh8
    foxconn socket too
    and 3 different boards got this problem even without subzero
    the first feeling was like a....hey i didnt clock it
    what the hell
    and after that i already realised this board must have some problem
    because i mounted the cpu and never unmounted it
    the first time i unmoented ,i see the pins are so fu&/% up like a cut thm with knife
    My DDR2 Results:
    Cellshock GMH 8500 2GB-1508MHz 2.74v vldt
    Cellshock GMH 8500 2GB-1398MHz 4-4-4-12 2.74v vldt
    Cellshock GMH 8500 2GB-973MHz 3-2-2-1 2.74v vldt
    Cellshock GMH 8500 2GB-1000MHz 3-4-3-5 3.25v SP1M
    Mushkin XP 8500 GMH 2GB-1300MHz 2.45v vldt
    OCZ Reaper 1200MHz PSC-1406MHz 2.28v vldt
    Dominator 8500 GKX 2GB-840MHz 3-2-2-1 2.5v vldt
  21. #446
    Jun 2009
    Italy
    hi,i must return back my p55a ud5 for rma problems
    however after the remove cpu, i looked the back side and... lotes clip didn't solving the
    problem
    my cpu has many "pin" not signed...
    i7 4770k @ 4.4GHz | MSI MPower | 8gb Geil Evo Corsa 2133 | Gigabyte GTX670 wf3 | Samsung 830 256gb | 3xWd Re3 raid5 | Antec HCG 620w
    Θ Core i7 4770k 4.4ghz 1.3v :'( Θ Core i7 2600k 4.5ghz 1.344v Θ E8400 500x8 4ghz 1.36v Θ Core i7 860 @ 4ghz 1.328v Θ Turion M500 2.2ghz 1.025v Θ Phenom II 955 c3 3.91ghz 1.52v Θ Phenom II 545 3.77ghz 1.47v Θ
    _~{ ALL RS }~_
  22. #447
    Hardware Nightmare
    May 2004
    Taipei :)
    Photos please.
    foxconn socket too
    X58? 1366? How can it be?
  23. #448
    I am Xtreme
    Sep 2006
    Snowbal effect Tin_EOF... now everybody starts looking at pin marks,luckily for me my eyes are so old, that I don't see one pin marking on my I7 CPU's lol
  24. #449
    Jun 2009
    Italy
    not burned my cpu, but not all pin are checked
    however i haven't digital camera (is damaged) and with cell is impossible...
    _~{ ALL RS }~_
  25. #450
    Hardware Nightmare
    May 2004
    Taipei :)
    Hate to report to this thread, but I must.
    As you remember from my previous post - ASUS MAXIMUS III Formula has Foxconn and affected too.
    History have now bad update with continues. Tested yesterday this combo with 8800GTX. both GPU and CPU was under LN2, CPU temps never go above -50.
    CPU was clocked at ~5G, only 1.57 V and lower by DMM reading, and with two cores disables. No HT too. LLC was on. And after 6 hrs of good ocing, i've shut rig off and putoff pot and cpu...and...pics in attachment.
    After clean up, straitning pins under binocular microscope, i've put CPU to mobo and rig worked. No more overclock now.
    Will never go ASUS from now. Yes, I know, it's foxconn issue, but tired of bullshift marketing of stupid top mobos with idiotic engineering..
