Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 118
Thread: I7 Waterblocks Version3
    I am Xtreme
    Aug 2008
    Cu goodness
    K350(ilovethis)
    Ek Supreme LT
    Ek Supreme
    HK Cu
    Swiftech GTZ
    hk3 german?
    **pictures
    more pictures..
    the setup...
    rads:
    cpu & nb
    loop1: nb
    loop2: cpu
    cpu loop
    The game plann
    Simple as it is. Here’s the brief procedure.
    1. Connected everything
    2. Bleed the loop and check for leaks(micro_res v2 makes bleeding a breeze 2minutes and the loop is clear of air bubbles)
    3. Mounted the water block
    4. Load bios oc settings (4140 ht on vcore at 1.568v)
    5. Prime95(load percentage average: 99.9% as reported by realtemp, windows vista tweaks help) large fft 20minutes(higher heat) check if temps improve if not, then remount
    6. record room temp and start realtemp
    7. repeat
    cpuz screenshot
    Room temperature was controlled to about 23.8c, minimum and max temps were 23.3 and 24.1
    sample tim application using a flexible plast strip..almost perfectly flat in less than 5seconds...
    Results(best 3 for each block out of 5 or 30+ mounts)
    Scores/Notes
    HK3
    1. Thermal performance (9/10) very good but not enough to be numero uno. bow down to the King350
    2. Flow and restriction (9.5/10) second to the Dtek fuzionv2, impressive
    3. Mounting (5/10) this is the worst block ive tried to hard mount, i don't use any of the stock parts included.
    Ive done 30+ mounts including bad mounts(mount and check temps if improved if not remount). I'm not sure if the block hates a lot of torque(subjective) when mounted but low(subjective) torque resulted to very good temps. I tried 30+ mounts squeezing the best temps, at first I thought this waterblock would beat the King350 but it(thermal performance) wasn't enough. Also compatibility with my motherboard . No instruction manual included. No backplate in the kit .
    4. Build quality (9/10) base is not mirror finish, best looking block overall i did appreciate its german design. (leaks:none) (price:fair)
    K350
    1. Thermal performance(10/10) nothing beats the king at the moment. maybe ek supreme v2
    2. Flow and restriction (6/10) good enough (edit: i used dual pumps)
    3. Mounting(10/10) easiest ...most reproducible...thick heavy duty..
    4. Build quality(10/10) the nickel plating is excellent in preserving that base. base finish is the best in class The acryllic top is excellent (leaks:none)(price:fair)
    Hondacity for the fun likes to thank
    1. That plastic strip for giving me that perfect flat paste everytime in 5 seconds
    2. Swiftech Micro Reservoir v2 for that less than 2 minutes bleeding time
    3. BP rotaries and that oh so uber soft Clearflex tubing,
    4. UN brackets for finally setting up my pumps correctly
    5. XS no reasons needed
    6. RRR/Gary for the HK3
    Dec 2008
    Jersey
    How about some .
    PLEASE!!
    Oct 2008
    do u need an extra o=ring to put fatboys on gtz?
    The Stuff
    Cpu: x3210 xeon (3.4ghz)
    Mobo: DFi P35 Dark (425 mhz fsb)
    Ram: Patriot 2x1gb ddr2 800 (at 900 mhz 4-4-4-12)
    Gpu: 4870 850 core, 940 mem
    The Liquid stuff
    Apogee Gt
    enzotech snbw
    Dtek-gfx2
    Hw labs GTX360
    DDC1-XSPC Top
    Custom PVC Res
    All tygon 7/16''x5/8''
    Jun 2007
    mars
    what a beatiful blocks here
    one more buddy for them
    Alphacool HF 14 Yellowstone
    Intel Xeon W3520 4200MHz HT
    Foxconn Bloodrage
    3x2Gb Patriot Viper II DDR3-1600 6-6-6-16
    MSI GTX480 M2D15 850/1700/2000
    Samsung F1 1TB
    Corsair TX950W
    Stacker 832 w/ Dual Loop Watercooling aka *Bong Build*
    NEC 2690WUXi
    Loop 1: Laing DDC1-T -> Watercool HK 3.0 LT -> Thermochill PA120.3 -> Bloodrage NB -> EK Res 150
    Loop 2: Laing DDC1-T -> EK-FC GTX480 -> Thermochill PA120.2 -> EK Res 150
    *New* CM 690 II Advanced Watercooled
    *Coming soon* Stacker 832 Rebirth!
    I am Xtreme
    Aug 2008
    Quote Originally Posted by thehighlander1 View Post
    yes which is a bad design
    Dec 2008
    Jersey
    Quote Originally Posted by rioja View Post
    That is sexy!!!
    Aug 2005
    Washington
    Quote Originally Posted by Hondacity View Post
    Really? I am using fat boys right now on my GTZ without any issues. There is even an entire thread on this.
    That said, when approx. can we expect the results of your tests? If you say by Monday I will hug you.
    Jun 2008
    Los Angeles, CA
    Not a big fan of it's looks but anxious to see testing on a higher flow system....
    I am Xtreme
    Aug 2008
    any us retailer carrying them?
    Xtreme Mentor
    Oct 2005
    Cant WAIT to see these results. Will you also be recording pressure drop?
    Asus Rampage II Gene | Core i7 920 | 6*2GB Mushkin 998729 | BFG GTX280 OCX | Auzentech X-Fi Forte | Corsair VX550
    —Life is too short to be bound by the moral, ethical and legal constraints imposed on us by modern day society.
    Feb 2006
    Vienna, Austria
    frozen cpu has alphacool blocks but only the 2 year old model
    this block was released a few weeks ago, maybe they'll stock it soon
    Core i7 2600k|HD 6950|8GB RipJawsX|2x 128gb Samsung SSD 830 Raid0|Asus Sabertooth P67
    Seasonic X-560|Corsair 650D|2x WD Red 3TB Raid1|WD Green 3TB|Asus Xonar Essence STX
    Core i3 2100|HD 7770|8GB RipJawsX|128gb Samsung SSD 830|Asrock Z77 Pro4-M
    Bequiet! E9 400W|Fractal Design Arc Mini|3x Hitachi 7k1000.C|Asus Xonar DX
    Dell Latitude E6410|Core i7 620m|8gb DDR3|WXGA+ Screen|Nvidia Quadro NVS3100
    256gb Samsung PB22-J|Intel Wireless 6300|Sierra Aircard MC8781|WD Scorpio Blue 1TB
    Harman Kardon HK1200|Vienna Acoustics Brandnew|AKG K240 Monitor 600ohm|Sony CDP 228ESD
    Dec 2008
    Franklin, TN
    Well, once I see these results I can finally choose a new block!!! Waiting impatiently Honda!!!
    (New build):MSI Big Bang X-power II with XSPC MB blocks, Core I7 3930k@4.6Ghz with HT on, 3x GTX 480 SLI with EK Waterblocks(for now), X-fi Titanium, Gskill quad kit 16GB 2133mhz, 2x240GB Corsair GT SSD's(raid 0), 3xWD 2TB drives, Silverstone Strider ST1500 Watt, Dell3007WFP and 2x Samsung 305T's. Water loop: EK HF CPU block, XSPC RX480 Rad, Coolgate GC480, Airplex Revolution 420 Rad, 2x DDC 3.25 18W with EK dual top, Caselabs STH10 white with customizations....
    Jun 2007
    mars
    I read that those Alphacool HF 14 performs with only one degree difference with Heatkiller 3.0, would be really interesting to see it in tests also.
    And it looks soo nice
    Don't know if Aquatuning delivers to USA, on other hand DHL works everywhere.
    http://www.aquatuning.de/index.php/c...ocket-1oe.html
    Foxconn Bloodrage
    Samsung F1 1TB
    Corsair TX950W
    NEC 2690WUXi
    Apr 2008
    Finland
    Would be nice to see the HK 3.0 Copper vs Acetal in this test as well
    Dec 2007
    Beneath The Remains, Greece
    I really hope the LT will do well on the test. I m waiting for the block on monday-tuesday.
    Intel i7 3770K (4.8Ghz@1.36v) ~ Asus Maximus V Gene ~ 8Gb G.Skill Ripjaws X 2133 C9 (@2400 C10) ~ Asus GTX 670 DCUII (1230/7000) ~ Samsung 840 Pro 128Gb ~ WD Black 1Tb ~ Corsair AX 850W ~ X-Fi Titanium Fatal1ty ~ Epoz Aktimate Mini ~ Ducky Shine Blue Led /w MX Red ~ Logitech G700 ~ Samsung S27A850D 27" (2440x1600) ~ SilverStone TJ07B-W
    WaterCooled by XSPC Raystorm ~ TC PA 120.3 + 3xAP 15 ~ MCP655 with EK-D5 X-Top Rev.2 ~ EK Multi 250
    Powered by APC Smart-UPS SC 1500 ~ MGE ellipse premium 500
    Apr 2008
    Finland
    I would choose the LT just based on price and looks so hopefully it performs as well as the copper. Have had my GTZ for a month and already looking for new stuff
    Dec 2007
    I know it's a different type of block but, do you have any plans to test a XSPC Delta V3? http://www.xspc.biz/deltav3cpui7.php
  18. #18
    I am Xtreme
    Aug 2008
    Quote Originally Posted by chiguy View Post
    read martins review
    http://www.xtremesystems.org/forums/...d.php?t=206712
    it doesn't touch the ek supreme curve/line ...thats not going into my review
  19. #19
    Sep 2004
    Already picked up a Heatkiller 3.0 just waiting for the rest of the gear to hook it up. Looking forward to some higher flow testing results.
  20. #20
    Xtreme Cruncher
    Jul 2007
    Flushing, NY
    Hondacity... you are such a tease...
    showing us only pix
    Nikon User
    Nikon D200 (Gone =( )/D300
    Nikkor 18-105mm(Gone) // Nikkor 50mm 1.8 // Nikkor 55-200VR(Gone)
    Tokina 12-24 // Tamron 90mm //
    Manfrotto & Benro Legs // Benro Ballhead.
    Current Lust = 80-200 Or 70-200VR1 <--Pending
    No more computer parts for me... Well for now until I
    really REALLY need to upgrade.
  21. #21
    Assistant Administrator systemviper's Avatar
    Nov 2007
    Newtown, CT
    Have my HK 3.0 LT in black and silver, it's a very well put together block.
    HWbot - Team: XtremeSystems
    XS cruncher - Team: XtremeSystems
    OCN Feedback
    HEAT
    *** Being kind is sometimes better then being right.
  22. #22
    Dec 2007
    I seem to have missed that one, thanks!
  23. #23
    Apr 2008
    Finland
    Quote Originally Posted by systemviper View Post
    One word: Jealous!
  24. #24
    I am Xtreme
    Aug 2008
    internal pix added
  25. #25
    May 2006
    the HK CU looks huge! whats the thickness of it?
