Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: Powdercoating my Cosmos?
    Jul 2008
    Okay well i have my CM Cosmos stripped down to the frame itself. I'm thinking about getting it shipped out to get it powdercoated since that seems like the easiest, and reassuring way knowing it's going to get painted right. Now my dad on the other hand says we should paint it ourselves but i feel as if its going to come out sub-par and im not going to be happy with it.
    My question is, is it worth getting it powder coated rather and spray painting it myself? I would like to get it done in like a flat black on the inside, while keeping the outside panels silver so its almost like everything between the silver side panels is black (if you've seen a cosmos before).
    Apr 2008
    Powder-coating is a great way to paint a case. Very durable finish. I highly recommend shipping it out to get it professionally done if you're nervous about doing it yourself. Getting one or two things professionally done won't kill the mod project, don't worry
    • i7 920 D0 // eVGA X58 SLI // 12GB G.Skill Ripjaws // HD6950 (6970 BIOS)
    • Apogee XT // MCP655 // Thermochill PA120.3 // CM HAF 932
    • OCZ Vertex 3 MI edition // ASUS Xonar DX // Corsair TX850
    • HTC Incredible - Uber Kingdom Revolution ROM
    Jul 2008
    yea i read the tutorial on how to paint it yourself but it seems like a lot of work, and i know i'll screw something up.
    Before i get my case shipped out, do i need to worry about covering any holes for screws? (motherboard holes etc)
    Case---------CM Cosmos (http://www.xtremesystems.org/Forums/...d.php?t=194812 )
    Power Supply-CM RealPower 850W
    Processor-----Intel Q6600 SLACR @ 3.6ghz 1.44v
    Motherboard--DFI x48 UT-T2R
    RAM----------G Skill Black Pi 2x2GB DDR2-900 @ 450mhz 4-3-3-6 CR1
    GPU----------Dual GTX 275 896MB (usually stock speeds)
    HDD----------Dual VelociRaptor 150GB(Raid 0) 320GB Backup
    Audio--------Razer AC-1 (On sale on woot for 50$ )
    Mouse/KB----Razer Copperhead/Logitech G15
    Watercooling: AquaComputer Cuplex HD, MCW 60's, 2x120mm Radiator, MCP655, EK Multi-Res
    Jun 2008
    Orange County,CA
    hey i plan on doing the same thing you did, can you explain or have pictures of how you took apart the cosmos case? was it hard?
    I am Xtreme
    Oct 2005
    Grande Prairie, AB, CAN
    Powdercoating is the the way to do. Paint just doesn't have the durability. It is pricey, but if you plan on using the case for a while i believe it is worth it.
    Jul 2008
    no it was pretty easy. i gutted the inside first, then took off the tops bars then tried to take off the side panels but they didnt budge, so you have to flip the case over, take off the bottom black piece, unscrew the front panel and then it pretty much pops everything off.
    note- dont confused the top and bottom bars. bottom are flat, top are curved
    also for the cd bay clips, if i remember correctly they push towards the front of the case to pop off and the bottom one for the floppy is screwed in.
    i also just got off the phone with the place and they said 75-100$ and could be done by the end of the week :0
    Dec 2005
    NYC
    its actually not pricey at all. In my area, the local coaters will do a full tower lian li for about $80 bucks..
    i5 2500k @ 4.6ghz 1.335v [ASUS P8Z68 Deluxe]
    8gb gskill ripjaws f3-12800cl8-8gbxm
    600gb velociraptor + 1TB black
    MSI N560GTX-TI Twin Frozr II + x-fi xtrememusic
    corsair hx-620w + lian li pc201b + dell 2408fpw
    d-tek fuzion1/ddc2 + petra top/thermochill pa120.3
    Mar 2008
    San Diego
    Quote Originally Posted by absoluteczech View Post
    Just take everything off till your left with the frame, then Anodize it and it will last forever.
    Apr 2008
    Canada, by the mountains
    As a meganoob, I always anticipate things with PC's being tough. And unfortunately I'm usually right (thank goodness for this place!), except for when I decided to strip my Cosmos. Just start unscrewin' screws and you'll be done before you know it. Be a bit careful prying off the plastic side frames... I broke off a couple little tabs (no huge deal tho) 'cuz I was tryin' to watch a hockey game at the same time.
    One thing about powdercoating a cosmos though. Aside from the debate as to whether or not one should remove all the rivets to get the case down to its smallest parts (you can do it without going that far if you want), I wonder if it isn't at least necessary to remove the spring-loaded sidepanel mounting bars. One shop I went to for a quote said there'd be no problem and that the powdercoating will just "work itself out" once you move the things back and forth a few times. But every other shop said they'd have to come off (which means rivet removal, albeit only a handful).
    Edit: to be honest, to me one of major appeals of powdercoating is that it saves you the PITA of a lot of the prep that goes with painting.... says the guy who's developed a total hatred of sanding since finally admitting to himself very recently that he didn't sand enough at the low-grit stage of his current alu polishing job (Cosmos front door) and has to go back and..... etc etc etc etc aaaarrrrrrgggggghhhhhhh (sorry, that just came out) Often, when Coolermeister paints the side panels on one of his crazy-ass Cosmos builds, he gets the panels powder-coated which apparently makes for a nice& easy base coat for the eventual crazy-ass paint, without all the aggro of prepping brushed alu.
    Time is an illusion. Lunchtime, doubly so. Douglas Adams
    QX9650 @ 3825mhz CoolIT FZone
    2x HD3870X2 @ 845/946mhz air
    Asus Maximus Formula 0907
    2x2048mb OCZ Reaper 8500
    2x Raptor 150G Raid0; 'Cuda 1000G
    1200W Thermaltake
    xFi Extreme Gamer/ Z-5500
    Vista Ult. 64
    Cosmos 1000
    30" NEC
    Jun 2007
    3 layer paint for other various designs ...
    power coating is very limited to single colors (so i heard)
    3 layer paint is those primer, color, clear coat paints ..... you could place some color designs ... or just wrap them up with clear coat glossy finish
    Jul 2008
    TedShred, you didnt have a problem with the spring loaded door parts then? i was kind of worried it would bind but if it did i wouldnt whine. Just curious
    Apr 2008
    I haven't actually sent the chassis in for powdercoating yet, it's still sittin' in a corner. It would be interesting to know if anyone's left those sidebars on for powdercoating and how it worked out.
    1200W Thermaltake
    Vista Ult. 64
    Cosmos 1000
    30" NEC
    Jun 2008
    Orange County,CA
    Quote Originally Posted by TedShred View Post
    id like to know too, however im just gonna use painters tape and cover it and have them skip that and remove the tape before putting it in the oven ghetto, maybe but better safe then sorry i dont have another 250 bucks for a cosmos s
    Sep 2006
    Toronto, Ontario Canada
    marcus at overclock.net powder coated several cosmos cases.
    he removed the rivets as he was quite certain that they would be affected by the powdercoating
    Intel i7 2600k , Asus P8P67 Pro, G.Skill Ripjaws 2x4 GB 1600 Mhz, MSI GTX580, OCZ Vertex II 128 GB Extended, X-FI Fatality Pro, Pioneer DVR-212DBK, CM HAF-X, Seasonic M12D 850, Corsair H70, Win 7 64 Home Premium.
    Jun 2008
    Orange County,CA
    how do u add the rivets back once you drill them out?
    Apr 2008
    Here's a couple (re)riveting vids I lifted from the earlier stages of Cyber Druid's recent triple-loop Cosmos build.
    http://www.youtube.com/watch?v=l92o5JEDCqU
    http://www.youtube.com/watch?v=vTIyOCXzIj8
    here's the whole thread
    http://www.xtremesystems.org/forums/...d.php?t=180663
    1200W Thermaltake
    Vista Ult. 64
    Cosmos 1000
    30" NEC
    Dec 2007
    $80 for powerder coating! Wow wish I could find deals like that.
    Would love to see some pics of the case when you get around to it TedShred. Also some gutted pics if you have the time.
    JM
    Intel Core2 Quad Q9550 @3.3GHz || DFI x48 T3RS DDR3 || Custom Silverstone Black Temjin TJ-07
    Coolermaster Gemini2 (2 120x120x38 Sunon's) Idle-32 Load-46 || 4Gig Patriot Viper DDR3 1333
    Crossfired 4850's || Gigabyte Odin 800W PSU || 500gig SATA || Logitech G9 || Samsung 2232GW
    Initiate Heat Blasters!
    "If I'm lacking in boats, it's cause I'm fearful of the Kraken" -MC Frontalot
  18. #18
    Apr 2008
    Quote Originally Posted by Jim Morbid View Post
    ... Would love to see some pics of the case when you get around to it TedShred. Also some gutted pics if you have the time.
    JM
    Sure thing, here's some pics of my slooooo-movin' build:
    The total guts. edit: forgot the drive bay clip/button things. (Wish I would have known about them pushing toward the front for removal. I just kinda squeezed the sides and pulled. It worked, but I think I might have got lucky not to break one):
    Heat gun (ok, hair dryer) to remove panel foam. SOS pads (steel wool/ soap) takes off the tape residue pretty easily.
    same heat gun to separate door (since cut) and acrylic from same 2x tape as on the panels. The little separate CM logo comes off the same way. Darnit, mine's hiding somewhere - I've been looking for it for over a week
    This rivet looks tricky, but there's a good thread somewhere here where I got some great suggestions on removal technique
    Notice the clear plastic strips (in front of the bag of handles & stuff) - they're from the top & bottom of the HDD caddy (hair... er, heat gun, again) I think that's gotta come off if the caddies are being P-coated. For taking off those little blue handle rests, I found they twist off nicely with needlenose pliers
    Each of the top/bottom rails are marked with their intended place, R-B, L-B, R-T, L-T (mine are chromed. well, 3 for now - #4 isn't done yet)
    Edit: sorry for goin' OT, but I can't help it Was always planning black/chrome exterior, but I've changed things up as I'm now gettin' totally inspired by this cool mint hotrod pic:
    1200W Thermaltake
    Vista Ult. 64
    Cosmos 1000
    30" NEC
  19. #19
    Xtreme Cruncher
    Jul 2007
    @ the computer
    i'm not sure how powder coat works, so is there any way i can do it myself or it can only be professionally done since i dont have the equipments?
    [SIGPIC][/SIGPIC]
  20. #20
    Apr 2008
    They have some basic DIY equipment here:
    http://www.caswellplating.com/powder/index.html
    1200W Thermaltake
    Vista Ult. 64
    Cosmos 1000
    30" NEC
  21. #21
    Dec 2007
    oooooo that green looks awesome!
    Although that green looks very glossy... dont know if you'll be able to achieve that with a powerder coat?
    JM
    PS, thanks for the pics
  22. #22
    Apr 2008
    JM
    You bet. Yeah, I'm thinkin' of using powdercoat just for a base, then finish off with paint.
    As an aside, one powdercoat shop told me the other day that they can mix up some paint to match the powdercoat, so afterwards you can match-up the plastic parts with a rattle can.
    1200W Thermaltake
    Vista Ult. 64
    Cosmos 1000
    30" NEC
  23. #23
    Jul 2008
    Hey, i finally got it painted!
    I forgot about this thread till a few minutes ago so i snapped some pics for you guys..
    When i actually got the case i just went and reassembled it. forgot about everything else (i didnt even eat dinner!)
    i spent from 5:30 to about 11:00 getting everything back together..
    now the sad news is...a few days before i got my case back, we had a t-storm and my yard got hit with lightning..it traveled to the box otu front of our house which hit our cable/phone which surged through the ethernet line and took out my board! THE SECOND ONE!
    so im once again on a search for a DFI 680i...if anyone has one and is willing to sell it i would be interested.
    now for the pictures =)
    oh one more thing, i didnt get it completely taken apart so i wasnt able to assemble the doors due to the mechanism being stuck. my powder coater said to take a soft mallet or piece of wood and hit them loose and they should be okay. i'll try that later.
    one LAST thing, my theme for the outside was to be silver on the outside, and a black strip down the middle. i think it came out good.
    oh yea, i think the silver HD bay bars set it off nicely, no?
    the only reason the loop isnt filled is because i took it apart to get ready to test my components, but then i had to put it back together to get it signed off as unrepairable at a shop, so thats why my loop isnt filled. it rusn off the motherboard, and the motherboard doesnt even power on.
  24. #24
    Jul 2008
    and here is the PC im on now since that one is dead...
    reluctantly i ordered this 2 days prior to the strike as something to toy around with..and now its my main system. kinda sucks but its not bad.
    e7200 @ 3.9ghz
    DFI P35
    4gb of mushkin ddr2 1000 (taken from my better PC for the time being)
    7900GS
    my video card block i had was leaking in my test before i put it in so i only had a cpu block...it still keeps it nice at sub-40c temps.
  25. #25
    Apr 2008
    Oh, man... that sucks about the lightning
    But, yeah, it turned out really nice! The silver HDD handles look great against the black caddies.
    I'm curious about a couple things:
    - how did p-coating the hdd caddies go? I'm wondering particularly about those little clear plastic shims on the top/bottom of 'em. And, since powdercoating would add a bit of thickness to the caddy and the hdd cage itself, maybe you don't need to (maybe can't?) put them back on for the nice tight fit? (I got a real heat gun and ended up melting a couple of the shims in the removal process.)
    - do you have an intake fan? (Looks like you took out the stock one to mount the D5)
    And also about how the mallet thing works out for loosening up the panel attachment thingies.
    Nice job! (stupid lightning!)
    edit: fwiw, and maybe you considered this already, but this is a pic, stolen from Performance PC's, of a D5 in a Cosmos 1000 mounted against the hdd cage with one of the (older model) un-design brackets. Gets a nice breeze from the stock intake.
    1200W Thermaltake
    Vista Ult. 64
    Cosmos 1000
    30" NEC
