Results 1 to 11 of 11
Thread: Xfx 7800gtx - Oc?
    Xfx 7800gtx - Oc?
    I just bought a neat XFX 7800gtx and i have some problems..with nvtweak i can try to oc via forceware but in 2D mode i try to set 450mhz for the core and says
    it cannot be set (like to much oc...wtf..)
    I tryed last version of Rivatuner and it does detect 7800gtx but doesnt give me the option to manipulate the clocks..
    I hate that range of clocks and want to set the clocks i like :P
    Greetings guys
    Xtreme News & Reviews
    Apr 2005
    Atlanta, GA
    get the new rivatuner, and make sure you set the 3D Clock
    Desktop
    AMD Phenom II X2 550 (Quad Unlocked @ 3.4Ghz / 2200Mhz NB)
    Gigabyte GA-MA790X-UD4P (F9 Bios)
    8GB (4x2GB) @ DDR2-800
    ASUS GeForce GTX 560 Ti DirectCUII (920/1840/2200)
    Corsair Force GT 120GB
    LSI MegaRAID 8408E (3x750 R5)
    Windows 7 x64 SP1
    Cisco E2000 with DD-WRT kernel 2.6
    I have rivatuner 15.6 and i dont have the overclocking option >_<
    May 2005
    Rye, Ny
    Quote Originally Posted by neosho
    look harder
    May 2004
    Sherbrooke, Quebec, Canada
    Wolfdale e8400es @4.5Ghz / Ultra-120 Extreme
    2GB Ballistix @ 589Mhz 4-4-4-x @ 2.5V - SPI 32M
    *** Motherboards tested: DFI Blood Iron (current), Asus P5K3-dlx, DFI P965-S, P5B-Dlx, DFI RD600, Bad Axe 2, EVGA 680i, DS3 and P5W DH ***
    Fan modded Zippy 850W, 500GB 7200.11 and EVGA 8800GTX @678/1062
    what a help..i used rivatuner with lots of graphic cards and the overclocking options its been always in first icon next to graphic card name.. and with 15.6 it isnt..if there is any option to turn on OC option any of u are welcome to say it..
    Jan 2005
    Budapest, Hungary
    U can find the OC options at the driver settings window ,at the end of the named "ForceWare detected" line.
    Jan 2005
    Budapest, Hungary
    I have a question too!
    When I try to set the core frquency over 520Mhz by rivatuner , than appears a massage like this:
    "The driver failed to pass internal test with the clock frequencies you are about to set.
    Please decrease clocks frequncies and try again
    Can anybody tell me , how can I unlock this option?
    Mar 2005
    do not unlock that option.. u can do so via the expert section of riva tuner.. but doing so gives a performance hit at the same clock.. and u need to force flash a bios to enable the internal test again..
    A64 FX-57 CABCE 0516 WPMW First DI Run
    Jan 2005
    Budapest, Hungary
    I am sorry , but my english is not to good . I can not understand it exactly.
    If I want to set the core frequencies over 530MHz than I should flash a new modded bios into the VGA?
    XS News
    Aug 2004
    Sweden
    You have hit your limit in overclocking the GPU i think.
    If you flash it with 530 i really think you will get problems booting the card.
    Be prepared to blind flash or use an PCI gfx if you want you want to restore it.
    Everything extra is bad!
