Results 1 to 20 of 20
Thread: Sempron 2600+ 64BIT
    Jan 2005
    indonesia
    Sempron 2600+ 64BIT
    i have sempron 64bit....
    n...well i try...
    this my test
    Default 200 X 8
    then....
    299 X 8
    n the last
    310 X 8
    MUSIK KU KERAS
    KOPI KU KENTAL
    KRATON ROKOKKU
    sorri if my english to bad..!!!
    Sep 2004
    i can only see the last pic, and it says it is Thourghbred Socket A ..
    EDIT: now i can't see any pic
    AMD Athlon 64 3200+ NewCastle @ 240 x 10 = 2400 MHz @ 1.550 V
    MSI K8N Neo Platinum 1.52 Beta BIOS
    2x 512 MB DDR500 A-DATA Vitesta Hynix @ 240 MHz 1:1 2.5-3-3-7 1T 2.85V 24/7
    Sapphire Radeon 9800 Pro R350
    Enermax EG365AX-VE FMA 3.3V@32A 5V@32A 12V@26A
    DVD-RW TEAC
    Seagate 200 GB SATA + Maxtor 300 GB SATA
    Jan 2005
    indonesia
    Quote Originally Posted by Ref
    sori...i'am newbie for this....
    MUSIK KU KERAS
    KOPI KU KENTAL
    KRATON ROKOKKU
    Apr 2005
    Mold,Wales
    Must be a bug in cpuz If you look at the instruction set you can see sse2,sse3 and 64bit instructions. Anyway endo what vcore was that at.
    Does anyone know where i can get bananas like this the only ones I can get don't dance and go black after a few weeks
    Xtreme Guru
    Jan 2005
    waukegan
    no crodan, those are correct so is the 64 bit
    mobo: strix b350f
    gpu: rx580 1366/2000
    cpu: ryzen 1700 @ 3.8ghz
    ram: 32 gb gskill 2400 @ 3000
    psu: coarsair 1kw
    hdd's: samsung 500gb ssd 1tb & 3tb hdd
    Sep 2004
    Quote Originally Posted by crodan85
    No, there was a different picture with CBID and SuperPI ... which showed Socket A ...
    now there are links for validation... not pics
    DVD-RW TEAC
    Feb 2005
    my DFI LPUT w/ sempron 64 2800+ couldn't detect the proc's name
    there's no update BIOS from DFI
    http://i11.photobucket.com/albums/a1...x8_sandra2.png
    http://i11.photobucket.com/albums/a1...x8_everest.png
    Jun 2005
    guys, cpuz 1.30 was released recently featuring improved sempron support. give it a shot.
    http://www.cpuid.org/cpuz.php
    [SIGPIC][/SIGPIC]
    IT Engineer in the making
    Jun 2003
    Former Kingdom of Bavaria
    Quote Originally Posted by embuh
    The 623 Bios should support the Sempron. Already tried that?
    Jan 2005
    Bulgaria:Maina Town(Plovdiv)
    please post some Super pi results.
    Jan 2005
    indonesia
    Ref >> sori.....
    crodan85 >> vcore 1.525 V
    embuh >> hey guy's.........
    u're sempron is unlock..??mine is locked..!!!
    high5 & bakcbone & celemine1Gig >> later....
    MUSIK KU KERAS
    KOPI KU KENTAL
    KRATON ROKOKKU
    Xtreme Mentor
    Apr 2005
    Since Semp 2600 is S754 CPU, on what S754 mobo did you manage to get HTT as high as 310 MHz???
    Jun 2003
    Quote Originally Posted by Nedjo
    On the DFI LP UT NF3 250GB a HTT clock of 350MHz (and more) shouldn't be a big problem. You only have to watch the LDT multi. Mine for example only does high HTT with a LDT multi of 1.5, 2.5, 3. Any other multi makes the boards crap out at about 260MHz HTT.
    Jun 2005
    i think he's running dfi nf3.
    but my abit nf8 also does 320mhz htt easy. i even think it could do more, i never really tried. however, i think i will once i get e6 sempron.
    [SIGPIC][/SIGPIC]
    Dec 2004
    Gorssel, The Netherlands
    Endo, did you need a BIOS update to recognize the 64bit sempron? Which BIOS are you using?
    C2D E6300 @ 3.5ghz | 2x1GB ADATA "Micron D9" @ 500 4-4-4-12 2.3v | Asus P5B-E Plus C2 | Sapphire X1900XT 512MB | Tuniq Tower 120
    Feb 2005
    Quote Originally Posted by endo
    which one is unlock?which one is locked?
    Here is my superpi http://i11.photobucket.com/albums/a1...x8_superpi.png --> apacer 512 @210MHz 2-3-3-6,async 7/10
    Apr 2004
    Vietnam
    hey guy ! My friend had 2600+ too... Overklock very good... U can see here...
    http://www.xtremesystems.org/forums/...ad.php?t=70491
  18. #18
    Apr 2005
    Mold,Wales
    Quote Originally Posted by i found nemo
    Yes I know that was what i was trying to say.
    Endo have you tried giving it some more volts as im curious to see what the max is.
  19. #19
    Jun 2005
    1.6ghz semprons are locked. 1.8ghz and higher support c&q so they're unlocked.
    [SIGPIC][/SIGPIC]
  20. #20
    Jan 2005
    indonesia
    Quote Originally Posted by celemine1Gig
    thx.....
    yes dfi NF3 250 Gb.....bios resultfrom board...
    embuh >>>2600+ is lock but 2800+ is unlock
    crodan85 >>> i can't..coz this hsf standar...but..i think u can try vcore to 1.75V...
    MUSIK KU KERAS
    KOPI KU KENTAL
    KRATON ROKOKKU
