Page 1 of 2 12 LastLast
Results 1 to 25 of 35
Thread: I need a recommendation for a new soundcard
    Jun 2004
    US, Virginia
    Right now I'm using the onboard sound on my kv8 pro, I'll be getting a dfi ut for christmas and be using the onboard sound on that. I have 7.1 speakers and I'd like support for thx, dolby 5.1, eax 4 hd and all that crap if possible. I don't really like creative soundcards because.. well I just don't want to support them (altho I own their speakers ) but I don't like how they have a monopoly and prevent innovation. Any other good soundcards? I'd normally just do some research myself, but I just don't know of where to start so I can't really type anything in to google per say. Anyone got any recommendations tho or should I just give in and get an Audigy 2? I don't need anything amazing quality wise as long as it's reasonably good. Mainly I just wanna get it so there is no cpu usage when using the onboard soundcard or I'd just stick with that.
    edit: I use linux too, so good support would be nice, but not a must. Should beable to get it working in Linux either way.
    E8400 @ 3600mhz
    4870 @ 790/1100
    2x2GB DDR2
    Xtreme Gamer
    Jan 2004
    Europe
    i got an audigy 2 since they came out and mim very happy ...and will probably be the best option. or wait for the audigy 4 pro to come out (but it has all the junk most people dont need: external drive blah blah)
    or look into terratec soundcards if u wanna be different
    Intel i7 930 @ 4.2Ghz 24/7
    Asus Rampage 3 Extreme
    Asus Radeon HD 6990
    Corsair Dominator GT 6GB
    Corsair AX1200, 600T
    Intel X25-M 160GB
    Dell U3011 30" Monitor
    Jun 2004
    US, Virginia
    yeah, even tho I'm anti-creative I might just go with an audigy 2. Which I can get for 100$ or less, and the audigy 4 which is almost the exact same costs 200+ from what I've seen. One question tho. Whats the diff. in all the audigy 2's? Like... I think the zs supports 7.1 and the audigy 2 only 6.1 I'm not sure. But like the audigy 2 zs gamer, zs platinum etc... Do they all have hardware decoding (or is it encoding) of all the diff. crap like dts, dolby, eax etc... ?
    E8400 @ 3600mhz
    4870 @ 790/1100
    2x2GB DDR2
    Xtreme Gamer
    Jan 2004
    Europe
    i dont know what u really mean with encoding/decoding ...but all the audigy 2's 'support' EAX, dolby and THX technology ...
    i'd just get whichever u can get cheapest as they are all so alike
    Asus Radeon HD 6990
    Intel X25-M 160GB
    Jun 2004
    US, Virginia
    Lots of soundcards support it, but with software not hardware. So it will encode or decode in software, meaning it'll take cpu cycles to do it, vs the soundcard itself doing it.
    E8400 @ 3600mhz
    4870 @ 790/1100
    2x2GB DDR2
    May 2003
    Dundee, UK
    Check out the Chaintech AV710, Via Envy24 chipset, meant to be a steal at something like $20 compared to higher priced Creative cards etc.
    | 2.4C | IC7-G | G-Skill GH | 6800LE | S12 600W | Viewsonic 171B-2 | 3DMark '03 '05 |
    | MM U2-UFO | Swifttech Storm | DD Maze4 Chrome | DD12V-D5 | Thermochill HE120.3 |
    Dec 2004
    Charlotte, NC
    Personally I think Creative SB is the best for sound cards, but you could always check out the Turtle Beach Santa Cruz ~ http://www.newegg.com/app/ViewProduc...118-102&depa=0
    I had one myself for a while, it worked fine.
    CPU: A64 X2 3800+
    Mobo: DFI Infinity NF UltraII-M2
    Memory: 2gb Corsair XMS2 PC2 5400
    Video Card: eVGA GeForce 7950GT KO 512mb
    Sound Card: SB Audigy
    PSU: 600w OCZ GameXStream
    HD: WD 160gb 7200rpm SATA
    Case: Sunbeam Transformer
    Monitor: 19" Widescreen Hanns-G
    May 2003
    Palm Springs, CA
    If you are a gamer..audig. Zs and up. Nothing else better.
    Music..M-Audio 7.1
    Terratec DMX 6 fire 24/96..a leap in sound quality and a leap in price
    LL V1000B > Asus Rampage lll > Intel 965xx >3x2 Gskill >OCZ SSD 120g > 2x640g wd > ATI 5870 > Corsair 850 HX
    Jun 2003
    Omaha, NE
    i have the logitech z-5500 speakers. What would be the best option that would have optical or coaxal connections so i can hook them up? I game(most), watch dvd's, listen to music, etc. Thanks
    DFI SLI-DR
    x850 xt
    3000+ Venice
    320GB WD SATA
    160GB WD IDE
    xp-120
    2x512 twinmos speed premium UTT
    NEC DVD Burner
    Lian Li V1000
    OCZ Powerstream 520W
    Heatware
    ebay
    Jan 2005
    TN
    Isn't there a herculese 7.1 soundcard thats supposed to have pretty good sound quality? I had a turtle beach soundcard in my old system and it wasnt bad, although I like my audigy 2 better. I would almost have to say to just bite the bullet and get a creative card though.
    Nov 2004
    Sri Lanka,Colombo
    mrnuke i have the logitech z-5500 speakers. What would be the best option that would have optical or coaxal connections so i can hook them up? I game(most), watch dvd's, listen to music, etc. Thanks
    If you game ADGY 2ZS would be the way @ $80 that aint much to pay....You get EAX HD(4)and all that dolby ex and dts es...bla bla crappy drivers but good card....For music it would seem that the M audio would surfice...
    Oh and i think if you use the optical cable all you'll get is stereo sound so i think you'll have to use the coax for gamming(thinking your speakers are 5.1..?)
    new system on the way qx6700||corsair 8500 2X1gb||2x120gb 8mb on raid 0||evga 8800GTX||Adgy 2zs + gigaworks s750||Samsung 244T Mail me here..!
    I am Xtreme
    Jul 2004
    Little Rock
    Quote Originally Posted by kryptobs2000
    WOW slow Thread. Audigy 2 ZS =P. These cards have very good drivers now, not like the bad old days and their updates are just as easy and just like Windows update site.
    Donnie
    XS News
    Jan 2005
    I'd go with the Audigy 2 ZS. It doesn't lag your pc in games.
    Dec 2004
    the chaintech... very good price.. and very good sound, cant say it rivals the audigy 2 zs.. but it puts up a good fight for the price
    DFI LANPARTY nF4 SLi-DR | AMD Athlon64 3200+ s939 .90nm | G.skill Dual Channel Kit 184-Pin 1GBDDR PC-4400 | LeadTek PC6600GT 128mb PCI-E | Seagate Barracuda 7200.7 160GB SATA | Antec Neo Power 480w | Sony DWD22A Double Layer DVD±RW Drive | XP-120 w/ Slienx Fan
    Banned
    Mar 2004
    Huntington Beach, Ca
    i got one of these coming from Korea. Should be here by friday
    HDA Digital X Mystique 7.1 gold. Does 5.1 in just about everything, including through Coax AND Toslink. Something the Soundblasters cant do. Excellent card.
    Review can be found here...
    http://www.avsforum.com/avs-vb/showt...hreadid=511204
    Feb 2005
    A Corner of Hell
    the Creative brand cards are very good and I've never had a problem with one of them.
    Jan 2005
    Carlisle, PA
    Quote Originally Posted by b|gf|sh
    Yea its a freakin awsome card, and the software is very minimal... only 25 bucks brand new from newegg.com
  18. #18
    c[_]
    Nov 2002
    Alberta, Canada
    Quote Originally Posted by madgamer
    GameTheater XP, maybe? Or Fortissimo.. I've got a GTXP and its great but i'm not using it right now..
    After creative refused an RMA on a DVD drive + decoder card (DxR 3) I swore i'd never buy from them again, and I havent yet.
    Heatware || 01.01.08; AND 111.2%
    Dead Z7S-WS? Click!. || XS Z7S-WS Thread || Current Dead Asus Z7S-WS count: 26+ ($15,000 in dead motherboards).
    All along the watchtower the watchmen watch the eternal return.
    Want to use my Anti-asus logo? Go ahead, but use this link please!: http://i853.photobucket.com/albums/a...sus/noasus.gif
    Bring back the game. http://reclaimyourgame.com/. EA are mean.
  19. #19
    Banned
    Mar 2004
    Im telling you guys, HDA Xmystic 7.1 is the only way to fly.
  20. #20
    May 2003
    Dundee, UK
    Been using my new Chaintech AV710 for a few days now, such a big difference over onboard sound Listening to stuff I've not heard in a long time cos everything sounds fresh with this soundcard
    Lacks a global equilizer in the control panel though, so gonna pick up a hardware equilizer at some point now
  21. #21
    Jun 2004
    US, Virginia
    Wow, havn't had a look at this topic for awhile lol, I forgot about it. Seems to have sprung up alot more interest than I last looked. I still havn't gotten a new soundcard, it's not a top priority but I still plan to. Anyone know if the AV710 is supported in Linux as I've been trying to get back into it. The HDA Digital X Mystique 7.1 gold also looked pretty good, but I doubt it's supported in Linux, I'll see if I can find anything. And thanks for all the input guys
    E8400 @ 3600mhz
    4870 @ 790/1100
    2x2GB DDR2
  22. #22
    May 2004
    Asturias
    The AV710 is said to have near audiophile sound quality.
    As far as linux support you need to use the snd_ice1724 alsa driver. IIRC it does not have hardware mixing in linux so this could be a show stopper if you plan on using TeamSpeak. That is unless you have the patience to configure dmix.
    Registered linux user #271604 Get Counted! http://counter.li.org/
    Lian Li PC60, OCZ powerStream 520W PSU,MSI K8N Neo, athlon64 3400+(@220x11),Thermalright XP90C, 1Gb Kingston HyperX (TCCD), Gainward GS 6800GT(@400/1115), Zalman-VF700-Cu, TB SantaCruz, M-audio revolution7.1 > pimeta amp > hd595
  23. #23
    Jun 2004
    US, Virginia
    Whats 'audiophile sound quality'?
    E8400 @ 3600mhz
    4870 @ 790/1100
    2x2GB DDR2
  24. #24
    May 2004
    Asturias
    Audiophile=person who spend's national debt of small african country on Hi-Fi.
    Here are googles definitions. Here
  25. #25
    Xtreme Guru
    Oct 2004
    Cleveland OH USA Bored?: You Know It
    Quote Originally Posted by blueworm
    lol, like your definition there
