XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > AMD
Reply
Old 08-17-2004, 08:58 AM   #1
LardArse
Moderator
LardArse's Avatar
.5X multipliers with AMD64?
Hi guys. I know some people report having bad performance with .5x Multipliers with AMD64, something like the ram ratio dropping. Is it only with certain boards, chipsets or just the AMD64s?
LardArse is offline   Reply With Quote
Old 08-17-2004, 09:11 AM   #2
IvanAndreevich
Xtreme Guru
IvanAndreevich's Avatar
Send a message via MSN to IvanAndreevich
LardArse
I think if you bump the multi by 0.5 to say 9.5, the memory will still run at the same speed as @ 9. Other than that - I haven't tested it yet.
__________________
i5 750 4.20 GHz @ NH-D14 | 4GB | P7P55D LE | 8800 Ultra | OCZ Agility | CM750W | HAF922
Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60
Originally Posted by CompGeek
The US is the only country that doesn't use [nuclear weapons] to terrorize other countries. The US is based on Christian values, unlike any other country in the world. Granted we are straying from our Christian heritage, but we still have a freedom aimed diplomatic stance.
IvanAndreevich is offline   Reply With Quote
Old 08-17-2004, 09:14 AM   #3
LilGator
LilGator's Avatar
Send a message via AIM to LilGator
Actually I think it is rounded up, hmmm:
Like 9.5x200 = 1.9GHz
1900MHz / 10 (9.5 rounded up) = 190MHz RAM
__________________
LilGator is offline   Reply With Quote
Old 08-17-2004, 09:16 AM   #4
LardArse
Moderator
LardArse's Avatar
What do you mean I dont get?
If I boot up at 9.5X and clockgen it to 266FSB 1:1, will it stay at 266?
Old 08-17-2004, 09:17 AM   #5
LilGator
LilGator's Avatar
No, your RAM will be running 253MHz
Your RAM will be CPU/10 with a 9.5x multi.
It will be CPU/11 with a 10.5x multi.
Just round up for your RAM divider.
__________________
Old 08-17-2004, 09:19 AM   #6
LardArse
Moderator
LardArse's Avatar
Crap, that sux
Old 08-17-2004, 09:21 AM   #7
LilGator
LilGator's Avatar
It's just the way the RAM controller is, CPU is divided by an integer Doesn't hurt performance though, not running 1:1, since 1:1 doesn't exist on Athlon64...
__________________
Old 08-17-2004, 09:31 AM   #8
IvanAndreevich
Xtreme Guru
LilGator
Yeah but you do get lower RAM speed than you would get by bumping the FSB..
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
