Can someone who has a 6800 make a 6800 waterblock template (just use like a posterboard, make a simple square with the actual core (another square) drawn dead center, and then the 4 holes. I can give you 10 dollars paypal to do all this.
4 holes equally spaced apart at 53.5mm. You will need 2 to 2.5mm thin scrfews to fit thru the holes.
That will be $10 thx
Just kiddin of course, but I didn't take any measurements of the core, bigger than ATI but smaller than the ones with heatspreaders.
Well, I was hoping for an actual physical template because even though your measurements may be correct, making a mounting screen for a waterblock requires exact measurments. For instance, is that 53.5 mm from the middle of the holes or from the right side of the holes, or left side. I need better measurements if i were to use just pure measurements wihtout the template.
thanks so much for your help.
centre of holes to centre of holes
hey lardarse do u have the picture with the mounting holes for s462/s478/s754 all on top of each other?
can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
Heres that pic blinky
-Phenom2 x6 1055 @stock
-8gb ddr3
-Gigabyte UD3
-Geforce 7900Gt 755/1863 1.562v vgpu
-OCZ Powersupply 600w
is there a newer one with s754/s940/s939 (all the same), if not i could make one when i get my A64 moboOriginally posted by lalPOOO
you can just make the holes bigger...Originally posted by quicksilverXP
can someone measure the the shimfor mepleaase? Thanks again inadvance. And also if the shim is easily removable, in comparison to removing a 9xxx series card.
Might those holes be just like they were back in the GF4 Ti times? Some models, like my Gainward cards, had 4 holes also.
Intel i7 8700k | AsRock Z370 Gaming K6 | G.Skill TridentZ PC4-3200 | Gainward GTX 1080 Phoenix GLH | Seasonic Prime Titanium 650W
