Results 1 to 19 of 19
Thread: GeXCube 9600XT Voltmod(urgent)
    Apr 2004
    Hi guys.
    Having the following problem.
    I've found this picture-but am not sure where to attach the second end of the variable resistor.
    I circled it yellow.
    Please say, where do i attach it(i have an idea to solder it to a place circled green-is that correct)
    Dec 2003
    OC, California
    If you have a meter make sure that the leg circled of that ic is not ground. If it isn't, any ground should work.
    Custom Baker18 R22 cpu/gpu cooling
    3D01 41889 3D03 18256 3D05 8011
    Apr 2004
    Sorry, mate. But could you please explain how to check whether it's ground or not.
    To which legs do i connect the meter, and what am i looking for?
    Dec 2003
    OC, California
    Set the meter for continuity with a beep if you have it or set it for ohm's.
    Put either one of the leads let's say red, on the leg of that chip that you are supposed to solder to. Than put the other lead the black one onto the metal part of the card the attaches to the cases. It should not beep or read 0 ohms. If it does beep or show 0 ohms than that leg of the ic is actually ground.
    Apr 2004
    Thanx a lot, check everething-it's done.
    have 1.498v but only 660 core clock (.
    Nov 2003
    only?
    1.5v is a lot, too much for stock cooling...
    Intel 2600K @ 4.8ghz 1.31v on Water.
    ASROCK Z68 Ex4 Gen 3, 16GB G.skill pc1600
    MSI GTX 680 1200/6800mhz
    2x Vertex LE 60GB Raid 0
    Feb 2004
    1.5V with stock cooling IS a lot for a core designed with 1.3V in mind. Run it a bit lower
    Dec 2003
    Cape Girardeau, MO
    I'm running mine at 1.4v and have a 640Mhz clock. try lowering the voltage to 1.4v and then work upwards until you don't see any improvement.
    And replacing your stock cooling is a must if you're going to push your vcore past 1.4v. That little chip puts of some decent heat when you raise the voltage and core clock that much.
    Q6600 @ 3.4ghz 1.33v
    Evga 680i
    8800GTS 640
    2gb Adata Extreme
    OCZ Gamextreme 600w
    Feb 2004
    Hong Kong
    by the way, i am using watercooling with my GeXCube 9600XT (-2.8ns Samsung Version), which voltage is safe for the Core and the Ram??
    Dec 2003
    Cape Girardeau, MO
    damn...don't think you'd need watercooling ,but then again...why not!
    I think the voltage would depend on your card. Mine seems to get flaky when I go above 1.45v. In flaky, I mean that sometimes I'll get artifacts, sometimes I won't, and almost all the time I won't be able to clock the memory as high (almost like it's starving for more power).
    Evga 680i
    8800GTS 640
    2gb Adata Extreme
    OCZ Gamextreme 600w
    Nov 2003
    with water, Try to use a POT/trimmer and go for 1.4V gpu to start.
    see ifits stable at relativly unmaxxed speeds.
    and continue to up the voltage to a max of 1.5V, some chips just artifact nomatter how good of cooling and speed.
    my core won't do over 1.35V w/o artifacting on good 1u cooling.
    3v Max on samsung 2.8 chips only if u got ramsinks.
    Apr 2004
    Actually guys, i have zalman cooling on my card, so there's no problem of overheating(i also check it with my hand).
    Probabbly i got an "unlucky" card, therefore it's so poor at overclocking. I reach 660-but it's eXtrim for my card- it creates lots of artifacts.
    ATI Tool is very time consuming and goes around 580-600, even despite that high voltages.
    Apr 2004
    !!! Help...
    I set up core clock to , for instance, 621. It passes all the omega driver artifact tests. But, when i start 3d mark or a game(i tryed Flight Simulator 2004) after a few minuts(seconds) the screen goes black(as when it is in a "sleep" mode). BUT ! computer still responds to some key on the keyboard!!!.
    I can turn it off by a Power Key on the KEYBIOARD, also i can Num Lock, etc.
    Does anyone know what are these simptoms all about?Please help.
    Feb 2004
    Germany
    !!! Help...
    HAppens if you OC the gpu too much. Lower your clock frequencies or raise the voltage. Passing the Artifact tests doesnt mean stable clock frequencies on the 9600.
    -100C Club Member
    Feb 2004
    australia
    what program do i need to download to oc these cards.
    does anyone know of a web address
    Dec 2003
    OC, California
    rivatuner powerstrip atitool radlinker
    http://downloads.guru3d.com/download.php?id=13
    -100C Club Member
    Feb 2004
    australia
    thanks
  18. #18
    Dec 2003
    Cape Girardeau, MO
    yup...what is happening is the GPU is not responding. There is an option in the drivers for this called GPU recover. most of the time it works. If I clock my card above 655 I get the same thing. So I run at 645 normally.
    Evga 680i
    8800GTS 640
    2gb Adata Extreme
    OCZ Gamextreme 600w
  19. #19
    Apr 2004
    Ok, thanx for help guys. Finally working 630/630.
    Havent tryed memory yet. According to Spec it should clock 700(2.8), by default-650, by me 630 for sync.
