XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > AMD
Reply
Old 05-12-2006, 04:53 AM   #1
sai
sai's Avatar
"Frame" for IHS-less CPUs?
Hi, I'm curious about if anyone built a frame yet against chipping the core when you removed the IHS. I got a Scythe Ninja CPU Cooler and I think it's nearly impossible not to break something when the IHS is removed. Please help me, I know you guys always know a solution to everything!
I'm going to slice it today if anyone got a good idea ;-)
__________________
sai is offline   Reply With Quote
Old 05-12-2006, 06:03 AM   #2
MikalCarbine
Xtreme Cruncher
MikalCarbine's Avatar
Send a message via AIM to MikalCarbine Send a message via MSN to MikalCarbine
Would the little pads from a 3200+ Barton bed sufficient for something like this? Or are the heights of the core dramatically different
__________________
Heatware | Abit IP35 Pro | Intel E6750@3.8Ghz 1.56v | Storm R2 | Ballistix DDR2-8500 | Sapphire HD3870 512MB@TBA | MCW60 | WD Raptor 74GB | WD2500KS | OCZ GameXSteam 600w | SoundBlaster Audigy 2 ZS | DT770/80Pro | WinTV PVR-250 | Antec P180 | 7 Yate Loon D12SL-12 | AQ50Z | PA120.2 Custom Painted | BIP GTS 120mm | MasterKleer 7/16 Tubing | VX924 | G15 Keyboard/G5 Mouse/Steelpad QCK+
MikalCarbine is offline   Reply With Quote
Old 05-12-2006, 06:33 AM   #3
Eldonko
Eldonko's Avatar
Should be good yeah, or you can order shims here. You will need a few though because they are thin.
__________________
Eldonko is offline   Reply With Quote
Old 05-12-2006, 06:37 AM   #4
largon
Xtreme Guru
largon's Avatar
Radeon X800 serie GPUs have a shimm that fit perfectly for K8.
X800 shimm on top of a S939 IHS:
__________________
You were not supposed to see this.
largon is offline   Reply With Quote
Old 05-12-2006, 07:46 AM   #5
MikalCarbine
Xtreme Cruncher
Do you know how high the A64 core is compared to a Socket A chip? I have a socket A shim lying around and a dead 3200+ I could take those pads off of, that would be perfect if I didn't need to get another shim, but I assume I will because you said I will need more than 1
Edit:
What about a 7800GT shim? I could yank mine of my 7800GT then ahah
__________________
Old 05-12-2006, 07:54 AM   #6
largon
Xtreme Guru
largon's Avatar
K7 CPU package is 10mm larger than K8 (50mm vs. 40mm) so a S462 shimm won't work without abuse.
__________________
Old 05-12-2006, 07:55 AM   #7
Eldonko
Eldonko's Avatar
Shim thickness should be .029 inches +/- .001. Tarccm measured his custom shim with digital caliper, heres a pic.
__________________
Old 05-12-2006, 09:44 AM   #8
MikalCarbine
Xtreme Cruncher
Now if I only had a digital caliper to measure mine
__________________
Old 05-12-2006, 09:55 AM   #9
sai
sai's Avatar
Originally Posted by coolingbug
Use some Adhesive-Back Neoprene Strip 1/32" 50A Durometer sheet and cut 4 strips and stick around the core. Its a tad higher than the core, but under the right pressure 50-75lbs will sink so core contact is perfect.
That would be...in germany
__________________
Old 05-12-2006, 11:49 AM   #10
MikalCarbine
Xtreme Cruncher
Just popped my IHS, the K7 shim was (like stated before) much larger than the k8, too large to even bother using...
I used my 3200+ Barton rubber pads on the corner of my 4200+ (attached using a drop of super glue)
Sorry for the crappy picture :P
I shaved the silicon that was holding the IHS down on the corners, making the rubber pads more even
__________________
Old 05-12-2006, 02:39 PM   #11
safan80
Xtreme Guru
safan80's Avatar
so lets hear what kind of temps your running.
__________________
Watercooling parts:
Pa120.3 rad (CPU)|PA120.3 (for video card)|GTZ on CPU
|stock cooling on chipset|Laing DDC w/ Petra'sTech DDCT-01s Top on cpu loop|aqua extreme 50z pump on gpu l
cpu i7 960 @???
old cpui7 920 3836A762 @ 3.7Ghz
Gigabyte EX58-UD5 F9e bios
12GB of G.skill (6 x 2GB)DDR3 perfect storm F3-16000CL8-2GBPS 7-7-7-21
2x bfg 285
new Dell 30"LCD 3008wfp oh the colors!
LG GGW-H20L
COOLER MASTER Real Power Pro RS-C50-EMBA-D2 1250watt for the cpu/mobo & video
OCZ600MXSP 600W for the hard drives
areca 1280ML with 2GB ecc of cache running in other 16x pci-e slot with battery backup running two raid 10 arrays 2TB boot array 6TB storage
sound card: Auzentech Forte 7.1 | Gigaworks S750 7.1 speakers
OSes: debian Linux unstable, and Windows XP pro x64 w/sp2| testing windows 7 x64 ultimate
safan80 is offline   Reply With Quote
Old 05-12-2006, 02:43 PM   #12
aMp
aMp's Avatar
I just found a high-durability rubber band that was about 30% thicker than the core, put a few pieces on the sides of the chip, and relied on the compression ratio to get good contact. Worked like a charm.
__________________
"Did a spork hit the pentagon?"
Dengyong
165 @ 2.9 @ 1.45V | 2x1GB G.Skill HZ | NF4 Ultra-D
MSI X1900XTX | G500 21" Trinitron
X-Fi Fatality | Z-2300s | Little Dot MkIII | Beyerdynamic DT770 Pro
TDX | Maze4 GPU | DDC Topmodded | BIP3
Stacker STC-T01
aMp is offline   Reply With Quote
Old 05-12-2006, 02:47 PM   #13
Eldonko
Eldonko's Avatar
Thats a good idea
__________________
Old 05-12-2006, 02:54 PM   #14
Aphex_Tom_9
Aphex_Tom_9's Avatar
Send a message via AIM to Aphex_Tom_9
heh, when i was mounting my old 3400+ DTR under my Mach, i used cut up credit card bits glued around the core area.
__________________
(will be updated shortly)
Aphex_Tom_9 is offline   Reply With Quote
Old 05-12-2006, 03:02 PM   #15
MikalCarbine
Xtreme Cruncher
22 idle, 29 load
used to be 24 idle 34 load
Hasn't help my overclock that much (at stock volts at least) I think I got a single MHz out of it
__________________
Old 05-13-2006, 02:27 PM   #16
tarrcm
Hey man, not that much of a deal to make one & no digi cal is necessary. I made one from 0.05 inch al sheet, used a flat file to get it to match, checked it by using a straight edge over the core & then fine tuned it by applying TIM to core & mounting dice tube or evap head or stock air cooler for contact. A little patience & elbo grease is all it takes, here's a link that might be of interest:
http://www.xtremesystems.org/forums/...7&goto=newpost
__________________
AMD Athlon FX57
DFI NF4 Expert
Crucial Ballistix Tracer (2x1GB) PC4000
Mushkin Redline XP4000
850 SSI PSU
tarrcm is offline   Reply With Quote
Old 05-13-2006, 02:56 PM   #17
nn_step
YouTube Addict
nn_step's Avatar
Actually this is what I use.. the Cores are EXACTLY (to 0.002 mm) the same thickness
__________________
Impossible is not a fact; it is an opinion. Impossible is not a declaration; it is a dare.
It's hardware that makes a machine fast. It's software that makes a fast machine slow.
Fast computers breed slow, lazy programmers
Algorithms + Data Structures = Programs
And all of that source is portable, except for this tiny kernel that you can (provably: I did it) re-write totally from scratch in less than a year without having /any/ prior knowledge.
-Linus Torvalds
http://www.youtube.com/watch?v=ANtpsunRYIs
http://www.youtube.com/view_play_lis...23537556D7AADB
http://www.youtube.com/watch?v=QTcFLp1uVZ4
Science is simply common sense at its best that is, rigidly accurate in observation, and merciless to fallacy in logic.
http://pix.motivatedphotos.com/2009/...raindamage.jpg
nn_step is offline   Reply With Quote
Old 05-14-2006, 03:19 AM   #18
tarrcm
Correction
Although I did make some using 0.050in sheet al THOSE WERE NOT THE ONES I USE.
The following pics tell all. As you can see I used 0.025in sheet al and took off 0.001 to 0.002 off with a fine flat file 'till it gave the contact I was looking for.
Apologies for the previous post & to you Eldonko for my mistake. Note that the calipers are only useful to reproduce or record dimensions, not necessary to make one, simply go by the fit
The goopy stuff is LET I used to hold everything in place.
__________________
AMD Athlon FX57
DFI NF4 Expert
850 SSI PSU
Old 05-14-2006, 10:02 AM   #19
Fission
Fission's Avatar
high-durability rubber FTW.
Fission is offline   Reply With Quote
Old 05-14-2006, 10:18 AM   #20
nn_step
YouTube Addict
nn_step's Avatar
Please stay on topic
__________________
-Linus Torvalds
Old 05-14-2006, 03:08 PM   #21
MikalCarbine
Xtreme Cruncher
But would it work?
__________________
Old 05-14-2006, 03:09 PM   #22
Eldonko
Eldonko's Avatar
Ah so 0.024, thanks for the clarification.
__________________
Old 05-14-2006, 05:54 PM   #23
Fission
Fission's Avatar
But would it work?
lube/jelly washed off it, I assume that it would be some of the densest rubber available, and can be rolled to fit the size you need. And of course, if you had to smuggle the proc into jail, well...
Old 05-14-2006, 05:55 PM   #24
eBoy0
eBoy0's Avatar
Send a message via AIM to eBoy0 Send a message via MSN to eBoy0
I'm ganna try plexi shim a try
Edit: Nvm unless i really heavily sand it down, it's too thick.
__________________
Originally Posted by nn_step
Well CPUs are like women they all like things specific ways for them.. Some love 8x and others Love 9x or 7x.. they all just have their G-Spot and you have to learn to use it..
q6600 @ 2.6
EVGA 680i
OCZ fatal1ty ddr2 800
8800gt SLI
watercooled
eBoy0 is offline   Reply With Quote
Old 05-14-2006, 05:56 PM   #25
MikalCarbine
Xtreme Cruncher
LOL
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
