XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 04-26-2006, 09:54 AM   #1
aasmaukr
aasmaukr's Avatar
Send a message via MSN to aasmaukr
Mitsubishi rotary wiring help
I just got this cute rotary, not sure if he works, but i am going to find out
I just need a little help from you regarding the wiring... How do i do?
aasmaukr is offline   Reply With Quote
Old 04-26-2006, 01:00 PM   #2
star882
star882's Avatar
Based on the wire colors, connect the red wires (from compressor to capacitor), the blue wires, and the white wire should be the neutral and the brown the hot.
To be really sure, the overload protector should be in series with one of the supply lines (preferably hot) and the capacitor should be in series with the start winding.
__________________
Originally Posted by A HVAC friend of mine
If Hannah was an air handler, I would be a condensing unit so I could open her TXV and pump my refrigerant through her evaporator coils.
star882 is offline   Reply With Quote
Old 04-26-2006, 09:11 PM   #3
skirms_fr
skirms_fr's Avatar
__________________
Signature removed.
Links in signatures to unapproved and/or unaffiliated sites is not allowed.
Re-read the Forums Policies & Guidelines.
Signature edited by IFMU
skirms_fr is offline   Reply With Quote
Old 04-26-2006, 09:19 PM   #4
wdrzal
I am Xtreme
wdrzal's Avatar
star is correct reconnect the blue and red to capacitor,the wire left on capacitor & white wire from overload disc connect to plug.
It looks like someone took the time to close off the tubes properly, so I bet it came from a known working unit.
__________________
http://xtremespeakfreely.com/forum/
Register today .
The Laws of Thermodynamics say:
Zeroth Law: "You must play the game."
First Law: "You can't win."
Second Law: "You can't break even."
Third Law: "You can't quit the game."
Do you wanna Play Thermodynamics ???????? I forgot "you must"
wdrzal is offline   Reply With Quote
Old 05-01-2006, 04:08 AM   #5
aasmaukr
aasmaukr's Avatar
OK, thanks, it seems to work fine.
I was the one who closed off the tubes btw.
Only i got no idea of the specs on this compressor.. It weighs about 16kg.
Some numbers written on it:
87-04-08
RK5515GNE1
AHA201A070A
DPH 30 DPL 13 R-22
2P 1PH 220/240V 50Hz
Does someone know anything about it?
Thanks..
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
