Hey Guys, started modding my P180 on Tuesday and I just got the water cooling set up tonight. I know how you all love pictures, so there are lots of pictures included!! Before we start, sorry for any slow download speeds, I had to host all the images off of imageshack, due to lack of webspace and no time to convert all the image sizes
A simple mod I have done a while ago with some aluminum tape
Planning out my radiator tubing holes
Radiator tubing holes drilled out (unfinished)
Box of wheat thins placed under drill zone
Hole for DD Fillport
Drilled the rivets out of the bottom 5 1/2" bay (then took bay out)
Small mod for wire management (forgot to take picture of the other side, which much more was taken off)
Front grill mods (can still use filter too)
I used the screw hole that was for the upper hard drive rack as a guide for mounting my pump. I opened it up a bit, and then drilled another, cutting it close to the floppy drive
MCW60 looked pretty funk after cleaning it (24 hour vinegar, instant distilled water flushing)
Had to mod one of the loons for the radiator (will have to do for upper exhaust in case)
The rig leak testing
Closer Looks
What do you all think?
Getting the tubing on all the fittings was a royal ! That pump is damn loud, I don't know if it is the way I have it mounted, and the fact it is open case at the moment, but I can hear it from my doorway of my room
I have some Vavoline Super Coolant, but I am figuring I don't need it? The storm and MCW60 are copper, so is the radiator (?)
That being said, should I make a trip to the fish store and get some of that anti algae liquid?
I would also like to thank everyone that has helped me out, especially MaxxRacer and Creidiki
