03-09-2006, 09:37 AM
#76
Xtreme Mentor
I thought the dongle is just used for the two cards to communicate. How will the dongle help with bandwidth? Regardless of the dongle, the information still has to travel through the PCIX slots.
Anyways that doesn't matter as xfire is useless for me. I just want to know is it easier to clock the memory on the new board.
__________________
Asus Rampage Formula X48
Intel Q9650 @ 4.33GHZ
OCZ Platinum DDR2-800
Palit 4870x2
Creative Xi-Fi Extreme Music
Corsair HX1000
LL 343B Case
Thermochill 120.3
2xMCP355
KL 350AT
KL 4870X2 FC WB
DD Chipset Block
03-09-2006, 09:50 AM
#77
No rest for the weary
Hmm easier is the wrong word and the wrong reason I would think. With more settings It tends to take more time. Etc this board not only has weak and normal Dram drive strength, it also has P and N DDR drive strength settings from 1-15 for both. I would be more interested in if it can clock memory higher than the previous board and am working on that now.
__________________
heatware chew*
AMD is Back in Black Lifes more fun at -190C
How To Behave On An Internet Forum
http://www.thewavingcat.com/2008/02/...eed-the-troll/
http://www.livestream.com/chewsdisasterarea
Originally Posted by Sampsa
1) Normal ES: Available to partners and press before the product actually launches. These are usually close to retail parts, maybe one stepping/node before retails. From my experience (I've had access to AMD & Intel ES CPUs before the official launch around 8 years) normal ES CPUs are actually usually worse than retails because manufacturing process develops all the time and retails keep getting better. Every Phenom II press sample (not even marked as ES but couple weeks earlier than retail parts) I've tested so far have been worse than normal retails.
03-09-2006, 10:07 AM
#78
hmmm
There is no reason that two X1900's cant go dongle-less just like 2 X1800's.... other than ATi feels like having it that way. Just like there is NO reason the cards cant work in NF4 boards other than ATI coded thier drivers to forbid it. Enough with the BS.
And if the bandwidth is a bit too low for best results dongle-less... then just turn up the PCIe clock from 100Mhz to 150Mhz. Certainly a 50% increase in clock speed will fill in the gap.
Time for ATI to knock off the crap and pull the prohibitions out of the drivers.
You wanna sell me 2 X1900's.... then allow them to work in my NF4 SLI-DR, sure it wont be as fast as using the dongle, but Ill live. Eventually if the RD580 based boards get good enough, Ill consider switching. Im certainly open to that, but if the RD580 boards cant at least EQUAL the performance/feature abilities on the NF4, why the hell would I bother.
Taking two steps back to take one step forward is pretty dumb. How about one step forward and ANOTHER step forward instead?
Meantime on RD580 testing, time to see how far BH5 2x512 and 4x512 go, as well as TCCD and Ballistix goes. Get'er done.
__________________
GA-MA790GP-D4SH, 940BE, 2x2G Gskill 1066
under test
Foxconn 590SLI, 5600+ @ 246Mhz x14
1.525Vcore, 1.35,1.35,1.35,1.525,1.5 chips
2x 2G GSkill 1066 5.0,5,5,15 @2.0V
P34 bios, 2x 150G VRaptor raid, 250G-IDE
8800GT 735/940/1685, LG-BluRay
03-09-2006, 10:26 AM
#79
I'd like to see UTT BH5 results. Vdimm options are still good right? If I can get 270 2-2-2-5 still with 3.6v I'll be happy  Might even sell my DFI boards and pick this up if possible...
03-09-2006, 10:37 AM
#80
Chew, please drop the multi and max out the HTT.
Pics of the board and such might be nice too
Thanks!
03-09-2006, 11:22 AM
#81
drop multi and max out Htt? I already ran 9x300x5x Ht mutli........ you want more than 1500 total Hyper transport speed? As far as pictures go I suggest you re read post # 1.
Vdimm options are still good yes.
As far as Bh-5 goes I only have 2x256 mb sticks........Same goes for Tccd. They are benching sticks and that is there sole intended purpose........Seeing as how real TCCD and BH-5 are no longer available or very rare I would think it is inconclusive.....2 gig dimm performance would be more realistic for most users. Of course since my bank account is dry atm I have no plans to purchase 4x512mb dimms just to test. If anyone want's to send me ram for testing i will do so....otherwise you'll have to live with what i have which is the following 2x256mb bh-5, 2x256mb TCCD F1 LA week 440, 2x256mb TCCD F1 LE week 437, 2x 256 crucuial ballistix pc 4400, 2x512 mb Corsair speed binned UCC pc 3200( i run at ddr 500 ) 2x1gig OCZ infineon 2-3-2-5 Pc 3200 and last but not least my personal favorite 2 gig OCZ plats EB PC 4000. I also have a bugdet set of 2x 512 supertalent pc 3200 that i can test for those who want to know if they can get away with using cheap ram on this board........
__________________
heatware chew*
03-09-2006, 11:37 AM
#82
I think he is meaning 400htt x 3 or something
Opteron 144 need atleast 350htt+
03-09-2006, 12:44 PM
#83
I'm ready to drop the hammer on this puppy as soon as I hear go...
03-09-2006, 01:19 PM
#84
What I meant.
Sorry about the pic-request
03-09-2006, 02:14 PM
#85
Support
I've seen Macci running 390x4 in the lab. The only trick is that one of the memory timing parameters (read preamble I think it was) needed to be changed at such high HTT...which is specifically a CPU thing...not chipset.
For all practical cases, x4 (800MHz mode) is the lowest you need to go...and that will be above 320htt. For anything lower, x5 (1GHz) should be okay but it does depend somewhat on the processor so results do vary a bit. But that is the ballpark.
03-09-2006, 02:25 PM
#86
Memory Addict
But does HTT bus on ATI chipset make a diff in performance unlike NF4 ?
03-09-2006, 03:20 PM
#87
Understandable since you don't have the stuff. However, I'd definitely disagree that just because TCCD and BH5 are hard to find now that it's less realistic, just look where you are  . As for the UTT BH5, I believe the G.Skill GH still uses that and a lot of people are still using older Redline, OCZ VX, etc. Maybe somebody with 4x512 of that stuff can let you borrow some for a while and see how the Sapphire board works with it. Either way, keep up the good work!
03-09-2006, 06:06 PM
#88
Drop it where? I don't think it's available yet......
__________________
Rampage II GENE - Bios 904
i7-920 SLBCH (3841A826)
Scythe Mugen 2 - Antec 180 Mini
CORSAIR DOMINATOR 6GB (3x2GB)
24/7: 3.80 @ 1.184V (AIR)
Prime Stable: 4.4 @ 1.435V (AIR)
Windows 7 MS Is Getting Better...
03-09-2006, 06:21 PM
#89
Just a quick test. 4X ht multi.....
__________________
heatware chew*
03-09-2006, 06:40 PM
#90
Grayskull do you have any insight to why Sapphire went with the SB450 southbridge and not the ULI? Is it because of the close relationship with ATI or what?
__________________
Foxconn Blood Rage GTI| Core i7 920 D0@4GHz| Corsair H50| 3x2 GB Corsair Dominator GT 1600 MHz 7-7-7-20| HIS Radeon HD5870 1024MB| Intel 80GB X25-M G2| Cooler Master Silent Pro M1000W| Cooler Master ATC 840|
03-09-2006, 06:48 PM
#91
I would guess as to the fact that they used the SB as there is nothing wrong with it in real world applications........
__________________
heatware chew*
03-09-2006, 07:26 PM
#92
XS in Sin City
Isn't the SB460 pin-compatible with the 450? That would be my guess as to the reason....
__________________
03-09-2006, 08:15 PM
#93
id take a working board with a crappy southbridge than a pos with sata 2 and better usb that i use for my ipod, printer and memory sticks...
03-09-2006, 09:16 PM
#94
What is this master card and dongle issue you guys are talking about?
Will a RD580 board work with just one nVidia card?
__________________
Opteron 165 0550 UPMW Reatil With Retail Heatsink
DFI Ultra - d
Enermax Liberty 500
2 GB GSkill UCCC
Leadtech 6800 GT
WD Sata2 250 GB KS
XP SP2
Stacker STC101
03-10-2006, 01:03 AM
#95
Yes it will. Pay no attention to the thread crapper. He's just ticked off that he can't run 2 ATI cards in an nvidia board but for some reason doesn't bash nvidia for the same thing....
The mastercard and dongle is still required for x1900 series cards however is not for x1800 or lower.
__________________
heatware chew*
03-10-2006, 02:30 AM
#96
Chew,
I got a question for you ...
I am new to Amd systems ... I actually just built my first Amd OC system with the specs below and I am currently geting a 1000 Mhz OC at stock volts with an Amd Stock 165 heatsink on a Ultra -d.
Now, I have another retail 165 UPMW with even a better batch number of 0069 [ I learned about the batch number issue reading one of your threads and if it the last four digits on the third line then it is indeed #0069 ] ... do you think an RD580 board will give me even a better OC on air than I am currently getting with the Ultra -d? 311 HTT, 9 multiplier, 3 LDT [ never tried any other ldt ]
The reason I bring up LDT is because from my reading, the RD580 will run at a 311 HTT with a 4 or 5 LDT but how much actual real program perfomance gains will that accumulate to, if any at all? I use 3d programs ... will a 165 [ 311 htt, 4 ldt ] render faster than a 165 [ 311 htt, 3 ldt ]
I am looking for a board to go along with this ' better batch ' 165 but I am not sure how much more this 1.8 Ghz can actually OC to
__________________
DFI Ultra - d
Enermax Liberty 500
2 GB GSkill UCCC
Leadtech 6800 GT
WD Sata2 250 GB KS
XP SP2
Stacker STC101
03-10-2006, 06:42 AM
#97
I'm honestly not sure if there are any gains atm as i havent tested but when i ran 4x Ht by 370 last night and was copying ,pasting, uploading, and posting the machine appeared to be running alot quicker. Ill have to do some further testing on that. As far as a higher OC I wouldn't go as far to say that but as a more stable platform i will say yes. Once its dialed in right from my experience its set it and forget it. No cold boot issues,warmboot issues, or any other issues.
__________________
heatware chew*
03-10-2006, 12:24 PM
#98
Originally Posted by Grayskull
The updated bios for the PI 480 board is ready according to Sapphire and should go up before the end of the week. This is what we are being told.
Finally!
I would like to see some side by side comparisons of running 5,4,3X LDT with the same HTT to see what are the performance numbers...
Also, let's say for arguements sake, 340HTT is the highest at 5xLDT, how much of a diff in performance is it at let's say 400HTT at 3XLDT?
I'm sure Chew* will answer all of these.. Great work man
03-13-2006, 10:47 AM
#99
Xtreme Mentor
Did this thread fall off the face of the Earth?
__________________
Palit 4870x2
Corsair HX1000
LL 343B Case
Thermochill 120.3
2xMCP355
KL 350AT
KL 4870X2 FC WB
DD Chipset Block
03-13-2006, 11:14 AM
#100
I am Xtreme
Hey chew great work on that thing, you are about a week ahead of me, crapload of memory timings on this thing makes for onr hell of a learning curve, i did some math and just playing with the 5 different drive strength areas alone gives 1560 different combinations.
so far ive gotten 315x10 with the 5x htt on my opty 146 with this thing, amazing!
Not trying to steal your thread chew, but heres mine, with pics of the board, i wont link it again:
http://www.xtremesystems.org/forums/...ad.php?t=92443
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
