Page 6 of 8 FirstFirst ... 345678 LastLast
Results 126 to 150 of 200
Thread: Apple Core Solo to Core Duo upgrade.
  1. #126
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    And the distributed processesing community as well. Showing how strong they are will surely attract buyers for low cost, low power, dual processor nodes.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
  2. #127
    Mar 2006
    2,16 YONAH on Core solo mini - confirmed working!
    Thanks FUGGER for this great work again!
    Since about 2 hours my mini runs with a core duo 2,16 GHz, absolutly flawlessly, im very happy with it!
    And it is very speedy now!
    If someone wants me to do some benchmarking please respond and tell me how to do it, i think it would be very informative to have benchmarks for a mac min core duo 2,16 GHZ with 2 GIG RAM and a 7200 rpm drive (100 GIG).
  3. #128
    Mar 2006
    thats my exact setup I will try to do some bench marks over this weekend
  4. #129
    Oct 2003
    USA/Norway
    Exclamation
    can the macbook pro, the mac mini or the imac be overclocked?
    is it possible to copy the firmware from the 2.18 to the 1.83?
    or can you get into the EFI and clock it from there? or is it a hardware transistor on the motherboard?
    I would like to know! PLEASE!
    PowerBook 1.83/2gb/100gb
    waiting..... PowerMac Quad baby!
  5. #130
    Mar 2006
    Quote Originally Posted by bernie_the_one
    Fugger, i'm in the process of upgrading my mini to 2,16 GHz like you did, i upgraded the mini with 2 GIG of RAM , a 100 GB 7200 rpm Drive and a Pioneer DVR-K06. Everything seems to work flawless so far, tomorrow i will get the ES 2,16 GHz dual-core CPU and will drop in this last part of my update.
    Hope it works! Some picts and maybe a .mov which shows how to replace the cpu will be posted on the web soon.
    Any recommendations for extra-cooling or is there nothing more needed?
    Thanks for this great thread, will point back to your forum in my posts.
    -- bernie
    Did you need to use PatchBurn to get the DVR-K06 to work?
  6. #131
    Mar 2006
    Quote Originally Posted by kaidomac
    No Patchburn needed for me. Starting from an OSX CD works great, Burning in the Finder or TOAST works, iTunes works, iDVD not tested yet. DVD-RAM works via Disk-Utility and Finder, so nothing more needed for me..
  7. #132
    Apr 2006
    Hello
    Did someone tryed the new firmware for the mac mini? Can we still change the processor or did Apple blocked it??
  8. #133
    Mar 2006
    Quote Originally Posted by faquin
    Hello
    No Problem here, Firmware and update to 10.4.6 runs smoothly. WIN XP flys under the 2.16 dual mini with BootCamp!
  9. #134
    Dec 2004
    can you run some benches in xp with the mini?
  10. #135
    Jan 2005
    NJ
    yes please do!
    CPU Z:2700 2k1:27952 2k3:12282 2k5:5763 PCM05 AQ3
    Opteron 165 s939_____OCZ RAM/PSU_____BBATI X800xl
  11. #136
    Mar 2006
    Quote Originally Posted by thegreek
    Tell me what bench-programs and who to load and what to do then i will tell you how is it going...
  12. #137
    Apr 2006
    Question SODIMM adapters
    Quote Originally Posted by FUGGER
    I do not have spd programmer, I am close to manufacture to where they will build what I need.
    I have DDR2 to SODIMM adapters, I can test SODIMM in P5WD2-E.
    It has a pretty good fan on it, upgrading the heatsink to copper is very possible since the mounting is standard. It would be very easy to install a water block and run the water lines out the air duct in the back of it.
    This block fits, even a gimpy water rig is more than enough on this cpu.
    Can you tell me where you got yr DDR2 SODIMM to DIMM adapters - I am after some to test some SODIMM's on my DFI 915P board.
  13. #138
    Jun 2002
    Las Vegas
    I have them at my office but if you can find the image, call the phone number printed on them so they can send you updated catalog.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
  14. #139
    Apr 2003
    North America, USA, TX
    I'd love to see XBench results! Thanks!
    http://xbench.com/
    Old Standby:
    DFI LANPARTY nF4 Ultra-D (R.AD0) 623-3 BIOS
    AMD Athlon 64 3800+ X2 (CCBWE 0529SPMW)
    THERMALRIGHT XP-90 w/Panaflo FBA09A12H-1AZ 90mm (56.8cfm) - AS Ceramique
    MSI NX6600GT-TD128E GF 6600 GT PCI-E
    WD Raptor 74G Boot, WD 1200JB IDE
    NEC ND-3520AW Black
    OCZ OCZ600ADJ ATX 600W
    ALPS Black 1.44MB 3.5" Internal Floppy Drive Model DF354H121F
    Lian Li PC-60USB B2 Silver Aluminum ATX Mid Tower Computer Case
    Win XP Pro (32-bit) SP2
  15. #140
    Apr 2006
    FUGGER, the datasheet shows that the Core CPUs use BSEL encoding for BCLK frequency, so a simple wire in the socket mod should do the trick to overclock the CPUs.
    133 (533) and 166 (667) are clearly marked, with two other options set as "RESERVED". 10 to 1 the two reserved are 200 (800) and 266 (1066) frequencies.
    Would you be willing to try this?
  16. #141
    Sep 2005
    Russia, Moscow
    @FUGGER
    how do you test sodimm mem @ p5wd2?
    does it work if i simply plug it?
    do you have a scheme of so-dimm programmer? i know where to find ddr1 one, but not so-dimm ((
  17. #142
    Apr 2006
    Fugger,
    I have a stupid question for you.
    Is the upgrade plug n play?
    My friend is working at intel and probably able to get me a cheap core duo chip.
    I really don't know anything beyond normal usage of the computer.
    I need a core duo mini to play HD movie.
    If it is truely plug n play, I definately want to upgrade it.
  18. #143
    Xtremely slow runner
    Nov 2002
    You just have to open the mini, disassmble the inside, remove the heatsink, switch cpu and reassemble everything. It's as simple as that
    The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
    Av by Frisch This is not a Lime tree
  19. #144
    Jun 2002
    Las Vegas
    Its just plug and play.
    I would suggest researching the dissassembly of the mini before doing so, having pictures to where the clips will save you a lot of time and damage to the case.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
  20. #145
    Apr 2006
    Thanks for the answer,
    One more question.....
    do you guys think $155 for a 1.83Ghz core duo is a good deal?
    I wish I could get a 2.0, but 1.83 is what I can get.
    Thank you
  21. #146
    Sep 2005
    Russia, Moscow
    FUGGER
    any news on installing xp on mac?
    was in apple center here in moscow today. everything ran smoothly. could even play nfs:mw ))
  22. #147
    Apr 2003
    Here is a good video of the process of disassembly:
    http://media.macsales.com/videos/min...l/highres.html
    Old Standby:
    NEC ND-3520AW Black
  23. #148
    Sep 2005
    Russia, Moscow
    how many hdds can i plug into mini?
    which ones are they?
  24. #149
    Jun 2002
    Las Vegas
    Only one spot for hard drive and nothing else.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
  25. #150
    Sep 2005
    Russia, Moscow
    @fugger
    can some more spots be brazed on mobo? no expansion slots in mini like pci, right?
