XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 02-16-2006, 04:39 AM   #1
-Wolverine-
-Wolverine-'s Avatar
Lightbulb DFI LP NF4 Ultra-D chipset cooling mod
Here is how me and my friend cool down chipset on our DFI NF4 Ultra-D boards!
Here R some pics
My rig with 7800GTX
With my X800XL, SATA and USB pluged in
temp during SP2004
S&M + Prime95 (2. test)
OCCT chipset temp with lapped stock+AC Ceramique+80mm fan
OCCT chipset temp with Wolv359Cu+AC Ceramique+80mm fan
for tests I used one 80mm fan @ ~1500rpm so it is very quiet. Passive it can hold temp under 45°C!
I'm very pkeased with temps wich R never above 35°C (even with friends X1900XT) while playing games!
Of couse it isn't perfect mod (bit expensive, can only use 2SATA) but it is good for me! It is nice, cold and quiet
What do U think?
In the meantime I changed CPU (3000+ Venice) with 3700+ SD and put VF700Cu on X800XL and changed SonicTower with BigTyphon. And changed old PSU with Hiper TypeR 580W
here is how it looks now
__________________
3700+ SanDiego KACAE 0547BPMW + TT BigTyphon ; DFI NF4 LanParty Ultra-D + Thermalright HR-05 SLI ; 2x512 Crucial Ballistix Z402 ;
Leadtek 7900GT Extreme + Zalman VF900Cu ; Hitachi 250GB SATA2 ; Plextor PX740A + Toshiba DVD rom ; Audigy2 PlatinumEX ;
Logitech X-530 ; Logitech MX900 ; CoolerMaster Cavalier 3 ; Antec NeoHE 430W ; Sony CPD-E250
-Wolverine- is offline   Reply With Quote
Old 02-16-2006, 09:02 AM   #2
D_o_S
D_o_S's Avatar
Looks cool...
Zalman VF700?
__________________
"Strive for perfection in everything you do. Take the best that exists and make it better. When it does not exist, design it." - Sir Henry Royce
D_o_S is offline   Reply With Quote
Old 02-16-2006, 09:24 AM   #3
Bail_w
Xtreme Cruncher
yes it is the Zalman Vf700, all he did is some bending. but dont really like that mod, because the vf700 take up too much spaces.
Bail_w is online now   Reply With Quote
Old 02-16-2006, 09:56 AM   #4
-Wolverine-
Yes it is trimmed VF700Cu! And yes it is pretty big but it's OK for me
__________________
Old 02-16-2006, 11:25 AM   #5
CPLB
CPLB's Avatar
Awesome job, as soon as something better comes out I'll do that with my current VF700.
__________________
AMD Athlon 64 X2 3600+ @ 3.0GHz||Biostar TF560 A2+||4x1GB Team Xtreem D9s||Visiontek HD3870||WD 250GB||Seasonic SS-600HT
AMD Athlon 64 X2 3800+ @ 2.6GHz||DFI NF4 Ultra-D||OCZ VX 4000 2-2-2-5||ATI X1900XT||Seagate 320GB||Seasonic S12 600
CPLB is offline   Reply With Quote
Old 02-16-2006, 11:54 AM   #6
NightCrawler™
NightCrawler™'s Avatar
I still have the base left from my PWMIC mod...... I might as well use it for my SLI-DR.. if my 9500 isn't in the way that is... LOL
NC™
__________________
Lian Li V2000+ Modded
Intel Core I7 920 @ 3.8Ghz 1.325v Thermaltright Ultra 120 Extreme RT1366
Asus Rampage Extreme 2
OCZ 3x2GB DDR3 1600 Platinum
EVGA 8800GT SSC 730/1800/2000Mhz SLi
OCZ GameXStream 700W
NightCrawler™ is offline   Reply With Quote
Old 02-16-2006, 12:21 PM   #7
-Wolverine-
NC™
Why do U think that it would be in the way?
__________________
Old 02-16-2006, 01:06 PM   #8
D_o_S
D_o_S's Avatar
Maybe because its mounted on his GPU?
__________________
Old 02-16-2006, 01:15 PM   #9
Serra
Xtreme CCIE
Serra's Avatar
Love it. Absolutely love it. Now I feel kind of bad that the only Zalmans I have left lying around are 7700's... probably much too large for that, plus I'll probably want to use a second PCI slot at some time...
Serra is offline   Reply With Quote
Old 02-16-2006, 01:28 PM   #10
Bail_w
Xtreme Cruncher
why dont you just spend 10 bucks on a evercool chipset cooler. and its much quieter almost same performances.
Old 02-16-2006, 01:32 PM   #11
-Wolverine-
o..i didn't get that (and I thought that I was crazy mounting VF700 on chipset )
I think that 9500 won't be a problem! VF700 is pretty low (profile i mean)
because U can't buy it in Croatia and this is more unique (and more complicated )
__________________
Old 02-16-2006, 01:55 PM   #12
Bail_w
Xtreme Cruncher
Whats that EZ PLuG on the MOtherboard for?
Old 02-16-2006, 02:18 PM   #13
-Wolverine-
what ez plug? where?
__________________
Old 02-16-2006, 02:23 PM   #14
Rabidmoose171
Rabidmoose171's Avatar
Send a message via AIM to Rabidmoose171 Send a message via MSN to Rabidmoose171
How can it be more quiet than something with no fan?
Rabidmoose171 is offline   Reply With Quote
Old 02-16-2006, 02:27 PM   #15
-Wolverine-
He probably thought more quieter than stock cooler!
__________________
Old 02-16-2006, 10:51 PM   #16
NightCrawler™
I'm worried about the width of the fin ray... the front of the Zalman aligns with the end of the PCIe slot.. looking at your pc those vf700 fins go past the slot..
NCâ„¢
__________________
Old 02-16-2006, 11:51 PM   #17
s7e9h3n
Phenom™
Here's my fanless solution - I had to remove almost two rows of pins in order for it to fit, but it works great:
__________________
FX56....
s7e9h3n is offline   Reply With Quote
Old 02-17-2006, 02:23 AM   #18
civ-fanatic
civ-fanatic's Avatar
Hmm... What are the Temps ?
__________________
Athlon64 3200+ (Clawhammer, C0-Steeping, from the late 2003 ) 2,2 GHz @ 1,568V | DFI LANParty NF3 250GB | 1024 MB Infineon DDR400 @ 2,5-3-2-5 | MSI NX6800 @ GT | Enermax Liberty 400W | 320 GB Samsung HDD | NEC ND-2500A @ 2510A
The Hesse are comin' !
civ-fanatic is offline   Reply With Quote
Old 02-17-2006, 06:16 AM   #19
-Wolverine-
NCâ„¢
Yes I saw that now!
Well it isn't a big problem! Just cut fins on VF or 9500 there (not more than 10mm) and it'll be OK!
__________________
Old 02-17-2006, 07:03 AM   #20
NightCrawler™
It's going to be the fins of the VF as the fan itself of my 9500 nearly touches the slot already...
NC™
__________________
Old 02-21-2006, 07:54 AM   #21
duploxxx
duploxxx's Avatar
my fanless solution always below 40degr, its modded for 1 high level card, can mod it for sli, but this is not my gaming rig
duploxxx
__________________
Vote for XS News forum without Quotes
duploxxx is offline   Reply With Quote
Old 02-21-2006, 08:57 AM   #22
kcnyc
Send a message via ICQ to kcnyc Send a message via AIM to kcnyc Send a message via Yahoo to kcnyc
Any issues with an SLi setup, s7e9h3n? How about an SLi setup phase changed on both the GPUs?
kcnyc is offline   Reply With Quote
Old 02-21-2006, 09:14 AM   #23
s7e9h3n
Phenom™
OOps...I forgot about this thread Sorry to say, I've don't and haven't run SLI, but there's enough clearance for a second card (as long as there's no ramsinks or such on the back of the second card). I also only own one gpu phase unit but that'll probably change soon.
Temps with the cooler ~30C Max, but that's with the mobo outside of a case on my bench rig most of the time. I'd say that as long as there's a decent amount of air flow, it'd probably be able to keep a chipset in the 35C area @ 1.6V if the mobo was mounted inside a case
__________________
FX56....
Old 02-21-2006, 09:21 AM   #24
kcnyc
If this thing works with the SLi, I might start breaking the pins on mine. IMO, this is the best chipset cooler out there. I think I might be able to even use a hot glue gun and glue a small fan on the side of the heatsink.
Old 02-21-2006, 09:36 AM   #25
s7e9h3n
Phenom™
I've balanced quite a few fans on the cooler - from 40mm - 92mm and found that in my particular setup, they didn't even make a difference in temps (since I have a rather large squirrel cage blowing air over my entire board to help prevent condensation)
__________________
FX56....
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
