as above, i wanted to know what program i could use to overclock the celeron 2.4 in this lappy. I've tried clockgen and CPUcool, but to no avail.
It's a dell Inspiron 1150.
Any help would be appreciated, thanks.
Usually with dell laptops the only chance of doing any overclocking is with hardware mods. They use proprietary bios which doesn't offer any voltage / chipset or fsb options. afaik, there are no hardware mods that can be done to those.Originally Posted by wwwww
Also, even if you did find a way to oc, those 1100 series laptops have absolutely terrible cooling. A friend of mine has one, his overheats at stock speeds.
Pentium M 770, Asus P4GD1
11 x 250 = 2750 MHz
2x512 OCZ Platinum Rev. 2 (1:1) 2.5-3-3-6
Sapphire x1900xt flashed to xtx
Antec TruePower 2.0 550w PSU
__________________
Dell Inspiron 6000d
Pentium M 735 1.7 GHz @ 2.26 GHz [pinmod]
ATI Radeon x300 128MB
i'll try a pin mod, anyone care to point me to a pin-mod for a socket 478 cpu to get me to 133fsb?
There is no pinmod that will work for the 855GM chipset. Only the 915 chipsets, as they support 133fsb. The 855 doesnt.Originally Posted by mr_mordred2095
11 x 250 = 2750 MHz
__________________
Dell Inspiron 6000d
Can't pin mod on the 855 chipset. Gotta be on the 915. Time for a new laptopOriginally Posted by mr_mordred2095
Currently building my i7 920 rig
i7 920 - Gigabyte x58-UD3R - 6GB Corsair DDR 1600
GTX285 - Intel X25-M + 1.2TB - Watercooled
if clockgen doesnt work, you're basically out of luck. well....
try systool and use every clock gen option to see if one works
i5 3570K@ 4.8GHz 1.32v, 32GB Gskill 1866, Gigabyte g1 sniper m3
HD7970@1125/1575 stock voltage
1TB F1+2*128GB Crucial M4
Silverstone 450w, no case
2560*1440@120Hz overclocked catleap
Steelseries G6v2+5600dpi modded logitech trackball
