Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: crucial ballistix 2x1024 timings
    Jul 2005
    What timings will the 2x1024 ballistix do below the pc4000 range? I know they are set for 3-4-4-8 at ddr500. I was wondering if they would do any tighter in the 235-245 range?
    ASUS Rampage II
    Core i7 920 D0 @ 4.2GHz
    Corsair TR3X6G1600C8 3x2GB DDR3 1600MHz
    Radeon 5870
    Raid 0 2x1TB WD on SATA 3/4
    Seagate 160GB on SATA 1
    LG Bluray ROM/DVD RW
    Corsair HX1000W
    Love and Peace!
    Dec 2004
    hiding somewhere!
    you should be able to do 2.5-2-2 if you're lucky, 2.5-3-2 or 2.5-3-3 if your sticks are more average
    Got a fan over those memory sticks? No? Well get to it before you kill them
    Da Goose
    Oct 2005
    Chicago
    I am lucky, mine can do 2.5-2-2-6 at 2.80V at 240 FSB
    i7-860 Farm with nVidia GPU's
    Crunch-Fu Adept
    Sep 2005
    Czech Rep.
    my sticks worked @ 237 like this (spi 32mb passed):
    cas: 2.5
    trc: 7
    trfc: 10
    ras to cas: 3 - lower is unstable with my sticks :-(
    ras to ras: 2
    tras: best was 0 or 7
    trp: 2
    twr: 2
    twtr: 1
    trtw: 2
    !!!! important !!! refresh rate 100 MHz 1.95us (3684) -this is my only stable setting on Ballistix when OCing
    async latency: 6ns (shame, didnt try the 5ns)
    read preamble 5ns (shame I didnt test the 4.5 or 4ns)
    idle cycle limit 0clks - my fastest setting
    didnt play with the drive strength
    remember I have only 2x512 , not 2x1024 , but I can see the Ballistix dont make a huge difference with the added density
    GOOD LUCK!
    Sometimes a good slap in the face is all you need
    Bios my arss.....
    I can fix this problem with a hardware mod....
    Hipro5
    "Overclock till death. Overclocking is life." Hipro5
    Dec 2004
    these are my settings 24/7 super pi 32M stable. voltage is 2.8V and memory is at 285 mhz.
    Crunch-Fu Adept
    Sep 2005
    Czech Rep.
    Quote Originally Posted by |3ourne
    nice speed, but it would be better, if you'd try 280 MHz and tighten those timings, try Trfc to 14, and latencies to 7ns and 5ns, try refreshing 100MHz 1.95us, should give you better performance
    GOOD LUCK!
    Bios my arss.....
    Hipro5
    Sep 2005
    Italy !!!
    hi my ballistix dont work at 250mhz whit 2.8volt... i think i use the bad timning...
    what timing are you use at 250mhz ????
    sorry for my bad english !!
    bye bye
    Dec 2004
    Quote Originally Posted by Aerosupra
    GOOD LUCK!
    Max Async and Read Preamble of 7ns and 5ns on a 2gb kit at 285 mhz with an opteron ??????
    Are you ok ?????
    It wont boot up. Or even if it does , it definitely WONT be stable.
    Trfc of 14 is not MUCH different from 16. Btw Memory at 285 mhz with Trfc at 16 has better performance than memory at 280 mhz with Trfc of 14.
    Trust me on this , I have played with nothing but memory modules this past one year or so.
    Da Goose
    Oct 2005
    Chicago
    Here's 250...
    Sep 2005
    Italy !!!
    tnx i try with your timing.....
    bye bye
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    Dozens of different examples in this thread for Ballistix settings 2x1gig
    http://www.xtremesystems.org/forums/...postcount=1101
    24/7 Work & Play Rig
    Gigabyte X58A-UD5, i7 920 @ 4.56ghz 1.48v 21x217, G.Skill PI 12Gb 8-8-8-24-1T 1.56V @ 1736Mhz
    EK Supreme HF P1, Dual EK DCP 4.0 Pumps and EK Res, XSPC RX360 & RX240 w/ 1850rpm GT's
    Sapphire HD 4870 1Gb @ 810/1020mhz, 2x Dell 2407, 2x 1Tb WD Black SATA3, 2x 2Tb Hitachi 7k2000
    Cooler Master ATCS 840, Corsair 750TX PSU, running OSX 10.6.3 & Win 7 64
    Sep 2005
    Italy !!!
    my ballistix can't work at 250mhz...
    please post me the default timing at 250mhz... (my spd is 3-4-4-10 @ 250mhz)
    i'm going to drive crazy....
    this is my configuration :
    AMD Athlon 64 3700+ San Diego 1 MB L2 socket 939 2,2Ghz @ 2500Mhz vcore 1.4v (250x10)
    Thermaltake Big Typhoon
    Asus A8N-SLI Premium
    2 x 1 GB Crucial Ballistix DDR 500
    Point Of View Nvidia GeForce 7800 GTX 256 MB
    2 x 160 GB Western Digital Caviar SE 8 MB Cache RAID 0
    OCZ ModStream 520w
    tnx !!!
    bye bye
    Love and Peace!
    Dec 2004
    hiding somewhere!
    with the asus, you probably have to change command rate to 2T. the spd you have listed is correct though
    Sep 2005
    Italy !!!
    the command rate was 1T... yesterday i have passed 1 hour of prime at 240 3-4-4-8 1T http://img206.imageshack.us/img206/9580/240344103qm.jpg
    now i test at 245 3-4-4-8 1T...
    AMD Opteron 165 Toledo 2x1 MB L2 socket 939 1800Mhz @ 2836Mhz vcore 1.408v
    Cooled By Ybris-Cooling K10
    DFI Lanparty UT nF4 Ultra-D
    Cooled By Lunasio-Cooling L4E
    2 x 1 GB Crucial Ballistix Tracer DDR 500 @ 236 Mhz 3-3-3-8 vdimm 2.62v
    Point Of View Nvidia GeForce 7800 GTX 256 MB 430/1200 @ 486(540)/1360
    Cooled by Ybris-Cooling K5
    OCZ ModStream 520w
    Thermaltake Armor Silver Modded!
    Samsung 19" 930BF
    Crunch-Fu Adept
    Sep 2005
    Czech Rep.
    Are you ok ?????
    Dont think I'm nuts, some people have Ballistix 2x1GB 290-300 with 8ns and 5ns and Trfc of 14, so 7 & 5 wouldnt be a problem @ 280, that Trfc 16 is your experience and mabye your right, didnt try myself
    Bios my arss.....
    Hipro5
    Sep 2005
    Italy !!!
    my ballistix 2x1024 can't work a 250mhz 3-4-4-8... this is my situation : http://img460.imageshack.us/img460/2964/twork8cc.jpg
    there is some bad timing ???? plese help me... at 240 3-3-3-8 after 1 hour and 8 minutes prime was found 1 error..
    on the manual of my asus there is "DIMM modules with 128Mb memory chips or double-sided x16 memory chips are not supported in this motherboard"
    the ballistix 1024Mb are 16 x 128Mb chips....
    but the crucial's web site report : http://www.crucial.com/eu/ballistix/...=25&submit.y=9
    if this is the cause of don't work @ 250mhz then i'm going to buy a dfi lanparty sli-d...
    sorry for my english !!!
    bye bye
    OCZ ModStream 520w
    Samsung 19" 930BF
    Crunch-Fu Adept
    Sep 2005
    Czech Rep.
    Set the read to write delay to 3, this will help ... Ballistix cannot handle Trtw at 2 on higher OC
    Bios my arss.....
    Hipro5
  18. #18
    Crunch-Fu Adept
    Sep 2005
    Czech Rep.
    also, the Ballistix 2x1024 (1GB modules) have 16x64 which stands for a double-sided 1GB module, it would be a nonsense not supporting 1GB modules on a Nforce4 mobo.
    that note in your asus manual says the motherboard doesnt support 2GB modules, it only supports 256-1024 on one module
    Bios my arss.....
    Hipro5
  19. #19
    Love and Peace!
    Dec 2004
    hiding somewhere!
    and generally, trtw should be 3 or 4 when using cas3.. my ballistix like 3 more than 4 though
  20. #20
    Jan 2005
    norway
    dram drive streng and dram data drive streng ande tref setting?
    cpu:qx9650@4ghz
    ram: gskill pc8000qt 4*2gb
    MB GB X48-DQ6
    Gfx 9800gx2
    Disk:2*1tb raid0
  21. #21
    I am Xtreme
    Dec 2003
    Talking This works for me 24/7 (D2OL x2)
    Tweaker .6 settings (no DQS) for 10x270/2.84 vdimm IIRC, been running like this for 2 months NP (Oh Opty 170 (2nd one, 1st is in wifeputer (1G TCCD )for now, will make return appearance in the new year)
    3, 11, 14, 3, 2, 8, 3, 2, 2, 3, (4708/166/1.95), 1
    16, 128, d, d, 7, 7ns, 5.5ns, 256, e, 200, e, weak(Think auto, but I forget), D
    Hope this helps
  22. #22
    Sep 2005
    Italy !!!
    hi friends !!!
    after 3 days of test my ballistix work at 230mhz at 2,5-2-2-5 at 2.8v
    http://img230.imageshack.us/img230/2...225work8gk.jpg
    i will try at + HTT...
    but for daily use can i use the ballistix at 230mhz at 2,5-2-2-5 ????
    thx to all !!!
    bye bye
    OCZ ModStream 520w
    Samsung 19" 930BF
  23. #23
    Crunch-Fu Adept
    Sep 2005
    Czech Rep.
    Quote Originally Posted by napass
    hi friends !!!
    thx to all !!!
    bye bye
    looks fine,
    sure its the highest stable at those timings?
    try setting ras to ras to 2 and that read preamble to 5 ns for slight performance increase,
    for 24/7 its fine if its stable, so you must this test yourself (spi 32, prime, games....)
    NO MATTER WHAT TIMING OR FREQUENCY YOU MUST KEEP THEM ACTIVELY COOLED !!!!!!!!
    Bios my arss.....
    Hipro5
  24. #24
    Sep 2005
    Italy !!!
    ok, tomorrow i will change the timing 3 to 2 and 5.5 to 5...
    this is the first test whit these timings...
    before i try whit same timing at 240mhz and after 1 hours of prime the ram run still...
    tomorrow i try at 240mhz whit your suggestion... i'm not going to stop the prime 95 before 5-6 hours...
    on my ram i have the stock amd's fan.... now the ram is very cooled !!!
    when prime is in action the ballistix are tepid...
    tomorrow, if i have free time i post the result of test...
    thx for all suggestion !!!
    bye bye
    OCZ ModStream 520w
    Samsung 19" 930BF
  25. #25
    Sep 2005
    Italy !!!
    hi !!!!
    this is a new result !!! http://img169.imageshack.us/img169/5...255work4tp.jpg
    see you soon !!!!
    OCZ ModStream 520w
    Samsung 19" 930BF
