Hi, Bought an "as-is" X800XL AGP on eBay... Unfortuantley (for me) it's not working so well...
If I start my computer with it my Port 80H device stops at "25" and I get the "ambulance sound" from the pc speaker... This is on both a Epox 8RDA3+ and 8RDA+ mainboard plus a Abit KT7A mainboard (no Port 80H on it though)
If I add a PCI VGA adapter and tell my computer to use it I can boot to Windows and it finds a new VGA hardware, installing the ATI drivers is however impossible because they tell me I do not have any supported hardware installed... Note that simply switching the monitor cable to the X800XL at this stage only results in a blank / no signal screen...
Booting to DOS and starting ATI Flash v3.09 with the -I paramter results in this output:
I saved the BIOS file, the checksum was 0x1200 and it was 0xE600 bytes long, I then hex compared this with the BIOS here at Techpowerup:
ATI X800 XL (AGP) 256 MB and they where exactly the same... I tried flashing that BIOS on Techpowerup anyway, ATIFlash then told me that it will not flash it because that BIOS is the same that is on the card so I forced it with -F and got this output:
Of course nothing good turned out of this, the card still not worked... So I took out my multimeter and measured the voltages on the card according to this image @ Techpowerup. The results where prefect, all voltage values where normal:
VGPU: 1,361v / 1.31V - 1.41V
VDD: 2,013v / 1.95V - 2.05V
VDDQ:2.096v / 2.04V - 2.10V
I then tried disabling AGP 8X in the BIOS and fast writes, because my mainboard only provides 1.5v no matter at what AGP standard... This did not work either, the hardware monitor shows the card getting 1.52v...
Last here are some screenshots of how ATITool and Powerstrip see the card in Windows...
Anyone with more ideas on how I can revive this poor card?
