Page 2 of 2 FirstFirst 12
Results 26 to 37 of 37
Thread: ?? Vmods for ASUS P4P800-X ??
  1. #26
    Xtreme Vmod mod
    Aug 2004
    Cornwall/Newcastle uni, UK
    For the Vdroop mod, connect a 100k variable resistor between the two points I've marked. Before modding, check that the point I've labeled reads Vcore. Decrease resistance until there is only a small amount of droop.
  2. #27
    Jun 2005
    Estonia
    do i need to measure these 3 pints what u marked out or only that chip leg???
    what happens if i decrease resistance too much? to any mosfets heat up with that???
    Have any pencil mod for that?
  3. #28
    Xtreme Vmod mod
    Aug 2004
    check the voltage at the point where there is space for a capacitor to be soldered circle with half of it coloured white.
    I can't follow the traces on the picture, so its a bit hard to work out any pencil mods
    If you decrease resistance too much, you could damage the Vcore capacitors and MOSFETs. Vcore will probably be decreased slightly by the mod.
  4. #29
    Oct 2005
    mr Kjaups can i know what memory do u used
  5. #30
    Jun 2005
    Estonia
    Quote Originally Posted by hendrasystemind
    U said in msn that u have done VDIMM mod for that motherboard.
    Can u give my pictures of it?
    PQI ram with PQI chips on it.
  6. #31
    Oct 2005
    VDIMM for P4P800X
    i mod my mobo by connect the yellow pin to the ground with 50K.
    any suggestion for the VCORE mod.
    for mr Kjaups can i know your RIG, THX
  7. #32
    Jun 2005
    Estonia
    Thanx, now i will find some stuff and start to mod .
    Some juice for rams
  8. #33
    Jun 2005
    Estonia
    I hope u can read this soon.
    Im planning to mod today, i have everything for moding, but i need to know, where did u measured VDIMM voltage????
  9. #34
    Jun 2005
    Estonia
    @ hendrasystemind
    Are u sure that u connected 50k with pin 2 ???
    My motherboard stoped responding for 10 minutes with that mod :S ....
    I hope, that nothing serious hapened.
    Can u give me some picturs of your mod
  10. #35
    Oct 2005
    here is
    sorry, i uploaded a wrong picture
    btw do u check u soldering, any short component ?
    connect the pin no 6 with a 50K to the ground.
    please check the lm 324 datasheet. i think is pin no 6
    here is my mod pic. (dont have a camera right now )
  11. #36
    Aug 2008
    what is the status now on a good Vcore Vmod ?
    3dmark Vantage : +47K (NO PhysX)
    3dmark11 : +14K
    3dmark06 : +41K
    3dmark05 : +50K
    3dmark03 : +187K
    3dmark01 : +126K
    Wprime32m : 3.233sec
    Wprime1024 : 1m30sec320
  12. #37
    I am Xtreme
    Dec 2004
    France
    This is from my p4p800-se the first is the vdroop with the solder on the chip its to a 100k pot, i think its the p4p800 se i was so proud i took a pic, it was my first vmod.
