dear friend, I use 2 stick crucial ballistix pc3200 memory,
after several test using Memtest 1.51 test#5 then I got that
1st stick can get FSB 275 with 3-3-3-8 1T vdim 2.9v(rest setting set to default/auto)
2nd stick can only get FSB 268 with 3-3-3-8 1T vdim 2.9v
but that FSB not stable, I mean sometimes (first stick) with FSB 275 can pass test#5 for more than 50pass, sometimes can't pass the test, this also happened with second stick.
Can anyone tell me what's wrong ? Or what should I do?
If I open the heatspreader and add ramsink on the memory, can I get higher FSB?
Note :
vcore 1.35+110%
Cpu multi set to x7
Htt multi set to x3
Mem divider 1:1
HSF Cooler stock
