Page 1 of 2 12 LastLast
Results 1 to 25 of 36
Thread: Did I damage my Winchester 3200+?
    Jan 2005
    Hi all
    I currently have a Winchester 3200+ installed in my system
    it has been runnin 10x241 for some months now
    when i started testing it for the highest speed in the beginning i got it 101% stable at 10x246
    but when the warm weather started i noticed stability was lost
    so i backed down to the 10x241 at 1.55V x104%, which i tested 101% stable back then (with roomtemp of +-20°C)
    since then i didnt really prime or occt anymore, i just played gta: sa
    after awhile gta crashed sometimes, and temps were also higher then they used to be when occting at 10x241 which seems very strange to me
    on the hottest summerdays the cpu became till 72°C once after a few hours of gta:sa , and i remember a highest occt temp of 61°C from when it was still stable if im right
    most of the times it crashed out of gta:sa at 69°C, and i even think that wasnt allways on extremely hot days
    i live in belgium btw, so nice summerdays are usually between 20-25°C, and the really hot ones around 30°C, 35°C perhaps happened ones or twice this year
    i should have acted back then, but gta was too addictive, and i just kept playing
    another reason i didnt start over finding the new 101% stable speed was that i was gonna buy a Venice 3200+ cpu soon
    well, actually i did a few days ago... so i wanted to install the newest official dfi bios (623-3)... but offcourse i dont flash in an unstable environment, so i backed down the 10x241 to 10x200, leaving all other settings intact, thinking this should CERTAINLY do the trick since this was 101% stable at 10x241 a few months before!
    but after a reboot i decided to at least try a few minutes of occt just to be sure...
    occt didnt even pass 10 secs
    so i started freakin out
    i decreased voltage to 1.55V instead of 1.55V x104%
    tried occt again, perhaps 15secs now
    reboot, load bios defaults (also once tested 101% stable)
    tried occt again, about the same 15 secs
    reboot, decrease multiplier to 8x200, increase voltage to 1.5V
    tried occt again, allmost a minute this time
    reboot, memtest test8 for 1 loop: no probs
    damn peepz
    im freakin out!!
    i wanne install my new venice, but i still wanne sell this winchester!!
    wtf is happening plzzz?
    edit:
    just tried lowering speed to 6x200 at 1.375V with chipset and ltd voltage up 2 steps
    and now prime is passing for some tests allready
    temp while priming is 43°C now
    Build in progress:
    PSU: Seasonic M12D-850
    MOBO: Gigabyte GA-X58A-UD7 | RAM: 6GB OCZ Reaper OCZ3RPR1600LV6GK | CPU: Intel Core i7 920
    SSD: Intel Postville X25-M G2 160GB @ ICH10 | HDs: RAID5 of 6x Seagate Barracuda LP 2TB @ LSI MegaRAID SAS 9260-8i KIT
    GPU: Gigabyte GV-R587UD-1GD
    To order:
    Watercooling!
    Xtreme 3DTeam Member
    Jan 2005
    AMD factory
    Quote Originally Posted by Mastakilla
    on the hottest summerdays the cpu became till 72°C once,
    Oh Masta - this is like U would run Your car 200mph in the backdrive.........
    Previous system:
    DFI NF4 ULTRA 0453A3 KOREA CHIPSET / BIOS 510-2FIX / FX-57 0516WPMW@3.62GHZ / 2x256 CORSAIR 3200LLPT BH-5@13x278MHZ 2-2-2-5@3.69VDIMM / MACH II GT@MOD BY BERKUT / ACTIVE COOLING FOR RAM - MOSFETS - GPU RAM / CHIPSET & GPU CORE WATERCOOLED / OCZ POWERSTEAM 600W / BUILT BY ATI X850XT@660/651 - VGPU@1.73-VDD@2.26-VDDQ@2.21 PENCIL MOD / WIN XP 2x80GB SAMSUNG SPINPOINT SP80 SATA - RAID 0 & WIN 2K 40GB SAMSUNG SPINPOINT SP40 IDE BENCH DRIVE / PIC
    Jan 2005
    Quote Originally Posted by HARDCORECLOCKER
    yeah ur right
    but gta: sa was soooo fun :/
    i edited my message a lil btw
    that 72°C was after some hours of gta: sa offcourse, not while idling
    but what can i do to fix it?
    and what the hell went wrong with my cooling? it used to run extremely stable at 10x241 with a do-able temp...
    damn i just hope i didnt damage anything
    edit: occt just crashed after 5 mins with the 6x200 settings, new record, but still BAD
    damn im getting really clueless here...
    Build in progress:
    To order:
    Watercooling!
    Jan 2005
    AMD factory
    was soooo fun
    ........said the alkoholic before he died after the 10th bottle of red wine
    To get serious again: Maybe U damaged Your CPU with those :banana::banana::banana::banana:ing attemps - try to set it under water or single phase and check if it is running stable.
    If not - definately K.I.A. - then R.I.P..........
    Previous system:
    Jan 2005
    just been tryin 5x200
    doesnt help much
    tried both 1.250V and 1.250V x104% and 1.55V x104%
    and all didnt even make the minute of occt
    daaaamn
    this sux
    Build in progress:
    To order:
    Watercooling!
    Jun 2005
    Bancroft, ON, Canada
    It sounds like you fried the memory controller, that's just too hot period.....
    Of note, even with the stock cooler on that chip at that voltage, it should never have gotten that hot unless it wasn't making good contact with the cooler or the case was really badly ventilated.....
    "Foldin, Foldin, Foldin...keep those benchers foldin..." (Lyrics by Angra, Music is Rawhide)
    BOYCOTT MIR's
    Quote Originally Posted by Monkeywoman View Post
    aww an OC virgin! lose it tonight with Xtremesystems!!!
    Jan 2005
    Quote Originally Posted by Ugly n Grey
    its a VERY well ventilated cm stacker case (2 hd-bays, so 3x 120mm fans + 1x 80mm fan)
    i dont really understand it either :/
    Build in progress:
    To order:
    Watercooling!
    Jan 2005
    AMD factory
    C'm on Masta - U could put a car engine's watercooler fan on Your CPU - it is still aircooling. These temps were too much.............
    Previous system:
    Jan 2005
    it doesnt really seem to matter what settings i run the cpu at... it allways seems to freak out within the minute now
    i just did a succesfull bios update to 623-3 final
    im gonna give up the winchester and try out that new venice
    Build in progress:
    To order:
    Watercooling!
    Jan 2005
    AMD factory
    Go for San Diego.............
    Previous system:
    Cyanide Blood
    Dec 2004
    England
    72c on A64? think thats a new all time stupidity record
    AN OPEN MIND, WITH A CLOSED FIST.
    Jan 2005
    AMD factory
    Quote Originally Posted by Korpse
    C'm on mate - no need to laugh. He sacrified his Winnie to show us how much it can bare.......
    Previous system:
    Jun 2005
    Now Korpse, no need to be rude, I'll just have to kill you in more inventive ways next time.
    Don't sweat the small stuff Mastakilla it's just a chip, get another one
    BOYCOTT MIR's
    Jan 2005
    AMD factory
    .....better this way than doin' it with a FX-57
    Previous system:
    Jan 2005
    hmz
    i just discovered my venice has another boxed cooler
    and now i dunno which one to use
    anyone around who can tell me quickly? (wanne get goin!)
    my old winchester boxed cooler is from AVC ad seems to have a copper bottom with alot alu fins
    the new venice boxed cooler is from no brand, is completely alu, has less, but thicker fins, and has a thicker base
    Build in progress:
    To order:
    Watercooling!
    Jan 2005
    AMD factory
    hmz
    Take a look at the specs - watts, rpms & size. Chose the better one.
    Previous system:
    Jun 2005
    It seems your old one didn't do so hot (or did too hot) last time anyhow, use the new one.
    BOYCOTT MIR's
  18. #18
    Jan 2005
    http://www.au-ja.de/review-cooler2005s939-print.phtml
    i found them both on this page reviewed
    allthough its in german and i dont understand of it, the graphics reveal enough
    ill try the new cooler
    Build in progress:
    To order:
    Watercooling!
  19. #19
    Apr 2005
    Houston, TX
    It is/was my understanding that anything over 1.5V on air would slowly kill an A64? I wish I had a better motherboard my AGP lock breaks at 255 and my chip is there with 1.4V.
  20. #20
    Jun 2005
    I don't think the voltage is the concern at that level as much as the heat is...1.5 is no big deal imo
    BOYCOTT MIR's
  21. #21
    Feb 2004
    72 C !!!
    You have to use a heatsink you know
    I would defenitely recommend you to
    who knowes it might even keep the next cpu alive
    i would take a look at the cool before i replaced with a new one
    Hope you can RMA it
  22. #22
    Feb 2004
    Quote Originally Posted by Major_A
    1,5V is not much the cpu will still last longer than you need to
    it is only 0,1V above default
    I wouldt worry
  23. #23
    Jan 2005
    hmz
    that venice isnt occt / prime stable either at stock speed, and also not at 8x 200
    gonna try and find out if it has anything to do with a bios setting
    Build in progress:
    To order:
    Watercooling!
  24. #24
    Jan 2005
    with my venice it seems directly dependend on the dram voltage....
    the 2.6V that used to be enough had to be increased to 2.7V or higher to get it stable (still tryin to find out which voltage it likes best)
    it was unstable with stock speeds (10x200), and even 8x200 when dram voltage was at 2.6V
    with the 2.9V im testing now i could do 10x255, 8x300 and 9x285 (occt for +- 5 mins)
    im VERY glad my venice started working...
    but im still confused by my winchester too
    im wondering if it needed the same dram voltage change to become stable again...
    dont really feel like retesting it though.... i just wanne sell that biatch...
    Build in progress:
    To order:
    Watercooling!
  25. #25
    Jul 2005
    NWI and Manhattan KS
    sounds like you should try a different motherboard with the winnie and the venice to see if thats the prob
