XtremeSystems Forums
Reply
Old 07-29-2005, 02:36 PM   #1
red_dragon
red_dragon's Avatar
What's the method for measuring pressure drop?
How can I measure pressure drop in my loop? Thx!
__________________
RedDragon
A64 Venice 0517 APFW @ (300 x 9) | DFI Ultra-D | eVGA 6800GT | PQI Turbo 2 x 512MB (300 @ 2.5-4-4-7, 2.7V) | Cooler Master Real Power 450 | Maxtor 160GB, Maxtor 120GB | NEC ND-3540A || AquaExtreme 50z | DangerDen TDX | Polarflo TT VGA | BIX2 | DangerDen Dual Heatcore w/ Shroud
Dragon [backup sys]
XP-M 2600+ | Abit NF7-S Rev 2.0 | Visiontek GeForce 3 Ti200 | OCZ Gold GX PC-3500 | Ultra X-Finity 600W || Thermalright SI-97 | MCX-159
Heatware 43-0-0
red_dragon is offline   Reply With Quote
Old 07-30-2005, 01:53 AM   #2
red_dragon
red_dragon's Avatar
no one? Some one's gotta know...
__________________
RedDragon
Dragon [backup sys]
Heatware 43-0-0
Old 07-30-2005, 08:18 AM   #3
BRiT
BRiT's Avatar
First, you need very expensive equipment. Search for a post by Maxxx where he shows off his new equipment and gives some pressure readings for various blocks. This was within the last three months in this forum.
BRiT is offline   Reply With Quote
Old 07-30-2005, 08:45 AM   #4
MrBean
MrBean's Avatar
Why would you want to measure pressure drop? You could use a manometer to do that. There are pressure transducers, best would probable be lvdt type.....You can get these, calibrated for 1-5V, or 4-20mA outputs, and you can scale that to a DVM.
Why not use a small venturi in your setup, the upstream side will have a larger pressure, caused by the restriction, on the downstream side you will have a slightly lower pressure, and the change in this would be proportional to your flow....
Record your pressure differential......for a more free-flowing system, dP will increase, and vice-versa.
What do you really want to acheive? Maybe I can give better ideas then.
__________________
Never argue with Idiots...they will drag you down to their level and beat you with experience!
MrBean is offline   Reply With Quote
Old 07-30-2005, 08:54 AM   #5
BRiT
BRiT's Avatar
Found the thread I was thinking of, it's Differential Pressure Meter Testing.
Old 07-30-2005, 07:12 PM   #6
MaxxxRacer
Xtreme X.I.P.
MaxxxRacer's Avatar
Send a message via AIM to MaxxxRacer Send a message via MSN to MaxxxRacer
mr. bean, what are of expertise do you have? you seem to know your stuff when it comes to this.
Brit has the thread I posted a while ago linked above, but that unit isnt for sale anymore afaik.
Fluke and Omega both make a wide range of manometers that will do the job though. some pretty nifty units i found at www.omega.com . expensive though
MaxxxRacer is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
