Page 1 of 2 12 LastLast
Results 1 to 25 of 35
Thread: Rebuild the Winbond honor -GSkill 1GBGH simple test
    Nov 2004
    Tomorrow is typhoon holiday. The mood is good and post some delayed test.
    Take a look first.
    Equipping with 2 holes Winond UTT. It guarantees DDR400 2 2-2-5 2.7~2.9V.
    The same level as the famous Winbond BH5.
    Specification :
    * Package : 512MB kit (2x256MB) 1024MB kit (2x512MB) dual channel pack
    * IC Spec : Winbond UTT
    * CAS Latency : 2-2-2-5 (PC3200)
    * Test Voltage : 2.7 ~ 2.9 V
    * PCB Board : 6 Layers PCB
    * Speed : DDR 400 MHz (PC3200)
    * Type : 184-pin DDR SDRAM
    * Error Checking : Non-ECC
    * Registered/Unbuffered : Unbuffered
    * Quality Control : Comprehensive rigorously tested in pair at dual channel environment
    * Warranty : Lifetime
    OC Winbond chip still needs higher voltage.
    Before OC, except the body, well cooling is also impacting the result.
    The same as testing OCZ VX PC4000 DDR500 2 2-2-5 3.3V, I use 12X12cm fan.
    Test config.
    AMD Athlon64 3000+ 0448&X2 4200+
    DFI nF4 LanParty Ultra-D
    GSkill 1GBGH
    SPARKLE 6200
    TOPOWER 520W
    Testing with Winchester 3000+ 0448SPAW
    DDR400
    DDR500 1.5 2-2-0 3.24V
    Swap to X2 4200+, it can reach DDR540 SP2004
    After comparing Winchester, Venice and X2, we can see the AMD memory controller is getting better.
    Combining with DFI LP board, you can reach higher.
    Every CPU is different. So you need different BIOS parameters to reach DDR530.
    BTW, Winbond chip is still in high C/P.
    After adding voltage, it generates more heat. You can add extra cooler to reduce it.
    But we cannot see if high voltage will damage the chip in long term use.
    As electric moving theory, higher voltage means lower life.
    The test above is over office spec. We need better cooling, better memory body and DFI LP board.
    I am well trained, please do not copy. Just for your reference
    Mar 2004
    Fullerton, California
    Quote Originally Posted by windwithme
    Wouldn't that be the whole point of picking up this ram
    Anyways, GSKILL needs to come out with some intel friendly low latency stuff
    Jun 2004
    damn that looks nice, wish i had picked me up some of that. My mushkin redline cant do 270mhz thats for damn sure. Hell I cant get 260 stable. Also it cant do Ras to Cas 2. This gskill stuff looks really nice.
    PS Does cas 1 actually do anything?
    Dec 2004
    Saskatchewan
    wow 270 @ 3.5v
    Mine should be here this week osometime, makes me excited
    Team Rufio
    XIP
    Nov 2004
    NYC
    heres GH @ 271-3.6V.....single vid. card b/way...
    XIP
    Nov 2004
    NYC
    No cold boot issue with Gxkill GH
    Mar 2005
    La Paz / Mexico
    Nice results ! Congrats.
    My Personal Records:
    Infineon BH-6 (1x256MB) at 290MHz [2-2-2-5] at 4.0V // CPU-Z
    // PIC
    Infineon BH-6 (2x256MB) at 270MHz [2-2-2-5] at 3.63V // PIC // BENCH 1 // BENCH 2
    Kreton UTT (1x512MB) at 270MHz at 3.35V [2-2-2-5] // CPU-Z // PIC
    Infineon BH-6 (4x256MB) at 270MHz at 3.8V [2-2-2-5] // CPU-Z // BENCHMARKS
    Jun 2004
    greece
    So what? U r gskill's employee and u r getting cherry picked modules in order to review 'em and then make all of us want like hell to buy them. Personally i don't trust no more any of you, reviewers and employees. And it's not against gskill individually, but to all of the companies whose policy is to get into forums and present products which don't stand for real world users.
    Jun 2005
    Netherlands
    Quote Originally Posted by Dumo
    Wooooo that's good news , makes me very happy having purchased them a while ago (not been able to use them yet as I'm still waiting for parts to my new rig)
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    Quote Originally Posted by georgesod
    I've had 8 sets of G.Skill, 6 sets of TCCD and 2 of UTT and they have ALL done what windwithme has posted his able to do. I think that if anything G.Skill tend to post conservative results.
    24/7 Work & Play Rig
    Gigabyte X58A-UD5, i7 920 @ 4.56ghz 1.48v 21x217, G.Skill PI 12Gb 8-8-8-24-1T 1.56V @ 1736Mhz
    EK Supreme HF P1, Dual EK DCP 4.0 Pumps and EK Res, XSPC RX360 & RX240 w/ 1850rpm GT's
    Sapphire HD 4870 1Gb @ 810/1020mhz, 2x Dell 2407, 2x 1Tb WD Black SATA3, 2x 2Tb Hitachi 7k2000
    Cooler Master ATCS 840, Corsair 750TX PSU, running OSX 10.6.3 & Win 7 64
    Xtreme Mentor
    Jul 2004
    Brooklyn, NY
    is it on sale yet?
    Asus Rampage Formula X48
    Intel Q9650 @ 4.33GHZ
    OCZ Platinum DDR2-800
    Palit 4870x2
    Creative Xi-Fi Extreme Music
    Corsair HX1000
    LL 343B Case
    Thermochill 120.3
    2xMCP355
    KL 350AT
    KL 4870X2 FC WB
    DD Chipset Block
    Jan 2005
    NJ
    yep at the egg...at least i think this is it http://www.newegg.com/Product/Produc...82E16820231013
    Thats damn cheap for 265ish @ 2-2-2-5. My VX only does like 255
    CPU Z:2700 2k1:27952 2k3:12282 2k5:5763 PCM05 AQ3
    Opteron 165 s939_____OCZ RAM/PSU_____BBATI X800xl
    Apr 2005
    Pittsburgh, PA (or Lisbon, Portugal)
    I have a set of GSkill 4400 LE that does better than the "advertised" here on the foruns by GSkill-related users.
    I think that makes me sort of a GSkill employee undercovered r something like that. Or just a lucky b@st@rd.
    Personally, and from what I've seen, I don't think that GSkill is inflating expectations about their products. There are many normal people who can reproduce or even beat the results presented. But overclock is a game. Some do have bad luck and can't reach that high.
    Quote Originally Posted by krille
    Ouchy, go die please, thanks.
    XIP
    Nov 2004
    NYC
    Quote Originally Posted by Kabouter
    Thats the most important thing with all this utt products in the retail channels now. I bought another brand of utt ($255 for dual 512m) that ran really fast @ 270/2-2-2, but it gave me a lot of headache with cold boot problems......not this gh though
    Banned
    Jan 2004
    Land of Buckeye
    Use Merlin, Hellfire mod mix 510-2 fix bios can easily get DDr500@3.3v and DDR530@3.43v stable at least super pi 1.4 mod 32m passed! Below is what I ran super pi 32m by using GH, 3.4v but forgot to show the mbm5 though
    Sep 2004
    I didn't realize he is a GSkill employee. Is he? I think the XS community would benefit from more participation from people pimping wares from companies targeting the enthusiasts community. That said, their status as such should be clearly noted in their sig or under their avatar. Like OPB for example.
    Back on topic - 270? A nice pair of sticks for benching .
    Sourcing parts for a mildly over clocked abacus.
    Xtreme 3DTeam Member
    Jan 2005
    AMD factory
    So take a look here:
    http://www.geilusa.com/proddetail.asp?linenumber=69
    Stock CAS 1.5 and warranty up to 3.8Vdimm !!!
    Maybe the new No.1.........
    Previous system:
    DFI NF4 ULTRA 0453A3 KOREA CHIPSET / BIOS 510-2FIX / FX-57 0516WPMW@3.62GHZ / 2x256 CORSAIR 3200LLPT BH-5@13x278MHZ 2-2-2-5@3.69VDIMM / MACH II GT@MOD BY BERKUT / ACTIVE COOLING FOR RAM - MOSFETS - GPU RAM / CHIPSET & GPU CORE WATERCOOLED / OCZ POWERSTEAM 600W / BUILT BY ATI X850XT@660/651 - VGPU@1.73-VDD@2.26-VDDQ@2.21 PENCIL MOD / WIN XP 2x80GB SAMSUNG SPINPOINT SP80 SATA - RAID 0 & WIN 2K 40GB SAMSUNG SPINPOINT SP40 IDE BENCH DRIVE / PIC
  18. #18
    Sep 2004
    Quote Originally Posted by HARDCORECLOCKER
    "Thmperature Thermometer" but no mention of active cooling required. I'm a little leary of Geil since they don't have the same reputation as Mushkin, OCZ and GSkill, but some of the results posted on other threads look very good. At 3.8v they must not only tested for speed but temps as well right? My "Thmperature Thermometer" are my fingers ... if I can't hold on to them, they're too hot.
  19. #19
    Jan 2005
    AMD factory
    Yep - temp thermometer is somethin' for the kindergarden but the sticks could be nice ones - active cooling never was a problem for me:
    Previous system:
  20. #20
    Apr 2005
    This ram works fine with venice & divisors???
    Bye
  21. #21
    Jan 2003
    Gurnee, Illinois
    Too bad you still have to run the ram at 2T.
    Currently building my i7 920 rig
    i7 920 - Gigabyte x58-UD3R - 6GB Corsair DDR 1600
    GTX285 - Intel X25-M + 1.2TB - Watercooled
  22. #22
    Apr 2004
    Socal
    why 2T?
    ASUS Maximus VI Hero
    Intel 4770K Delidded @ 4.7GHz
    Swiftech DDC w/Petras Top
    EK Supremacy Direct to Die/MCW80 GPU
    XSPC 120.4
    2x8GB G.Skill
    MSI 6950 2GB 975/1400
    Samsung 830 2x128GB RAID0/WD 2x3TB RAID1
    Corsair 800D with AX850W PSU
    Dell U3011 30" LCD
  23. #23
    Jan 2003
    Gurnee, Illinois
    Nevermind, I was reading 2 thread at once and thought that this one was running 2gb of this. If it was 4 sticks you'd have to run 2T. Dang, I should just read one thread at a time... lol
  24. #24
    Nov 2004
    DDR550 2 2-2-5 PI 4M
  25. #25
    Apr 2004
    Brisbane Australia
    How about a 32M Pi? I only trust 32M as proof for memory clocks (like your 261 HTT pic)
    3D01 - 29649
    3D03 - 13055
    AM3 - 72618
