Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Thread: Open Your Storm Cpu Block Before Installing!!!!
    Jan 2005
    to everyone who bought a storm block open it up and check for both rubber o-rings. i received mine and installed it, started leak testing and boom!! niagra falls. ive never seen so much water leak out before. opened it up and an o-ring is missing. im just pre-warning you guys cause it sucks! hopefully nothing is wrong wth the rest of the components, there was no power to anything except the pump
    Mar 2005
    Sweden/Skåneland
    Thanks for the heads up
    My english isn't perfect, so sue me!
    Maxxxracer is one hello:banana::banana::banana:uy x2
    Jan 2005
    it sucks i got to let everything dry out and then pray it works. no power to any of it so it should be good
    Dec 2004
    San Diego, CA
    Wow, that sucks.
    I'd e-mail Swiftech to let them know. They really should keep a closer eye on that. I probably wouldn't have opened it up before installation either.
    Jan 2005
    i dont think it will do any good anyway
    May 2005
    Rye, Ny
    wow...that sucks ass man...hope everythings ok...just let her dry out everything should be fine....i put my flash drive (out of the casing) thru a laundry machine....it was fine no powre to it i guess. ill be sure to check when i get mine!
    Xtreme X.I.P. MaxxxRacer's Avatar
    Aug 2004
    Los Angeles, Ca USA
    wow.. kinda scary.
    Member
    Dec 2002
    Leics UK
    They are probably rushing to assemble them, bet they have loads of orders.
    This is another VERY good example of why you should allways leak test stuff outside your case before you install it.
    Make sure you dry everything out VERY thoroughly before you turn it on. Dont rush or you WILL kill something!!!
    Xtreme D²OL Cruncher
    Dec 2004
    London
    also if you have as water wetter etc you will need to clean the board down with isopropo alcol or acetone as they leave a residue than is conductive where the water evaporates off.
    ovens at 70-80oC are good for getting rid of water from all of the hidden areas. just make sure you put something above the board to stop direct heat from damaging the plastics.
    Oct 2004
    Norway
    Wow.. scary stuff Did anyone else recieve their yet? Any pics and reports of performance? Are you sending it back or getting that missing o-ring yourself? Swiftech should check their rutines and send you a little something for the experience. And yes, be sure to dry everything very closely, I've killed two motherboards and two graphic cards by not having the patience to wait
    Holst: Please answer PM
    Mb: Abit IX38QuadGT Cpu: Core2Duo E6850 Gfx: HD4870X2 Ram: CrucialBallistix 2x1GB Case: Gigabyte3DAurora Psu: Corsair620W
    Jan 2005
    yeah im sending it back for replacement. it would be nice to get something from swiftech but there not going to give a . everything seems dry right now but im letting it sit for more.
    Feb 2005
    Quote Originally Posted by pablo
    use a hairdryer too good luck
    3.4E D0 @ 285×14 1.525Vcore
    XP-90/Tornado
    Abit Ic7-G
    G.skill pc4400 LE 2×512MB
    PNY 6800GT 438/1180
    Thermaltake 420Watt PSU
    SERVER: P4c800-E Deluxe - 2.4B @ 173×18 1.525Vcore
    9800 Pro VGA silencer - 40GB Maxtor 7200RPM - Dell 350 Watt PSU
    Mar 2005
    OMFG! Talk about a scary moment. I hope everything still works after you dry it off and clean it up. Real shame to have a new shipment start off like this...
    Jan 2004
    London, UK
    Ouch, not good, thanks for the heads up.
    G
    Xtreme Recruit
    Jun 2002
    Thanks for the heads up...I just checked mine and all looked good. But it did give me a reason to take some pics,I attached one and more Hi-Res Internal shots can can be found here
    http://pg.photos.yahoo.com/ph/blore2...re27/my_photos
    --NY
Name:	Storm Package_small.jpg
    Main Rig
    Abit AN8-Ultra /3800 x2 @ 2650/ 2x512 Crucial Tracer/7800GTX/2 x 40gb maxtor RAID0/Antec 550w/Swiftech Storm, BIX, MAG3
    Feb 2005
    The Outer Limits
    Looks like metal inserts for the fitting threads in the pics of the top... could you confirm bro?
    Xtreme Recruit
    Jun 2002
    The top plate is solid delrin no meatal inserts...this pic should make it easier to see.
    http://home.comcast.net/~northernyan.../Top_Plate.JPG
    Main Rig
  18. #18
    Mar 2005
    Oregon
    Quote Originally Posted by Cossey
    OMG, DO NOT USE ACETONE ON PCBs!!!
    One thing I've found works is using BrakeClean and hitting the whole board fast at high pressure then blowing it all off with compressed air FAST. It didn't damage any of the plastic components or the board, but the stickers will be gone so take them off first and reapply after.
  19. #19
    Dec 2004
    I checked mine as well, and the o-ring is in both parts. Hopefully this is just a 1 off incident. Still haven't had time to install it in the rig yet.
  20. #20
    Jan 2005
    yeah the o-ring between the copper and black was missing. this thing was leaking bad, so bad that i heard it before i saw it....lol. im not going to try the computer till tomorrow. does anybody know if frozencpu has good rma?
  21. #21
    Dec 2004
    I know they want the original back BEFORE they send the replacement, unless of course you pay for the replacement beforehand. However, as of this afternoon, they were out of the Storm blocks
  22. #22
    Jan 2005
    yeah i know and let me just say how pist i am about that. i hope they get them in fast
  23. #23
    Mar 2005
    Opened mine up and both rings are there.
  24. #24
    Feb 2004
    Drake, Costa Rica
    why not contact Swiftech for an o-ring ?
    2.5 x 50mm
  25. #25
    XIP - can sit on his hair
    Jun 2002
    Wakefield, West Yorkshire, UK
    Heh... he's baaaaacccckkkk.... *tips hat*
