Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: Is this on the r520??
    Xtreme X.I.P.
    Aug 2004
    Chile
    Only time will tell if ATI will shout the news from its corporate rooftops, but according to the X Initiative, when it ships later this year an unspecified ATI PCI-Express graphics processor will be the first X Architecture chip on the market. ADVERTISEMENT
    Before you drift off into dreams of the X-Men and Wolverine's Adamantine augmented skeleton, let us explain.
    The X Initiative is a group of semiconductor companies promoting the X architecture for processors. (The group is fairly large, but doesn't include many of the major players in chip design, such at Intel, AMD, IBM and Freescale.)
    X Architecture is about bringing diagonal interconnects (or diagonal routing) into the design of a chip.
    Normally a chip uses all right angles to connect its various bits and pieces.
    According to the X Initiative, "The X Architecture rotates the primary direction of the interconnect in the fourth and fifth metal layers by 45 degrees" from the traditional right angles, but remains compatible with "existing cell libraries, memory cells, compilers and IP cores by preserving the Manhattan geometry of metal layers one through three." The X Initive says this is the first "production-worthy approach" to the "pervasive use" of this design.
    Why would a chip company move from the decades old right angle, or "Manhattan" chip design? Try a 20 percent reduction in wiring on a chip, which the X Initiative claims will "reduce chip costs, increase performance and lower power consumption."
    In fact, ATI's new processor, manufactured using Taiwan Semiconductor Manufacturing Company's 0.11-micron process and designed with Cadence Design Systems X Architecture "eliminated one metal layer from the original Manhattan design, reducing die costs."
    ATI is certainly bullish on the technology. Greg Buchner, vice president of Engineering at ATI claims that using the X Architecture afforded the company the opportunity to "increase the performance envelope while reducing costs." ATI is also joining the X Initiative, and will be its first fabless chip design member.
    link
    http://www.extremetech.com/article2/...129TX1K0000532
    anyone knows ?? if so it would oc even better, be cooler and cheaper, or is it a new core??
    Mar 2005
    I don't think so, R520 is built on 90nm Low-K not on 110nm process
    Mar 2005
    This X advertised 110nm chip is a "value" R520 derivative, like today's X700 and X300 are from X800, and it is supposed to arrive later this year.
    Xtreme X.I.P.
    Aug 2004
    Chile
    i've found this info, maybe the x900 has this??
    Radeon X900 XT-PE
    • 32 Pixel-Pipelines
    • 10 Vertex-Shader Einheiten
    • 90nm low-k bei TSMC
    • 500 Mhz Chiptakt
    • 700 MHz (1,4 Ghz) Speichertakt
    • 512 MB GDDR-3
    Radeon X900 XT• 32 Pixel-Pipelines
    • 450 Mhz Chiptakt
    • 600 MHz (1,2 Ghz) Speichertakt
    • 512 MB GDDR-3
    Radeon X900 Pro
    • 24 Pixel-Pipelines
    • 450 Mhz Chiptakt
    • 256/512 MB GDDR-3
    Radeon X900
    • 16 Pixel-Pipelines
    • 8 Vertex-Shader Einheiten
    • 110nm low-k bei TSMC
    • 500 Mhz Chiptakt
    • 500 MHz (1,0 Ghz) Speichertakt
    • 256/512 MB GDDR-3
    Xtreme X.I.P.
    Aug 2002
    There is no low k 110nm process at TSMC, 110nm is the cheap process used for mid range cards and now G70.
    Regards
    Andy
    Dec 2004
    Santiago, Chile
    Where will they get 1.4ns memory chips? As far as I know, the fastest memory chips are 1.6ns up to date.
    Xtreme X.I.P.
    Aug 2004
    Chile
    Xtreme 3DMark Addict
    Sep 2003
    Radeon X900 Pro
    • 450 Mhz Chiptakt
    • 256/512 MB GDDR-3
    wow even the x900pro looks to be better than the 7800gtx
    3000+ Venice 240x9=2.16GHz(ondie controller limit) 2x512mb patriot tccd ram
    9700pro at 325/310 runs all games buttery smooth!
    9700(8 pipe softmod, 128m) at 410/325 23821 at 325/310 21287 at 275/270 19159
    9500(4 pipes, 128m) at 420/330 18454 at 275/270 13319
    9500(8 pipe softmod, 64m) at 390/310 19201 at 275/270 16052
    9500(4 pipes, 64m) at 400/310 16215 at 275/270 12560
    3dmark scores with Ti4200 and Ti4800se
    Ti4200 at 340/730 19558 at 300/650 18032 at 275/550 16494 at 250/500 15295
    3dmark scores with older gpus
    Ti500 at 275/620 14588 Ti200 at 260/540 13557 MX440 at 380/680 11551
    May 2005
    Sweden
    Quote Originally Posted by Geforce4ti4200
    Radeon X900 Pro
    • 450 Mhz Chiptakt
    • 256/512 MB GDDR-3
    And it will cost much less than 7800gtx! :
    [Core 2 Quadro QX6700 @ 3.20Ghz] [Tuniq Tower 120] [Abit IN9 32X MAX nForce-680i SLI] [4x1024 PC2-6400 Team Xtreem @ 3338 400Mhz] [Geforce GTX 260 216 55nm @ 655/1408/2100 SLI] [2x74GB WD Raptor 10000RPM] [Tagan TurboJet 1100W] [7x TT Blue Led VR] [CoolerMaster Stacker 830 Evolution] [Samsung SH-S183A SATA] [Dell UltraSharp 3007WFP-HC] [Logitech Z-5500]
    Sep 2003
    $600-800 for 7800gtx, ive heard $999 for 512mb x900xt
    Xtreme X.I.P.
    Aug 2004
    Chile
    way to much....
    i think ati and nvidia have to lower the prices, for most vgas.
    Sep 2003
    they did, its called 9800pro
    Xtreme X.I.P.
    Aug 2004
    Chile
    new gen vgas i still mis my 9800pro aiw but its pci-e time now
    Dec 2004
    Melbourne
    well if the 6800GT/U vs X800XT/XT-PE story was anything to go by, you need an ATi core to run at least 100mhz quicker (core and mem) to outperform the nVidia counterpart... so I doubt X900 Pro would beat out a 7800GTX when both are at stock speeds - but yeah, again i'd assume the ATi cores would clock better.
    dfi nf4, 3200+ @ 2.98ghz on water (soon TEC), 6800U @ 460/1260. gskill GH @ 2-2-2-5
    Aug 2004
    LoSt In bLaCk HoLe
    When is the date for the ATI cards? August?
    So when ATI releases their 900 cards, give them 2-3 months to be in mass volume at the stores. Thats puts you at around X-mas time. Which is 6-months after the 7800GTX release which means... nVidia could in that time release a new card...... could happen you never know.
    Solaris
    Mobile Athlon 64 3400 CH (0450) @ 265x10=2650MHZ(33c/40c) (1:1) | DFI UT LP NF3 250GB Bios 10/15 | PQI PC-4000 1GB (TCCD, BP808) 2.5-4-4-8 265mhz@ 2.6v | Koolance PC2-601B w/CPU-300-H06, AS Ceramique | OCZ 520w Adj. rails| WD 120gb SE 7200/100 HD | WD 80gb SE 7200/100 HD| Lite on 16x DVD-ROM| Lite on 16xx DVD-RW | SB-Live Value| eVGA GF6800 Limited Ed. modded to Ultra(470mhz/1250mhz) | Cable Modem 6.6mb/768kb | Viewsonic 21" P225 monitor |
    Nov 2003
    happy place
    the x900pro looks very attractive out of the bunch. hope it comes in agp form, because i refuse to go pci-e , since i'm not going SLI or crossfire.
    --===== proud owner of new razor tarantula gaming keyboard =====--
    May 2005
    since it is right around my birthday I will buy whichever my bday money affords me to
  18. #18
    Aug 2003
    Belgique, Belga, Belgio, Belgium, Belgica, Belgie, Belgien
    Like Andy said, low K is not possible at 90nm at TSMC, so the specs are proven to be wrong.
    .:C2D 6600 :: Tuniq tower :: Asus P5B dlx :: 2GBHZ :: OCZ 520W :: 8800GTX :.
  19. #19
    Moral Police
    Nov 2004
    Belgium
    Wink
    who says the specs are wrong? Its not because TSMC doesn't do that now that they won't do it in the future on request of probabbly one of their if not THE biggest costumer?
  20. #20
    Xtreme X.I.P.
    Aug 2002
    Quote Originally Posted by Entity_Razer
    They have a cheap 110nm process at 1 fab now
    They have expensive 90nm low k process at 3 fabs now or soon.
    But you are suggesting that TSMC put more effort in an expensive 110nm low k process and build a whole new line just so that Ati can make the X900 cards ? Why make a new expensive 110nm process when they have 3 lines of 90nm working or being built ? Thats a massively backward step and would cost Ati more so it is non sensical.
    Anyhow, lets not have facts spoiling a good story , I'm going to laugh both my testicles off when it turns out there is not going to be 32 pipes
    Regards
    Andy
  21. #21
    Jun 2005
    Upstate NY
    Quote Originally Posted by metro_oc.cl
    Radeon X900 XT-PE
    • 500 Mhz Chiptakt
    • 512 MB GDDR-3
    Yeah if they could do that by Christmas I'd pick one up for anything under 1000 :-), assuming they preform as well as they look like they should on paper. I'd have to suspect Nvidia would release another card for 7 series though if ATI pulled off a lineup like this... if..
  22. #22
    Jun 2005
    Radeon X900 XT-PE
    • 500 Mhz Chiptakt
    • 512 MB GDDR-3
    • 450 Mhz Chiptakt
    • 512 MB GDDR-3
    Radeon X900 Pro
    • 450 Mhz Chiptakt
    • 256/512 MB GDDR-3
    Radeon X900
    • 500 Mhz Chiptakt
    • 256/512 MB GDDR-3
    Yeah I saw that, http://www.ati-news.de/cgi-bin/News/...&id=1117138247 is the article. If thats really what its going to be then Im going to go crazy...unless its like $900 for the x900XT PE
  23. #23
    SLC
    Oct 2004
    Ottawa, Canada
    Quote Originally Posted by Cyber$nake
    Hope fully it wont be...
    32 pipes looks insene though. Can't wait...
    btw to xtreme!!!
  24. #24
    Jun 2005
    Upstate NY
    I think that ATI should recognize that its being outsold by NVidia because of their prices, even though they put out more powerful card. Apparently, the build on the new cards allows them to make it fast but produce it for cheap, so if the R520 is 500-700$ then
  25. #25
    Aug 2004
    Austin, TX
    Remember that this is a completely new architecture, so for all we know, the R520 could be clocked lower than the 7800GTX and still get better performance.
    oh man
