XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > AMD
Reply
Old 06-10-2005, 09:37 PM   #1
uscfan
uscfan's Avatar
Send a message via AIM to uscfan
AMD Announces FOUR cores, X4???
In a detailed briefing for analysts in New York on Friday, executives at Advanced Micro Devices painted the company as making "irreversible progress" into new architectures, specifically multicore microprocessors and 64-bit processing.
Executives confirmed that the company plans to enhance its Opteron enterprise processor line to four cores in 2007, adding focused optimizations to manage power and improve throughput.
There is a great article I found over at Extremetech which explained some of AMD's plans for the future. Some of these include...
  • Shifting to DDR2 by 2006.
  • Shifting to DDR3 by 2007.
  • Dual core mobiles in 2006.
  • WiMax support for notebooks.
  • Enhancement of current 64-bit Semprons.
  • HyperTransport 3.0 (Three times the throughput of todays HTT).
  • 65nm chips coming soon from the new fab/plant in Germany.
AMD's desktop roadmaps show a "xGHz" version of HyperTransport shipping in 2007, which AMD executives did not explain.
The good news is AMD will start working with IBM to enhance the 65nm process. The bad news is AMD will start working with IBM to enhance the 65nm process.
This has a lot of juicy details that many of you will probably enjoy. Here are a few links.
The article at ExtremeTech.
Images from the announcement.
__________________
AMD Athlon 64 3000+ NewCastle @ 2450mhz (245x10)
OCZ PC3200 Platinum (2x256) @ 225mhz 2-3-2-5 [retired]
Corsair PC3200 TwinX (2x512) @ 245mhz 2-3-3-10
Seagate 250GB 7200.8 SATA
Soltek SL-K8AN2E-GR - nF3 250
Antec Neopower 500W
ATI Radeon 9800Pro
uscfan is offline   Reply With Quote
Old 06-10-2005, 10:01 PM   #2
5-Clicks
5-Clicks's Avatar
hmm......
__________________
Intel C2D E6600 (L630B015)
TT BigTyphoon || Zalman VF900 Fatal1ty
Abit QuadGT
2GB Corsair Dominator PC2-8500
HIS X1900XT --> XTX
Creative X-Fi Elite Pro
OCZ GameXStream 700w
Feedback:
HEAT --- eBAY
5-Clicks is offline   Reply With Quote
Old 06-10-2005, 10:07 PM   #3
frostedflakes
65nm. :drool:
Hopefully it'll be as successful as AMD's move to 90nm.
frostedflakes is offline   Reply With Quote
Old 06-10-2005, 10:12 PM   #4
mrbios
mrbios's Avatar
Originally Posted by frostedflakes
65nm. :drool:
it wasnt 100% succesful in overclocking terms though (subzero probs, presume its a 90nm thing anyway?) though it was a good one none the less
__________________
mrbios is offline   Reply With Quote
Old 06-10-2005, 11:08 PM   #5
trance565
wow, ddr3, 3ghz fsb, quadcore, 65nm, das gonna kick ass
just like the camaro coming back in 2k7
__________________
emptiness
trance565 is offline   Reply With Quote
Old 06-11-2005, 12:32 AM   #6
The Mofo
Banned
The Mofo's Avatar
Send a message via AIM to The Mofo
Just incase their X4 is a failure, they have X3 as a backup.
The Mofo is offline   Reply With Quote
Old 06-11-2005, 02:32 AM   #7
Squid_Spit
Squid_Spit's Avatar
Send a message via MSN to Squid_Spit
DDR2 in 2006 but then DDR3 in 2007 already....
__________________
AMD Phenom II 720 @ 3.8ghz
DFI Lanparty DK 790FXB-M2RS
2x2GB Corsair XMS2 PC8500
Gainward HD4870 1GB @ 860/1130
Thermaltake TP 750w
Custom Water
Squid_Spit is offline   Reply With Quote
Old 06-11-2005, 03:02 AM   #8
perkam
Live Long And Overclock
perkam's Avatar
Send a message via MSN to perkam Send a message via Yahoo to perkam
Yup. AMD's Quad Core CPUs is the evolution of the AMD K8 platform. Theoretically...the AMD K9
Perkam
perkam is offline   Reply With Quote
Old 06-11-2005, 04:16 AM   #9
ewitte
IMO they should just forget about DDR2 if they are supporting DDR3 so quickly after its release. I'd say while we wait to just add a second 128-bit memory controler to the 2nd core when M2 is released. Then just put 2 memory slots per processor. With such a setup there should be not only be little overclocking problems with 4x512 but also 12.8GB/s available to begin with without overclocking. Thats essentially whats available with NUMA and dual Opteron.
ewitte is offline   Reply With Quote
Old 06-11-2005, 04:37 AM   #10
adz
i would go straight to dd3
adz is offline   Reply With Quote
Old 06-11-2005, 06:58 AM   #11
Gogar
Gogar's Avatar
If they are going straight for DDR3, would they want Intel to know?
Maybe they are keeping quiet, and pretending they are going for DDR2.
While intel is probably preparing to push DDR3 right after AMD finishes moving to DDR2, or at least that's their plan i bet. Gotta keep Intel riddled you know
Ewitte, that would require 4 memory busses to be routed out.. That's a lot of pins and a very hard (expensive) mainboard to make. I think that's just what they want to avoid.
In fact if you look at how little faster memory improves performance, i think AMD is actually more interested in getting more cores to actually utilize all the on-die memory controller action. Memory isn't the bottleneck right now.
Gogar is offline   Reply With Quote
Old 06-11-2005, 07:31 AM   #12
$a1Ty
yes it has its flaws, but its way better then intels 90nm
$a1Ty is offline   Reply With Quote
Old 06-11-2005, 09:34 AM   #13
uscfan
uscfan's Avatar
Yeah I guess the transition to 90nm wasnt perfect, but what is? Upgrading an OS, installing new hardware, there are always little things that screw up.
What I am excited about is the xHGz HTT, to me it understands that the hypertransport will be running at multiple gigahertz, which might be wierd becuase then it might run faster than the clockspeed? Or maybe it will mean that clockspeed's will go thru the roof?
But I really think in the past AMD has done a good job embracing new technologies, and they will continue to do so. I hope AMD releases a bit more information regarding all of this.
__________________
Antec Neopower 500W
ATI Radeon 9800Pro
Old 06-11-2005, 12:23 PM   #14
EMC2
java junkie X.I.P.
EMC2's Avatar
Just a bit of a teaser... but the internal architecture and registers of the A64 are setup to allow up to 8 cores on a chip (not saying they are going to do that... just that the "hooks" are in place for it)
EMC2 is offline   Reply With Quote
Old 06-11-2005, 12:52 PM   #15
Borgschulze
Borgschulze's Avatar
Send a message via MSN to Borgschulze
Sweet, X4 *DROOL*
__________________
Opteron 146 CABYE 0542FPMW @ 2.8ghz 1.525v | DFI LanParty UT NF4 Ultra-D | 2x512mb Samsung TCCC 200mhz 3-3-3-8 | Sapphire x800GTO^2 16 Pipelines 624/615 | BenQ FP93G X | Seagate 7200.10 320GB SATA2 | OCZ Powerstream 520watt
Antec P180B | Danger Den TDX with Brass Top | Maze 4 GPU and Chipset | Swiftech MCR220 and Black Ice Pro 120mm Radiators | Laing D5 | Tygon R-3603 1/2" ID 3/4" OD
Borgschulze is offline   Reply With Quote
Old 06-11-2005, 12:56 PM   #16
perry_78
Ebay Hater
perry_78's Avatar
Send a message via ICQ to perry_78 Send a message via MSN to perry_78
Good info! I'll stay K8 DDR1 S939 until those fabled DDR3 mainboards come out - if indeed the transition is to take place so quickly from DDR2 to DDR3...
__________________
In short, both AMD and NVIDIA discovered that their next-generation graphics cards are superior to each others' last-generation graphics cards.
perry_78 is offline   Reply With Quote
Old 06-11-2005, 01:34 PM   #17
Turok
Turok's Avatar
Im guessing they want to release a DDR2 version in 2006 maybe due to availability.
DDR3 could be too scarce and might be buggy at the time, and DDR2 could become what DDR is right now.
__________________
LCD Buyer's Guide
Turok is offline   Reply With Quote
Old 06-11-2005, 03:40 PM   #18
Damien
Damien's Avatar
Send a message via AIM to Damien
Starting to. Alot of different DDR2 memory is out now, and latency is lowering as well. 2.5-x-x-x latency DDR2 will be sweet
__________________
Intel Core i7 920 #3841A437 @ 3.8ghz 1.26v HT off
Thermalright True-120 Extreme
Gigabyte ex58-UD3R @ 190x20
6gb (3x2gb) G.Skill Pi @ 1520mhz 7-7-7-21-1T
PNY 8800gtx @ 640/1000
abs (tagan) 700w
Antec Nine Hundred
Seagate 320gb
LG 25.5" LCD
Logitech G11 + mx518, Logitech x530 5.1 + plantronics DSP500
Damien is offline   Reply With Quote
Old 06-12-2005, 05:40 AM   #19
IYP
Send a message via AIM to IYP
yeah i think that they should give the option of DDR2 because the latencies will be low....when ddr3 comes out the latencies will be what ddr is now....ty....ddr3 will need time to evolve like ddr2 did
IYP is offline   Reply With Quote
Old 06-12-2005, 06:02 AM   #20
z24
Now if some one some where maybe rambus given license to WINBOND to Make DDR II/III then we will be Save ..............
lo bring up DDR II/III CL2225 action!! Winbond
z24 is offline   Reply With Quote
Old 06-12-2005, 11:05 AM   #21
CNCL
CNCL's Avatar
AMD is really making the moves with X2 and now the X4 and 65nm...
CNCL is offline   Reply With Quote
Old 06-12-2005, 11:19 AM   #22
kiwi
xtreme energy
kiwi's Avatar
Send a message via MSN to kiwi Send a message via Skype™ to kiwi
AMD forever
I never imagined at those old K6 300 times amd would come up with cpus it is making now.
__________________
kiwi is offline   Reply With Quote
Old 06-12-2005, 11:26 AM   #23
NickK
Agreed, I'll run with the X2 and 2Gig of DDR until 2007.
My upgrades have been:
Tbird & PC133 -> Barton & DDR -> X2 & DDR -> X? & DDR?
__________________
Still using the ADA4400DAA6CD CCBWE 0517MPMW
NickK is offline   Reply With Quote
Old 06-12-2005, 05:56 PM   #24
ferrari_freak
ferrari_freak's Avatar
Send a message via MSN to ferrari_freak Send a message via Yahoo to ferrari_freak
I personally would wait and let ddr3 evolve like ddr2 did before making a move, and then being 13 right now, and 15 in 2007.... I would also need my dad's permission.... Can't wait to see what these new technologies can do though!
Usama aka Ferrari Freak
__________________
Originally Posted by jimmyz View Post
A DFI board is like a divorce, expensive, but well worth it.
Originally Posted by virtualrain View Post
I dunno... I think a DFI board is more like marriage... demanding, time consuming, and a PITA but rewarding in it's own twisted way.
ferrari_freak is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
