XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Overclocking
Reply
Old 05-16-2005, 12:19 AM   #51
Sampsa
Xtreme Legend
Sampsa's Avatar
PCMark04: 9017
God damnit! 3 points from FUGGER's Intel WR
__________________
Favourite game: 3DMark
Work: Muropaketti.com - Finnish hardware site
Hobby: overclocking.fi - Extreme overclocking: Team Finland
Sampsa is offline   Reply With Quote
Old 05-16-2005, 12:56 AM   #52
over@locker886
Champion
over@locker886's Avatar
Send a message via MSN to over@locker886
What clock?
over@locker886 is offline   Reply With Quote
Old 05-16-2005, 01:01 AM   #53
GoThr3k
Banned
Originally Posted by Sampsa
PCMark04: 9017
some ln2 might do the trick
GoThr3k is offline   Reply With Quote
Old 05-16-2005, 01:52 AM   #54
lv_88
looks great! impressive
__________________
Xeon X3350 3.52Ghz, GB DS3R, 8GB G.Skill 1.05GHz, 8800GT
lv_88 is offline   Reply With Quote
Old 05-16-2005, 03:01 AM   #55
Hombre
Very nice results indeed. Dual core looks awesome.
Hombre is offline   Reply With Quote
Old 05-16-2005, 03:14 AM   #56
REDKEN
REDKEN's Avatar
What vcore are you giving it now?
__________________
P4C800E DL,P4 2.4c @ 3.4(droop mod),1G Mushkin 3500 II 2,2,2,8 @ 3.1v,AIW 9800 Pro (450/370 @ 1.9v core),Audiology Platinum,2xDiamonds 8mb Raid0,Lian-Li Pc70,PC P & Cooling 510D,Plextor 708A,Plextor 52x32x52...water cooled...
REDKEN is offline   Reply With Quote
Old 05-16-2005, 06:03 AM   #57
kryptobs2000
kryptobs2000's Avatar
Send a message via AIM to kryptobs2000
Yes but I should still be able to compare power consumption between A64 X2 4800+ and FX-55 if I only change the CPU in the system, right?
makes sense to me.
__________________
E8400 @ 3600mhz
4870 @ 790/1100
2x2GB DDR2
kryptobs2000 is offline   Reply With Quote
Old 05-16-2005, 06:30 AM   #58
FUGGER
Xtreme Owner
FUGGER's Avatar
Send a message via MSN to FUGGER
Nice!
My 2K4 was also done at a little over 200FSB as I was testing to get past 5Ghz. Dont forget my mobo was very limitd limited and I should have been well over 5Ghz.
Pi's are close and I am sure I can do much better.
__________________
Intel Core i5 661 @ 4.6Ghz
Gigabyte P55A - supports 32nm now
Gigabyte GTX 260 SOC
Corsair Dominator 8GB 2200C8
Intel SSD RAID 0
http://valid.canardpc.com/show_oc.php?id=925582
FUGGER is offline   Reply With Quote
Old 05-16-2005, 07:26 AM   #59
mesyn191
Sampsa needs to send FUGGER his CPU and mobo so FUGGER can put it on his triple cascade and get that X2 up to 4GHz!!
mesyn191 is offline   Reply With Quote
Old 05-16-2005, 07:43 AM   #60
Sampsa
Xtreme Legend
Sampsa's Avatar
Naah, I'll be giving it some LN2 treatment in few days.
__________________
Old 05-16-2005, 07:45 AM   #61
Sampsa
Xtreme Legend
Sampsa's Avatar
Originally Posted by FUGGER
Nice!
I have to say that I can do much better also
I tried Pentium EE 840 today with Vapochill LS. I have to say that the experiment was HORRIBLE. I was able to run spi1m @ 4,5 GHz but not PCMark04 even at 4 GHz. Asus Probe showed CPU temp 33C under load and Vapo's LCD showed -32C for evap
Components next to Socket 775 were EXTREMELY hot.
__________________
Old 05-16-2005, 07:47 AM   #62
Sampsa
Xtreme Legend
Sampsa's Avatar
Here are my results with Vapochill LS:
__________________
Old 05-16-2005, 07:52 AM   #63
Sampsa
Xtreme Legend
Sampsa's Avatar
Power consumption was 440W during PCMark04
My mistake, this is not correct because there was also Vapochill LS between the Antec 550W and wall socket
__________________
Old 05-16-2005, 07:53 AM   #64
Sampsa
Xtreme Legend
Sampsa's Avatar
__________________
Old 05-16-2005, 08:11 AM   #65
macci
Xtreme Legend
macci's Avatar
Nice show there Sampsa.
I have a feeling that it will be in better hands here in Finland
Also it's quite obvious that this chip ain't going to see anywhere near 4GHz - no matter what cooling.
macci is offline   Reply With Quote
Old 05-16-2005, 08:24 AM   #66
REDKEN
REDKEN's Avatar
Thanks for sharing all this info with us Sampsa.:beer:
So, you got to 3.0 @ 1.4v and 3.1 @ 1.55v would it be fair to say that it would scale higher with more vcore? Maybe 3.3-3.4 could be reached with pase.
__________________
Old 05-16-2005, 10:49 AM   #67
zakelwe
Xtreme X.I.P.
3.1GHz with a Vapo LS is pretty good going actually considering it is 2 cores. FX-55 on single stage phase was at max getting 3.3GHz.
Of course this is one chip so it might be bad or might be good. However AMD bringing out a duel core at only 200Mhz less than FX-55 seems to be replicated with the overclock ( 200Mhz drop ).
Asuming Sampsa's chip is average ( a big IF ) then this is not bad at all and bodes well for the future. I'm actually quite surprised to be honest, I thought x2 would be dire !
I'm still more interested in Dothan and Fx-57 though at present, but I am really looking forward to what Sampsa can do with very few kelvin. You have to think two cores will like few kelvin an awful lot. More so than voltage of course.
Regards
Andy
zakelwe is offline   Reply With Quote
Old 05-16-2005, 11:01 AM   #68
Sampsa
Xtreme Legend
Sampsa's Avatar
Yes, it would be a miracle to hit 4 GHz with this chip
Anyway, I'll try to hunt 10k in PCMark04. I'll also try to find out if this CPU can go higher for 3DMark05 than my FX-55 (3474 MHz),
__________________
Old 05-16-2005, 11:12 AM   #69
mike
"the Situation"
mike's Avatar
Awesome score! Good luck on your quest to 10k!
__________________
It may be the reincarnation of Gautama Buddha, but that does not change the fact that she was rap.. ...
mike is offline   Reply With Quote
Old 05-16-2005, 12:23 PM   #70
Kunaak
Xtreme 3D Mark Team Staff
Kunaak's Avatar
Send a message via ICQ to Kunaak
jesus man, 9 K on PCM'04 and not even 3.1 ghz. thats just crazy...
I can't wait to see what this does under cascades and LN2.
__________________
Kunaak is offline   Reply With Quote
Old 05-16-2005, 01:03 PM   #71
FUGGER
Xtreme Owner
FUGGER's Avatar
I had another 2K4 submitted and not published.
http://service.futuremark.com/compare?pcm04=2948934
200FSB on the link above.
__________________
Intel SSD RAID 0
Old 05-16-2005, 01:08 PM   #72
macci
Xtreme Legend
macci's Avatar
your score went up by 44MArks (9003 => 9047) when you overclocked from 4351MHz to 4817MHz??
Is this the new dual-core scaling or what??
Old 05-16-2005, 01:19 PM   #73
FUGGER
Xtreme Owner
FUGGER's Avatar
no from 4.669Ghz to 4.8Ghz about 140Mhz gain in speed. The 4.66 was at 333FSB 1:1 3-2-2
__________________
Intel SSD RAID 0
Old 05-16-2005, 01:34 PM   #74
mesyn191
Man you guys are lucky, I've only ever gotten a good OC once waay back with a Palimino 1700+ @ 2Ghz stable on water.
Even with my VapoLS I can't break 2.8Ghz stable with my A64 3500+ and you guys got the friggin' 3Ghz dual core A64 and 3.45Ghz FX55!?!
\must be cuz of the cold weather in Finland...
Old 05-16-2005, 02:28 PM   #75
macci
Xtreme Legend
macci's Avatar
Fugger, what do you mean 'no'?
you've got a score of 9003 at 4351MHz and 9047 at 4817MHz. Obviously also 9020 at 4668MHz.
So looks like upping the CPU spee doesn't help much there.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
